Onkyo 605 Or 805? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Onkyo 605 Or 805?
Discuss Onkyo 605 Or 805? in the Home Theater | Audio and Video forum; Onkyo 605 Or 805? Hi i'm new to this forum and dont know much about home theater.I just purchased a pioneer pro-1150 hd plasma ...
Old 03-13-08, 04:19 PM   #1 (Link)
New Member
Alias: BOB
User: #18141
Since: Mar 2008
JAKE 2544 is offline
Onkyo 605 Or 805?
Hi i'm new to this forum and dont know much about home theater.I just purchased a pioneer pro-1150 hd plasma and now want to purchase a new receiver.I have been looking at the onkyo 605 and 805 which would be better for this plasma and why?I currently have a sony receiver with cambridge soundworks speakers and a cambridge soundworks 12 bass cube.Thanks for all your info i'm glad i stumbled on this site.
Old 03-13-08, 08:04 PM   #2 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is offline
Re: Onkyo 605 Or 805?
Hello Jake, Welcome to the Shack.
Depends,... I'm not familiar with your speakers, but I'd bet either receiver would do you fine. In my book the main items in choosing a receiver are; budget and features. Onkyo, Denon, Yamaha, Pioneer, Harmon Kardon are all comparable, just depends on the features you need and the price you are willing to pay.
Mark
Old 03-13-08, 10:17 PM   #3 (Link)
Loc: Lower Alabama
Yes... either will work equally well with the plasma. The 805 does have numerous other features that make it worth owning if you can afford it. With a Pioneer plasma... I'd bet you can afford the 805.
Old 03-14-08, 07:56 AM   #4 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
Both Sonnie and myself have the 805 and we both like the features and sound it produces. the bigest difference between the 605 and the 805 is that the 605 does not have pre outs in case you ever want to ad an external amp and of course the 805 has a fair bit more power and surround modes Also the 805 has the best Burr Brown DACs available.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 03-14-08, 08:38 AM   #5 (Link)
New Member
Alias: BOB
User: #18141
Since: Mar 2008
Ok thanks for the replies,not to get off this subject but let me ask this.What benefit will i get going hdmi from the 805 to the plasma over going hdmi from my motorola hd cable box to the plasma.I currently have hdmi from the hd cable box to my hitachi plasma and use a optical cable from the hd cable box to my sony receiver.Will i get a better picture out of the 805 over my hd cable box?If so do i hook up a hdmi from the cable box to the 805 and another hdmi from the 805 to the plasma?sorry about all the ?????
Old 03-14-08, 10:49 AM   #6 (Link)
Loc: Lower Alabama
I think it is a situation of half a dozen to one, six to another. I do not see there being any improvement... if anything possibly less (though I doubt) since the signal has to go through an extra path. If you want video upconversion from 480i or 480p to 1080, you will need to go up to the 875. Then you might see some improvement in your image.
If you have more than one source, such as the cable box and a DVD player, then connecting them both through the receiver and then out to the plasma will keep you from having to switch inputs on the plasma... and you would no longer need the optical cable.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Similar Threads
Onkyo TX-SR 605 Owners? jmy2469 Home Theater Components 28 04-01-08 07:02 PM
Onkyo 605 or 705? acommonsoul Home Theater Components 7 03-03-08 01:30 PM
Yamaha RSXV1700 vs Onkyo 805 vs Onkyo 705 Buckster Home Theater Components 2 03-03-08 09:22 AM
no picture through HDMI connection? onkyo 605 jimbronie System Setup and Connection 1 12-31-07 01:18 PM
Need some help setting up Onkyo 605 jmy2469 System Setup and Connection 4 06-08-07 09:00 PM
Mach 5 Audio
