| Home Theater Components Audyssey MultEQ Discussion ThreadDiscuss Audyssey MultEQ Discussion Thread in the Home Theater | Audio and Video forum; Audyssey MultEQ Discussion Thread Hey Folks,
I bought a Denon AVR-888 a few months ago. Being too lazy to drag the PC into the ... |
| | #26 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread Hey Folks, I bought a Denon AVR-888 a few months ago. Being too lazy to drag the PC into the living room to do measurements yet again, I have not measured the effects of Audyssey MultEQ in my system, but I have formed an opinion. I like it. I like it a lot. I set my BFD to tame only the peaks in an average response of my listening positions. I added a house curve. It sounded good. Then I bypassed the BFD and let Audyssey MultEQ do its thing. It sounded decent, but maybe not as good as my BFD effort alone. Finally, I adjusted my BFD to tame the peaks, but left a flat response, and I let Audyssey do its thing on top of that. The combination of the two sounds terrific. I highly recommend this approach, if you have both a BFD and Audyssey. It seems that Audyssey MultEQ can use a little help. It's performance is fair, if you throw big room problems at it. But if you use REW and a BFD to deal with the big problems first, Audyssey MultEQ will put the finishing touches on it and the end result is beautiful. Standing on the shoulders of giants, so to speak. Has anyone else experienced this? We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | |||
| | #27 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread What would everyone's opinion be, BFD first and then let Audyssey do it's thing, or Audyssey first and then let BFD get what Audyssey doesn't? Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #28 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread Personally, if you use Audyssey, I wouldn't use the BFD on top of it. Basically, you are using processing on top of processing. If you have the ability to upgrade to Audyssey Pro, I would certainly do that since the increased resolution in the lower frequencies is much greater..thereby essentially eliminating the need for the BFD. If you have a seperates system, the Audyssey Sound EQ is the best way to go as it uses the full DSP. However, if you are targeting the lower frequencies only, SVS' new sub equlizing system utilizes Audyssey XT, and it uses much, if not all, the DSP, similar to the Sound EQ except it is just for the lower frequencies. Now, this is all dependent on seating and speaker placement. I always say that Audyssey helps you as much as you help it. If you find that you still peaks occurring in the lower frequencies, I would first look into placement of seating and sub. If that doesn't deal with it, look into conventional means, such as room treatments, to deal with the stragglers. | |||
| | #29 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread That is absolutely true. That's the concern that prompted me to try Audyssey MultEQ without the BFD. But the proof is in the pudding. Prudent EQ plus Audyssey sounds much better in my system. So if you already have a BFD and you get Audyssey, I recommend:
As Shawn says, if you want better results than Audyssey MultEQ can deliver, you can always step up to the more advanced versions of MultEQ XT and Pro. But that is an expensive proposition. The BFD is still the best $99 tweak I know of. We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | |||
| | #30 (Link) | |||||
| Re: Audyssey MultEQ Discussion Thread Quote:
I like the MIDI option with the FBQ2496, but also the multiple presets with the DSP1124P. BUT, because I'd be using it in conjunction with the Audyssey system are multiple presets even needed when using the BFD the way Ayreonaut is talking about? ![]() Isn't a proper microphone, external sound card, and REW necessary for BFD to work the way your talking about? All these things cost money. Wouldn't their cost be approaching what the Audyssey installer costs which I believe is $325. I'm trying to figure out the best way to get the best sound out of my room with the least amount of money spent, and with a moderately integrated solution. If possible. Last edited by intelonetwo; 05-30-08 at 12:01 PM. | |||||
| | #31 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread If you want the best system, I would go with Audyssey Pro. It depends on the installers price. Keep in mind that $150 goes stright to Audyssey and is not pocketed by the installer. Here are the pluses and minus' 1. Audyssey Pro uses a small microphone grazing area (smaller the ECM 8000). This is actually essential to get truely accurate results when analyzing the room. The smaller the grazing area the better. This is why the RS meter is absolutely useless through the entire audio spectrum. 2. The microphone used in the installation kit has a calibration file specifically for that microphone. This delivers accurate results for the program to analyze. 3. Audyssey XT uses microphones (supplied with unit) that are mass calibrated, and thus may be accurate or not entirely. You just don't know. 4. If you go the EMC8000 route, it will cost you some change for the equipment. Depending on the sound card you purchase. Decent ones cost around $150-200. The microphone is around $60, and the cable is around $25 or so...not including mic stand. Now you are looking at around $250-350 for a microphone setup. Plus the additional $99 for the feedback destroyer. Liberally, you've spent around $500, and probably won't get as good of a result as you would with Audyssey Pro with an experienced installer. In addition, you have to know what you are looking at when you take readings. Some of the peaks and nulls may be associated with room modes or SBIR, or even background noise. You need to able to recognize what is what to deal with the problem. I will tell you, as a person who uses Pro, the differences I heard are night and day between Audyssey Pro and Audyssey XT. Keep in mind, your room layout is absolutely essential to get the best results, and the use of conventional treaments may still be needed. This is where Audyssey Pro benefits as well, since it shows you the before and after graphs for each channel in the report you receive from your installer. An experienced Audyssey installer would also be ideally HAA certified, so he/she can recognize and hear additional steps that may be needed. Audyssey is not the magic bullet. It will NOT fix ALL problems. Proper uderstanding of room acoustics is still an essential part of an incredible listening experience. However, in my opinion, upgrading to Audyssey Pro is the best investment you can make at a reasonable price. After using it, I am a believer! | |||
| | #32 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread If you have Audyssey Pro capability, by all means, take full advantage of it. The installers kit costs $325, which leaves you to do the work yourself. I'm not sure what it costs to have it professionally done. (But I would rather have the equipment and tweak it myself to my heart's content.) We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | |||
| | #33 (Link) | ||||
Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #34 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread I think that is only true if you want to become an Audyssey certified installer. We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | |||
| | #35 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread Incorrect, You are allowed to purchase the equipment ONLY if there is not a certified installer near you. Only about 20 units have actually been sold to "customers". Audyssey will first check to see if there is an installer near you, if there is not, then you may be allowed to purchase the equipment. Yes, it does cost $325 plus an additional $150 for the licensing fee plus $25 to ship it. Therefore, it will cost you $500 if you are allowed to purchase it. If there is an installer near you, you will not be allowed to purchase the installer kit. However, it comes down to this as well. Do you want someone who knows what they are doing, or do you want to mess with upgrades to your DSP blindly. Again, Audyssey works best if you have a proper room setup, and a good installer will make the necessary changes to optimize the Audyssey setup. Sometimes, it is just worth paying a knowledgeable person to do it right the first time. | |||
| | #36 (Link) | ||||
| Re: Audyssey MultEQ Discussion Thread Wow, thanks for the info. I guess I got the wrong impression from the Audioholics review. Quote:
Every time you make a change to your audio chain you would be looking at paying that fee again. ![]() We are the Shack. Existence as you know it is over. We will add your biological and technological distinctiveness to our own. You will be mapped. Resistance is futile. | ||||
| | #37 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread Exactly my concern. I don't want to add a $300 Audyssey fee (is it $300) every time I get new speakers, hand wall treatments, or move my couch. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #38 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread Hey guys, That is why I suggested an audio pro to begin with. Once the room is properly setup, you shouldn't have to change anything. It isn't always the case, but constantly "upgrading" is often a sign that the room isn't in proper alignment. Audyssey should be used as the "finishing touch" on timing alignment and problem frequencies inherent to the room's dimensions. Speaker and seating placement should be used to deal with major modal problems from the beginning. Once you have the "best" arrangement your room design will allow, then you let Audyssey work the rest of the existing problems that you were unable to fix by design. This is basically the principle that ALL equalizers should be incorporated into a system. There are other things that could also be done to improve sound, but constantly upgrading speakers shouldn't be one of them unless the speakers were of poor design to begin with. That is another reason to hire a seasoned vet as they will be able to test your speakers for poor response prior to audyssey install. All you really should be doing is sitting back and enjoy the show! ![]() | |||
| | #40 (Link) | ||||
I think this assumes a lot. It assumes that you will have the time and money to do everything you want to do in the first place, and that your tastes/desires will never change. In my opinion, this happens about 1% of the time. The rest of us start with the speakers that we can afford, and something not completely over the top like a $1500 Integra Pre/Pro. We want the best sound we are currently capable of, so we pay for the Audyssey calibration. Then we get money for a front projection system which increases the screen size tremendously. Move couch, add second row, more Audyssey. Econ stimulus check comes in...new surround speakers, more Audyssey. Scratch off nets $5k...build a bar in the back, more Audyssey. Next job pays double next state over, have to move, more Audyssey. 7.1 material become a reality, add rear channels, more Audyssey. Go to conference, hear JBL Everests, sell kidney, more Audyssey. If you have the kind of money to do things right the first time, including hiring a consultant, then you don't need to worry. You can afford multiple Audyssey cals. For the rest of us, we'll be changing and upgrading as money permits, and money will go a lot further if we don't have to pay $300 each time for a cal. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #41 (Link) | ||||
Second, any subsequent work done by the installer due to changes in the system/room are based on a negotiation between you and the installer. Since the license has already been bought, the cost of this work should be less. Kal | ||||
| | #42 (Link) | ||||
| | #43 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread That's what I'm saying should be able to be done. Anyone know if Audyssey is on-board with this approach? Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #44 (Link) | ||||
The only way you could obtain an installer kit with license would be if you found a dealer of Audyssey receivers, etc, etc, and ordered the kit from them. They may or may not let you have the license along with the kit. Hoping to pull some money from you at a later point in life for setup of the system. | ||||
| | #45 (Link) | |||
| Re: Audyssey MultEQ Discussion Thread Well, I am sure you could possibly work that with the installer...however, I doubt it as that is lost revenue to the installer. The dealer/installer also has to be a dealer/installer for Audyssey. If you are that worried about "spending" the money each time you want to "upgrade" your system, then I suggest purchasing a Sencore SP295, multiplexer and digital audio generator in order to obtain the same results anytime you wish! |
