audyssey worth it? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
audyssey worth it?
Discuss audyssey worth it? in the Home Theater | Audio and Video forum; audyssey worth it? I am completing my DIY surround system, and will be getting a new receiver soon. I have digital cable, and ...
Old 03-16-08, 11:34 AM   #1 (Link)
Alias: Dave
Loc: Bloomington, Illinois
User: #9307
Since: Jun 2007
chopperguy99 is offline
audyssey worth it?
I am completing my DIY surround system, and will be getting a new receiver soon. I have digital cable, and an upconverting dvd (no blu-ray yet) that both use hdmi cables. My tv only has one hdmi input, so switching is a must. Running seperate opticals is no big deal if the receiver is only pass thru. I need to know if audyssey should be on my feature list. And which version. EQ2 or Multi EQ. I have no test equipment at all right now. I will be buying refurb, and only have about 300 or so to spend. Thanks for any advice.
Old 03-16-08, 01:01 PM   #2 (Link)
Loc: Lower Alabama
Re: audyssey worth it?
Audyssey can in some cases be helpful. I would recommend it if I could afford a receiver with it, but only the most recent version of MultEQ. I do not believe you will get that with $300, but I could be wrong.
Old 03-16-08, 09:08 PM   #3 (Link)
Alias: Dave
User: #9307
Since: Jun 2007
After some research, it looks like a lower line denon would be my only option with the multi eq. The 1708 or 1908.
Old 03-17-08, 12:11 AM   #4 (Link)
Loc: Lower Alabama
And neither of those are what you get in the more expensive upper end receivers they offer.
Old 03-17-08, 07:15 AM   #5 (Link)
Alias: Dave
User: #9307
Since: Jun 2007
Being on a budget stinks! Maybe I should just save a little longer for an Onkyo 705.
Old 03-18-08, 12:14 AM   #6 (Link)
Alias: Zip
Loc: London, Ontario, Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
$300 is not enough to get even a good used receiver IMO. If your budget can't go up above $500-600 then Audyssey shouldn't be on your list of must haves. If you were looking at the Onkyo 605, that's not a bad receiver, but the 705 will also give you THX Select2 and an extra HDMI input which could come in handy. I'd wait and save an extra $200, you'll probably end up regretting it if you don't. That's part of the A/V addiction. I think www.accessories4less.com has the 705 refurbished for a good price.
Old 03-18-08, 07:22 AM   #7 (Link)
Alias: Dave
User: #9307
Since: Jun 2007
I think you are right. I think the 705 is realistic for me, just gonna take a while longer. Thanks
Old 03-19-08, 01:21 AM   #8 (Link)
Loc: Lower Alabama
Audiogon could be your friend... keep a check on it. At the moment an Onkyo 805 is there for $570.
Old 03-20-08, 09:54 PM   #9 (Link)
Alias: rich
Loc: minot ND
User: #2506
Since: Sep 2006
pietsch288 is offline
audyssey, Is one of the best investments I have made yet (denon 2808). I would at least get the onkyo 805.....well worth 600.00 shipped.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Similar Threads
Audyssey MultEQ? Alec.su General Discussion 3 03-13-08 01:40 PM
Thinking about Audyssey -- experiences? Anthony Home Theater Components 1 03-13-08 01:37 PM
SVS PB12-Plus/2 with Audyssey drdoan SVSound 1 03-11-08 09:50 AM
Filtering, Audyssey and what have you Sniderhouse REW Forum 2 03-04-08 02:28 PM
Audyssey Donald Home Theater Components 12 01-26-08 09:14 PM
Mach 5 Audio
