| Home Theater, Audio and Video News Engadget HD Review: HDHomeRunDiscuss Engadget HD Review: HDHomeRun in the General Shack Area forum; Engadget HD Review: HDHomeRun Filed under: Features , Reviews , Media streamers
It isn't everyday that a new class of device is released, one ... |
Views: 821 - Replies: 0
| Engadget HD Review: HDHomeRun Filed under: Features, Reviews, Media streamers ![]() ![]() About the software. Plug everything in and head over to your pc, what you do next depends on what kind of computer you have. Out of the box the tuner works best with MythTV, it's as simple as a adding the two tuners to your MythTV config. If you don't have MythTV things get a little more complicated, as well as this hardware works there is no doubt there is something missing in regards to software. We had no problem using this device on a MacBook Pro, but we can see how others might shy away. First you download the source code, make sure XCode is installed run make and you have a very simple CLI application to control the HDHomeRun. Then you launch VLC, tell it to open a UDP stream and then you enjoy HD. Sound easy enough, then go for it, this thing works great! If it seems a bit complicated we don't blame you, but there is hope, there is a Windows GUI that doesn't require you to compile it and will launch VLC for you, but you still have to know what channel you want to watch and unfortunately it may not be the channel you think you want to watch. ATSC channels use PSIP information to remap the real channel to the channel you know and this box doesn't pick up the PSIP information automatically, lucky for us Antennaweb.org has all the info we need and it doesn't take long to learn that CBS Ch 10 is Ch 24. ![]() The windows GUI has a nice little signal strength meter while Linux and OS X fans have to use the watch command to get the same info. Of course MythTV takes care of all this for you as well as recording and there are plans for a MCE plug-in as well as BeyondTV, there is even talk of a client for the Roku HD1000. Personally I think they need to make a Sling like player for your computer maybe using the VLC source. The good news is the player uses open standards and the software it does come with is open source so the smart people of the world will be able to do alot with this box. Hardware performance Software aside this is a solid piece of hardware. It works flawlessly streaming HD to every box we have thrown at it. In the past we have had plenty of trouble trying to stream HD via WiFi to our Xbox360 and we are starting to think it isn't the WiFi's fault, this little box can stream via WiFi without missing a farme. It does use UDP which has to help(not sure what the Xbox uses), we open VLC info and verified that it was streaming the full 19.3Mbps stream and network monitor to confirmed it. ![]() Conclusion If you are in the market for dual ATSC tuners for your MythTV setup this may be the way to go, the network enable device allows you to add as many tuners as you want without being limited by the number of PCI slots in your PC, which opens up opportunities with small form factor computers like the Mac Mini. Priced at $169 you will have a hard time buying two ATSC tuners cheaper. If you aren't a MythTV user yet, you may just want to hold off and wait for the community to deliver more compatible software that is more user friendly. Were going to have to pay for this thing so we can keep it, as it is the perfect way to watch HD while writing on Engadget HD. Read | Permalink | Email this | Linking Blogs | Comments SPONSORED BY: BOLD MOVES: THE FUTURE OF FORD A new documentary series. Be part of the transformation as it happens in real-time. | ||||
