| System Setup and Connection Speaker wire question?Discuss Speaker wire question? in the Home Theater | Audio and Video forum; Speaker wire question? I recently purchased the Onkyo HT-SP908 Home Theatre System (7.1 surround sound). It consists of:
- TX-SR605 Receiver 90 watts ... |
| | #1 (Link) | |||
| Speaker wire question? I recently purchased the Onkyo HT-SP908 Home Theatre System (7.1 surround sound). It consists of: - TX-SR605 Receiver 90 watts min. continous power per channel - speakers: 2 way closed type, Impedence 8 ohms, max. input power 110 Watts, Frequency Response 60 Hz-50 Hz The system sounds great though, at times, the center speaker tends to get static when someone screams or a loud noise is on screen while playing a DVD movie. I am using the original wire that came with the system (real thin). Questions: 1- Is the speaker wire too thin and doesn't have the capacity at high volumes (starts getting static at Vol. #80 - range is 1-100)? 2- If I need a thicker gauge wire, what gauge should I get (my longest run is about 30 ft.)? 3- Is it worth getting "Monster Wire" or just a good premium Radio Shack wire. If so, what gauge/type? I appreciate any help. Thank you | |||
| | #2 (Link) | |||
| Re: Speaker wire question? No. That's not the wire. I couldn't see Onky supplying wire of insufficiant gauge. Stay clear of Monster. It sounds like the noise your hearing is the speaker distorting. If its a problem, turn it down. If your dialogue comes across well, you could lower the volume on your center a bit. If I watch at high volume, I tend to drop the center volume. It gets too harsh in the center. Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | |||
| | #3 (Link) | |||
| Re: Speaker wire question? Could also be that the power amplifier in the Onkyo is clipping? 80 (out of 100) is really loud (for this amplifier) and clipping is not impossible here. As Randy wrote, turn the volume down when the sound gets distorted. If you need to play louder then you will have to upgrade to a more powerful amplifier/receiver... Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100" | |||
| | #5 (Link) | ||||||
| Re: Speaker wire question? Quote:
Your receiver is rated at 90watts and that wont give you high db levels. Quote:
Go with 14awg wire. at 30 ft thats plenty. Quote:
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | ||||||
| | #7 (Link) | |||
| Re: Speaker wire question? Definitive opinion on speaker wire: http://www.roger-russell.com/wire/wire.htm Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #8 (Link) | ||||
![]() Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100" | ||||
| | #10 (Link) | |||
| Re: Speaker wire question? so are you saying that I should change out my Monster cable XP? but I got such a good deal on it at Ocean State Job Lot. It comes in package form, not by the roll, 4 lengths of very flexible color coded and terminated 14 gauge wire. priced at $8.99 per pkg. | |||
| | #11 (Link) | |||
| Re: Speaker wire question? Monster cables are fine and for the price you got them for there is no reason to return them if they do the job but usually they are simply overpriced. I had a Monster HDMI cable on my BluRay player that cost $80 and after returning two of them due to intermittent issues I finally went with a cheaper brand and have had no problems since. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #12 (Link) | |||
| Re: Speaker wire question? If you are selective, some of the Monster branded stuff is quite good. They do tend to overprice their products for what you get though... and they will put their name on just about anything that will make a buck. | |||
| | #13 (Link) | ||||
![]() About the sound ... Did you calibrate your system??? ... If you haven't maybe this will help, who knows and your speakers levels are to high and that are distoring the sound ![]() | ||||
| | #14 (Link) | |||
| Re: Speaker wire question? Don't forget monoprice Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #15 (Link) | |||
| Re: Speaker wire question? As has been said; 14awg is good and plenty. Lowe's will sell it really cheap; just make sure it's phase marked so you can see which channel is which. Nothing wrong with Monster cable if the price is right, but Noel Lee's a very greedy man... Cheers, Konky. I get up...I get the paper...I read the obituaries...if I don't see my name; I go ahead and have breakfast! George Burns. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| In-wall or standard speaker wire? | Jodean | Remotes | Cables | Accessories | 6 | 02-03-08 11:30 AM |
| Speaker wire and Cables, newbie ? | Tuddy | Remotes | Cables | Accessories | 5 | 12-14-07 07:29 AM |
| Question about CL3 Speaker wire Prices. | Scuba Diver | Home Theater Design and Construction | 4 | 11-02-07 07:03 AM |
| Speaker wire & conduit | Dain Bramaged | Home Theater Design and Construction | 16 | 10-20-07 09:21 AM |
| A Comprehensive Guide to Splicing Speaker Wire | Wayne A. Pflughaupt | Remotes | Cables | Accessories | 1 | 08-02-07 08:24 PM |
