Klipsch Releases Three New Speaker Models (RP-280FA, RP-140SA, REP-450CA) - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 15 Old 07-27-15, 09:22 PM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson's Avatar
Todd Anderson
A new day, more Atmos. This time we’re turning our attention to a wildly popular speaker company known for its efficient horn-loaded loudspeakers: Klipsch. Recently, the company officially debuted three new speaker models with immersive audio in mind.
Klipsch has released an all-in-one Atmos speaker solution, the RP-280FA.
Headlining the debut is a floorstander and Atmos all-in-one model. Since the announcement of Atmos, we’ve seen quite a few Atmos module speakers hit the market. These modules are designed to be placed on top of existing speakers in order to bounce sound off a ceiling to create a sense of height. As we reported last week, this isn't the best option for immersive sound primarily because lower frequency sounds are more diffuse and much harder to aim via sound reflection. However, THX believes that the typical home employing Atmos will use some sort of add-on Atmos speaker technology (as opposed to installing ceiling speakers).
Klipsch’s new all-in-one is called the RP-280FA. Wrapped in either a walnut or black real wood veneer, this speaker is built on the same technology used in the company’s RP-280F floorstander. It features dual forward facing 8-inch cerametallic cone woofers and a single 6.5-inch cerametallic height channel woofer. It also has two 1-inch titanium dome LTS tweeters with a Hybrid Tractrix Horn (one forward facing, one height). Being a Klipsch, it's not surprising this speaker is incredibly easy to drive (sensitivity = 98db). The main forward facing channel can handle 150 Watts of continuous power (600W peak) while the height channel is rated at 75W continuous and 300W peak.
If you buy an RP-280FA, then have your weight-belt or a friend on standby; the speaker weighs a hefty 72-pounds.
Klipsch’s other new offerings include the RP-140SA Atmos module speaker and the REP-450CA center channel. The 450CA is a large speaker (31.13-inches wide, 6.81-in high, 14.51-in deep, 35.7 lb.) that features four 5.25-in cerametallic cone woofers and one horn loaded 1-inch titanium tweeter. It is also highly sensitive (97db) with a 150W continuous power handling capability (600W peak). Available in walnut and black wood finishes, the company is billing this channel as the front channel mate of the RP-280FA.
The 140SA is an add-on module speaker designed to sit on top of floorstanding and bookshelf speakers. Its 4-inch cerametallic woofer and 1-inch horn loaded titanium tweeter are set in a fixed-angled position to throw sound off the ceiling of a room. The footprint of the speaker is 6-in x 11-in. It’s finished in black only.
All three speakers are available now (MSRPs: RP-280FA $1,200/each, RP-450CA $850/each, RP-140SA $499/pair).
Image Credits: Klipsch
Todd Anderson is offline
post #2 of 15 Old 07-27-15, 11:23 PM
willis7469's Avatar
I sure wish I could demo some of these types. Despite fairly good reports(early anyway) I can't get my brain to accept this as viable. Obviously manufacturers think it's good so who am I to say, but my vaulted ceiling might disagree. Has anyone heard a good demo with upfiring atmos speakers? What did you think?
Thanks Todd. Love seeing new stuff.
willis7469 is offline
post #3 of 15 Old 07-28-15, 05:38 AM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson
Re: Klipsch Releases Three New Speaker Models (RP-280FA, RP-140SA, RP-280FA)
willis7469 wrote: View Post
Hey Willis,
I'm not so sure manufacturers think it's good...but I believe they think there's a large market for it. I've heard some rumblings (no specifics) about other possible non-inceiling options. Hopefully those will take shape.
post #4 of 15 Old 07-28-15, 07:16 AM
Chromejob's Avatar
David S.
Todd Anderson wrote: View Post
A new day, more Atmos....[/I]
HOW many new speakers? Look at your subject line, Todd.
“Say, was you ever bit by a dead bee?”
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550.
Chromejob is offline
post #5 of 15 Old 07-28-15, 07:44 AM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson
Chromejob wrote: View Post
post #6 of 15 Old 08-01-15, 01:33 PM
Kyle
Re: Klipsch Releases Three New Speaker Models (RP-280FA, RP-140SA, REP-450CA)
Does atmos have more soundfeild depth then pro-logic heights? dsx
Id love to hear a pair of these.
kingnoob is offline
post #7 of 15 Old 08-01-15, 06:27 PM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson
Atmos is an object oriented, rather than channel assigned, codec. I'd hazard to guess that Atmos with ceiling mounted channels would have more of a depth and height effect than IIz...not only due to channel placement, but also the encoding factor.
post #8 of 15 Old 08-01-15, 10:52 PM
willis7469's Avatar
I Agee here, but my disconnect is when they describe it as "object" based. Sounds still have to "pan" around the speakers. Right? How is is that so much different than how, for example, a jet flies overhead? Oversimplified it seems like a sophisticated "fader" like in my car. Prob not the place for me to look for clarity. Sorry. Maybe I'll try the "atmos explained" thread.
post #9 of 15 Old 08-02-15, 06:48 AM Thread Starter
HTS Administrator
News Editor
Reviewer
Todd Anderson
No worries, Willis! I see where you're going with this...it does seem, at some level to be splitting hairs...but because of the root differences between encoding, it's not
Traditional multichannel systems are coded to assign sounds to channels. Yes, sounds pan and can come from more than one channel, as sounds move around a room. But, the gist is that the coding is channel locked. In the Atmos system, sounds are coded to where they are meant to appear in a 3D listening space via a package of metadata. When you playback an Atmos track, that metadata is decoded and the system uses the available speakers to attempt to have the sound appear where intended...which means that the sound may come from more than one speaker as the system attempts to pinpoint a sound in 3D space. Obviously, this means that the intended sound effect has a better chance of being accurately placed with more available speakers (such as a theater with 32 speakers).
I would hazard to guess that Atmos encoded movies rely on both standard multi-channel coding techniques and Atmos metadata (depending on a what's going on in a movie)...but, in general, an Atmos encode has a much more diffuse playback effect with depth and height that tradition multichannel systems don't have.
post #10 of 15 Old 08-10-15, 10:58 AM
Bouncing sound waves off a ceiling.. doesn't this just seem silly altogether?
Just seems so gimmicky.. worse than 3D.
Realtorx7 is offline
klipsch , models , releases , rp140sa , rp280fa , speaker
You may not post new threads
