Ten New Turntables Revealed in 2015 - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 21 Old 03-20-15, 12:10 PM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson's Avatar
Todd Anderson
If the recent vinyl revolution has caught you by surprise, then you’re probably unaware that dozens of companies currently manufacture turntables. Today, we'll spotlight ten new turntables that were showcased at CES 2015 or have been officially launched this year. Some are pure budget-crushers while others carry familiar brand badges. What’s striking is the omission of one incredibly familiar name: Technics. The high-end Panasonic brand, and maker of the ever-popular SL-1200 player, had its analog turntable division shuttered in late 2010. Despite recently injecting life into the brand, Panasonic’s rollout of new Technics products has not included any turntable gear.
So, without further delay, here's ten new turntables (in order of expense) that can breathe new life into your vinyl collection.
10. TechDAS Air Force 2 (MSRP $50,000)
Wasting no time, we’ll go big with our first featured turntable: TechDAS’s Airforce 2. The Air Force 2 is the most expensive player on our list, and at a cool $50,000 it obviously has a relatively limited market. But, at half the price of its elder sibling (Air Force 1), TechDAS’s latest installment offers some relief for high-end buyers. If you’re considering this player, you’ll need space as the unit is a large 30x17.7x7in (WDH) and weighs nearly 100-pounds. These measurements do not include a separate outboard air pump and power supply (17x10x6in).
The Air Force 2 features a cast aluminum chassis, oil-dampened air suspension, and vacuum hold-down for the records. It also has the ability to accept two different tonearms (a standard 10-inch mounts on the right, while a tonearm of up to 12-inches can be placed in an arm base on the left side of the player).
9. Spiral Groove The Revolution ($15,000)
For slightly less coin, Spiral Groove’s latest player, The Revolution, is another option for the high-end crowd. Unveiled at CES 2015, The Revolution features an outboard sine-wave power supply, an AC synchronous dual speed motor, and a dampening graphite top-plate for smooth play back. The player’s body is composed of three layers made from two different materials for total isolation. For vinyl enthusiasts that like to change arms, The Revolution claims to offer easy arm changes and can accommodate tonearms up to 12-inches.
8. AMG Giro G9 ($9900)
Continuing down the price ladder, the German manufacturer AMG introduced its new Giro GR at CES 2015. Conceived by AMG founder Werner Roeschlau, the Giro G9 is manufactured – completely – at the company’s Bavarian factory. The player’s platter and bearing housing are CNC machined from a hi-tech synthetic. The Giro G9 uses parts from AMG’s Viella V2 turntable, including a high-mass stainless steel machined pulley coupled to a precision Swiss-made DC motor.
7. European Audio Team ($3700)
Hitting more affordable territory as a gatekeeper that stands between expensive and truly high-end, European Audio Team’s C-Sharp turntable is new to 2015. The C-sharp is an elegant looking player that features a chassis made of high-density MDF. The player’s belt is made from special anti-static rubber and the tonearm is redesigned to combine the load-lessening advantages of a unipivot arm with a cardan design.
6. Tri Art Pebbles TA-1 ($995)
Tri-Art’s Pebbles TA-1 is a natural choice (no pun intended), featuring a gorgeous bamboo platter and other wood compliments. The tonearm (which is sold separately for $350) is also crafted from bamboo. These nature-friendly players are completely designed, fabricated, and assembled by our neighbors up north in Canada.
5. Onkyo CP-1050 ($599)
As featured in our vinyl article earlier this week, the Onkyo CP-1050 looks to have been launched from the 1980s directly to 2015’s store shelves. With an attainable price-point, the CP-1050 features a quartz-lock control system and a die-cast aluminum platter. It also has a built-on dust cover to keep pesky flecks of dust from gathering on your vinyl as it spins to musical bliss. Onkyo’s included tonearm can accept a range of aftermarket cartridges (between 5-10 grams).
4. Pioneer PL-30-K ($299)
Yes indeed, our familiar friends at Pioneer also have a new turntable offering: the PL-30-K. It’s priced about $200 less than Onkyo’s CP-1050 and is aimed directly at the plug-and-play crowd. Weighing-in at 12-pounds, the PL-30-K features a dual layer chassis, a 4mm-thick metal platter (5mm thick rubber mat), and a DC-servo controlled motor. Nearly identical to Onkyo’s design, this unit also has a plastic dust cover.
3. ION Audio Air LP ($149)
Ion is gunning for the ease-of-use digital age crowd with its Air LP Bluetooth turntable. If you’re an analog enthusiast, you probably just cringed…but, yes, ION is offering a player that wirelessly streams to Bluethooth speakers following an onboard analog to digital conversion. Users can also use included software to rip vinyl into separate digital files. Luckily, the Air LP does have RCA output capabilities to right all wrongs.
2. Audio Technica AT-LP60 ($129.95)
Hitting our budget range, the AT-LP60 was debuted by Audio Technica at CES 2015 in both blue (AT-LP60BL) and red (AT-LP60R) finishes. This belt-driven turntable is fully automatic with a switchable phono preamp allowing it to be connected directly to a computer or other sources lacking a dedicated phono input. The AT-LP60 is available exclusively through Amazon.com.
1. Crosely Cruiser ($99.95)
Now to the budget of the budget-minded turntables: Crosely’s Cruiser. This is a self-contained three-speed player featuring onboard speakers; no gear required. The unit is constructed of wood covered by a leatherette material. It closes like a brief case for ease of portability. The Cruiser won’t offer a true hi-fi experience, but if you’re looking to hear some old LPs on the cheap, it might just do the trick.
Image Credits: DasTech, positive-feedback.com, European Audio Team, AMG, Tri-Art, Onkyo, Pioneer, Audio Technica, Crosely, Ion Audio, hercampus.com
Todd Anderson is online now
post #2 of 21 Old 03-21-15, 02:28 PM
Talley's Avatar
Re: Ten New Turntables Revealed in 2015
Don't forget the Work of Art from Basis Audio - $160,000
Master Electrician
My Theater Build
XPA-7 & Krell Showcase 7 | XMC-1 | SVS Ultra Tower system | HSU VTF-15H MK2 | BenQ W1070 | Jamestown 135"
Talley is offline
post #3 of 21 Old 03-21-15, 11:40 PM
Meetdtaylor's Avatar
Derrick
I love the look of the tone arm on #9. Simply gorgeous! I wonder what the sonic characteristics are from the curves?
Meetdtaylor is offline
post #4 of 21 Old 03-26-15, 10:53 AM
Creative award should go to #6 for being made out of bamboo. Unit looks great.
39cord is offline
post #5 of 21 Old 04-12-15, 11:44 AM
New Member
You are right when You say that there is no Technics tournable, but the eritage of the great SL-1200 is taken by Pioneer that with the PLX-1000 takes the perfection (for DJs and 1200-lovers) of the '1200 to a new level. The similarities are evident and the differences are a lot too (without diffentiating too much from the original): detachable audio and power cables, 8, 16 and 50% speed control (for DJs), etc. This is not simply a clone such as the Audio Technica AT-LP120-USBHC - which has also 78 rpm - and I think it may be a good news for DJs ...and for some of us too!
gipoco is offline
post #6 of 21 Old 04-14-15, 08:55 PM
New Member
I'll take number 7....for $1500.
bkoch47 is offline
post #7 of 21 Old 06-03-15, 07:49 PM
tcarcio's Avatar
TC
Well I decided to check out my old vinyl again so I ordered the Audio Technica in red and it is on sale so I got it for $110.15 shipped so not bad. I got it at Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Onkyo TX-NR809 HT receiver
HPS-4000,SR-70, John Allen, Klipsch Heresy, Speakers for L.C.R.
QSC GX-5 power amp for L+R mains
Chase Home Theater PRO-10's for surrounds
Behringer EP 4000 pro amp for the Danley DTS-10 tapped horn sub
Oppo BDP-93 universal BD player
Toshiba HD XA2 HD dvd player
Sony VW-VPLPRO1 1080p PJ
Cinema White 1.0 gain 106" fixed frame screen
Dish network with 2 Hoppers and 1 Joey
tcarcio is offline
post #8 of 21 Old 06-03-15, 08:38 PM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson
Let us know what happens with that!
post #9 of 21 Old 06-04-15, 07:41 AM
tcarcio's Avatar
TC
Todd Anderson wrote: View Post
You got it.......
tcarcio is offline
post #10 of 21 Old 06-12-15, 04:09 PM
tcarcio's Avatar
TC
Got the Audio Technica TT today and hooked it up. It sounds great and the TT is so simple to operate it is great for someone who is just getting into vinyl. One thing I forgot is how I used to cringe when the LP had a skip and that cracking sound brought back memories long forgotten. I definitely will have to do a big time cleaning of all my LP's but I don't at the moment have too many so I will take care of that ASAP. Does anyone have any advice on record cleaning devices that are around $100?
tcarcio is offline
2015 , revealed , ten , turntables
You may not post new threads
