| Home Theater Components NAD T743 receiver sub channel clipping - need upgrade?Discuss NAD T743 receiver sub channel clipping - need upgrade? in the Home Theater | Audio and Video forum; NAD T743 receiver sub channel clipping - need upgrade? Hi everyone,
I am finding that my current NAD T743 receiver is clipping (with BFD LED) in the subwoofer channel ... |
| | #1 (Link) | |||
| NAD T743 receiver sub channel clipping - need upgrade? Hi everyone, I am finding that my current NAD T743 receiver is clipping (with BFD LED) in the subwoofer channel and so I have to set it at around -8 to -10db compared with the rest of the speaker channels which are set around 0db. I'm happy with the volume output of the mains when I crank the receiver up to 0db but I have to keep the overall gain down around -8db or the subwoofer starts clipping. So I need a new amp right? The receiver doesn't have enough oomph to deliver the sub channel, compared to the other channels? I was thinking the next size up NAD receiver? Cheers, Blue HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| | #4 (Link) | |||
| Re: NAD T743 receiver sub channel clipping - need upgrade? It's the same sub amp that I am using with the Peerless - a 240 watt plate amp, but in a few months I'll be upgrading to something like an EP2500. But in preparation for my new sub set-up (and two Mach 5 Audio IXL-18s), I'm thinking that I'll need a beefier amp to feed the new sub amp? I think I need a new amp because my amp is clipping - ie. the signal is clipping before it reaches the sub amp... which I presume will limit the output of the sub? At present I am able to prevent the sub from clipping by reducing the receiver output - but wouldn't it be better to be able to output a louder signal from the receiver that doesn't clip (similar to the output to the main speakers)? And so that's what makes me think I need a new amp (more headroom?)... Yes/no? HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| | #5 (Link) | |||
| | Re: NAD T743 receiver sub channel clipping - need upgrade? I'd say your Peerless sub/amp combination is simply maxed out. Since you will be getting a EP2500 soon, wait and see if that is the problem. No sense buying a new receiver if it's not the issue. We're all in this together! | |||
| | #7 (Link) | |||
| Re: NAD T743 receiver sub channel clipping - need upgrade? Well, I think my receiver is clipping because my BFD input LEDs are going into the red - when they are up there my sub starts to make poping noises (unless I turn my sub amp down) - so that means my receiver is clipping, right ?I see your point Mike re waiting to see how the new sub system performs... HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| | #8 (Link) | ||||
| | Re: NAD T743 receiver sub channel clipping - need upgrade? Quote:
Note that this isn’t probably going to fix the problem with your sub. You see, low frequency distortion has to get much higher before it’s audible than mid-to-upper frequency distortion. So even if the BFD is clipping, it probably wouldn’t be audible. Popping noises from the sub usually means the driver is bottoming out, or perhaps that the amp is clipping. Equalization places additional demands on the amp and driver, so going in you have enough reserve in headroom to handle it. Regards, Wayne | ||||
| | #9 (Link) | |||
| Re: NAD T743 receiver sub channel clipping - need upgrade? So I don't need a new receiver then? Everything will change when I get the new EP2500 / Mach 5 18"s - so wait until I run the new sub setup then, as Mike suggests? By the way, could that mean my mains are clipping if my sub channel is feeding too much to the sub? HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Software upgrade goes well on HK AVR-635 Receiver | Rambo4 | Home Theater Components | 2 | 02-28-08 06:05 AM |
| Center Channel upgrade. | F1 fan | DIY Speakers | 6 | 11-21-07 04:37 PM |
| NAD C272 Power amplifer | Doug Plumb | Classifieds - Audio Equipment | 0 | 11-04-07 04:15 PM |
| BFD and clipping | ejn327 | BFD Forum | 15 | 08-14-06 10:13 PM |
| From Rotel to NAD | NorwegianDawg | Home Theater Components | 15 | 05-23-06 07:24 AM |
