Go Back   Home Theater Shack > Home Theater | Audio and Video > Home Theater Components
Register
onkyo vs. marantz
Discuss onkyo vs. marantz in the Home Theater | Audio and Video forum; onkyo vs. marantz simply put the onkyo tx-nr905 or the marantz sr8002? i can get them both for about the same price, any ...
Old 04-08-08, 01:11 PM   #1 (Link)
Alias: Mcs
Loc: atl, ga
User: #19305
Since: Apr 2008
mcsnickel is offline
onkyo vs. marantz
i can get them both for about the same price, any other suggestions would be great too.
Old 04-08-08, 01:22 PM   #2 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Re: onkyo vs. marantz
Thats a tough choice, The one big thing is the Onkyo has more power per channel and has a Toroidal Power Supply. The Marantz also doesn't mention if it uses the HQV Raon chip for upscaling video where the 905 does.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears,
SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's
Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i towers, & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Old 04-08-08, 02:43 PM   #3 (Link)
Loc: Lower Alabama
I'd go 905 all the way.
Of course I gave you my thoughts on your other thread.
Old 04-08-08, 03:09 PM   #4 (Link)
Alias: Mcs
Loc: atl, ga
User: #19305
Since: Apr 2008
your opinion is always valued, even if you say it twice.
i'm purdy new at all this so every bit helps.
Old 04-09-08, 04:26 PM   #5 (Link)
Alias: Warren
Loc: Carlisle, MA
User: #17379
Since: Feb 2008
warren112 is offline
I looked at the Marantz SR8002 because it was heavily pushed by a dealer who higly recomended it. It is rated at 125 watts x 7 channels. It only weighs 33.1 pounds. Maximum power consumption is 780 watts. It does 480i to 480p upconversion. And its dimensions (whd) are 17 5/16" x 7 1/4" x 15 5/8". The dealer said it would sound really good with the Paradigm Studio speakers he was also selling.
The Onkyo TX-NR905 is rated at 140 watts x 7 channels. It weighs 54 pounds. Maximum power consumption is 9.8 amps (1176 watts). Its dimensions (whd) are 17 1/8" x 7 5/8" x 18 1/16". It is thus 21 pounds heavier, 2 11/16" deeper, and can use about 400 watts more AC power than the Marantz.
My understanding is that amplifiers are rated as stereo amplifiers only. So in most of the ratings for 7 channel amplifiers or receivers they are testing the amplifier with only 2 channels at a time. Thus an underpowered powersupply would not be noticed by any measurement in the ratings.
I suspect that a big heavy transformer will output more power than a smaller lighter transformer. And big larger conventional aluminum heatsinks will dissipate heat better than small light copper plated ones will.
I don't know the exact improvements that a toroidal transformer has over a more conventional cheaper transformer except that they are probably a little more power efficient and dissipate less heat. They are also much more expensive to manufacture. A necessary improvement for marketing with no real improvement for the customer.
I also believe that much of the maximum power that a unit will consume will be an indication of how much power could go to the speakers. Of course a class D switching amplifier will be more efficient than a non switching amplifier. However, at higher frequencies the class D will have more distortion. Subwoofers commonly have class D switching amplifiers but they only amplify low frequencies.
The dealer told me that the Integra DTR-7.8 receiver ($1200) that I was thinking of buying had a harsh and bright high end. This would make the Paradigm speakers sound harsh and bad. He said that the Marantz would make the speakers sound smooth and clear.
I ended up buying the Integra receiver and the Paradigm speakers from another dealer whose advice I trusted more. The sound is clear, flat, accurate, detailed, and there is plenty of power. Integra is a division of Onkyo. So I am sure that the sound from Onkyo TX-NR905 will also be excellent. And it has the HQV reon-VX which upscales to 1080p. The reon is worth $700 alone.
Old 04-09-08, 04:54 PM   #6 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
warren112 wrote: View Post
That alone is a big factor in going with an Onkyo, the build quality over the other receivers in this class is allot better.
My understanding is that amplifiers are rated as stereo amplifiers only. So in most of the ratings for 7 channel amplifiers or receivers they are testing the amplifier with only 2 channels at a time. Thus an underpowered power supply would not be noticed by any measurement in the ratings.
Yes this is usually the case.
A toroidal power supply is a huge advantage one being quality. The toroidal PS will give you cleaner power and is far more stable than a standerd power supply. All Onkyo receivers from the 805 and up use larger transformers in them and use a push pull amplification section giving superior sound quality.
That is a HUGE advantage over the Marantz.
Old 04-09-08, 07:07 PM   #7 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
tonyvdb wrote: View Post
I work on all brands of receivers. I cannot conclude the same about build quality. It would be more correct to describe the brands in this class as more similar than different. I have actually seen more build quality related issues with Onkyo than with others in its class (I consider those to be Yamaha, Denon, Marantz, and maybe HK). The Marantz has a longer warranty and we rarely see any problems with them at all. I'd say that in terms of reliability, Yamaha has likely been the best over many years, with the rest coming in behind, and Onkyo and HK taking up the rear of this group. I have never been impressed with anything about Onkyo as a company in terms of service and customer support. Marantz is marginally better in this respect, but Denon and Yamaha definitely beat them both in tech support and Yamaha customer relations is easily the best.
The primary advantage in a torroidal transformer is the efficiency. You can build a smaller, lighter device to get the same current. They are quieter as well, but the difference in how "clean" the power might be is marginal.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 04-10-08, 07:52 AM   #8 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
Torroidal transformers are self-shielding (they contain their magnetic fields better). This can reduce the amount of 60 Hz hum (when using a linear design power supply) induced in other circuits. For higher frequency switching power supplies, a torroidal transformer does a better job of containing EMI.
Harder to wind though.
Old 04-10-08, 10:35 AM   #9 (Link)
Alias: Warren
Loc: Carlisle, MA
User: #17379
Since: Feb 2008
Plitron is a company which makes toroidal transformers. This information is from their web page: http://www.plitron.com/advantages.asp
High efficiency of around 95% at load versus 80% for a standard transformer.
Size can be 50% smaller and lighter than conventional transformers.
Toroidal transformers are acoustically silent with very low mechanicl hum compared to conventional transformers.
The windings of the toroidal transformer act as magnetic shielding and they radiate 1/10 the magnetic field of conventional transformers.
The toroidal transformer uses 1/16 the power when no load is being driven.
All of these factors should be of greater importance when larger loads such as 1000 watts or more are required to drive the speaker output amplifiers.
Old 04-11-08, 09:45 AM   #10 (Link)
Alias: Zip
Loc: London, Ontario, Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
I'm pretty sure that both of these amps have toroidal transformers. Copper is a better conductor of heat than aluminum so a smaller copper heatsink would be more efficient than a larger aluminum one. Excess weight can also mean poor design or heavy use of older (heavier) components or materials.
I think it would boil down to features, which the Onkyo has more. You get network capabilities (streaming, internet radio), THX Ultra certification as opposed to THX Select, a little more wattage and much better video upconversion.
The 905 has the upper hand in pretty much every category, looking at the specs. You might want to audition them though to see which one sounds better in you opinion. On paper the 905 is a clear winner.
Old 04-11-08, 02:47 PM   #11 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
thxgoon is offline
MatrixDweller wrote: View Post
That would do it for me This says a lot about the power stage of the receiver.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
Yamaha RSXV1700 vs Onkyo 805 vs Onkyo 705 Buckster Home Theater Components 2 03-03-08 09:22 AM
Marantz 7002 and 8002 Wayde Home Theater Components 6 02-27-08 03:15 PM
marantz vc6001 vs denon dv2200 and marantz cc4300? enrique Home Theater Components 3 06-06-07 01:07 PM
Marantz lcaillo Manufacturer and Vendor Reference Information 0 05-13-07 08:26 AM
Marantz SR5200 Phil M Home Theater Components 4 05-14-06 10:36 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
