| Home Theater Components Yamaha RX-V361 QuestionDiscuss Yamaha RX-V361 Question in the Home Theater | Audio and Video forum; Yamaha RX-V361 Question I have the above mentioned reciever.
http://www.yamaha.com/yec/products/p...ETYP=ATTRIBUTE
I know its entry level...but I am very happy with it.
My question ... |
| | #1 (Link) | |||
| Yamaha RX-V361 Question I have the above mentioned reciever. http://www.yamaha.com/yec/products/p...ETYP=ATTRIBUTE I know its entry level...but I am very happy with it. My question is this...it says in the manual that you can adjust the reciver to either 8ohm or 6 ohm. If I adjust it to 6ohm could I safely run 4ohm speakers? I do crank it up some times...but not to often. | |||
| | #2 (Link) | |||
| Re: Yamaha RX-V361 Question Yes. Just make sure you have adequate ventilation to avoid overheating if you listen very loud. The Yammies have built in thermal protection device but just make sure you let it breath very well ![]() Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #3 (Link) | |||
| Re: Yamaha RX-V361 Question It sits in a stand. Its on the bottom shelf...and the dvd player is set up on the highest peg...about 5" above the reciever. And I always leave the front door open on the stand when in use just to be on the safe side. | |||
| | #4 (Link) | |||
| Re: Yamaha RX-V361 Question Well, give it a try... just put the receiver in 6 ohm configuration to limit voltage output. I think you will be fine. Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #5 (Link) | |||
| Re: Yamaha RX-V361 Question I just want to add two things: 1. If you can place a small fan that is not noisy inside or near the stand it will help you with the ventilation (that's what I'm doing to ventilate the rear of my TV and top of receiver) ![]() 2. I own the RX-V2700, searching online for reviews I found one on www.audioholics.com (maybe there's one for your model) ... they stated that even when using 4 ohm load, to leave it at 8 ohms instead of 6 ohms; their test showed that when used at 8 ohms the output was 272WPC instead of the 144WPC at 6 ohms (http://www.audioholics.com/reviews/r...-configuration) ... maybe is the same with your receiver ![]() | |||
| | #6 (Link) | |||
| Re: Yamaha RX-V361 Question The 2700 is a different machine with stronger power supply. It won't be the same with his receiver. I would only follow audioholics' advice only if more power is needed and that would be with caution specially with entry models. Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review Last edited by Blaser; 04-28-08 at 01:12 PM. Reason: typing mistake | |||
| | #7 (Link) | |||
| Re: Yamaha RX-V361 Question It will depend somewhat on the speakers, but generally these will be fine with most 4 ohm speakers if not pushed hard and if well ventilated. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #9 (Link) | ||||
| | Re: Yamaha RX-V361 Question Quote:
I have the earlier RX-V757...It's set at 8 ohms even though my centre is 4 ohms.. I just balance the LCR to all read 75dB.. Never had any problems, and I play it LOUD!! Home Theatre....The never ending story! Prof.. | ||||
| | #10 (Link) | ||||
![]() One day I connected my small fan to my receiver (for convenience), but suddenly after 20-25 minutes my receiver when into protective mode and turned off by itself ... I guess the receiver can overheat when powering a fan with that outlet ... I think I read that on the manual, also, you can't use it to power a subwoofer ![]() | ||||
| | #12 (Link) | ||||
I bet the 757 should be the same as the 2500 (but that's for stereo), as far as you are talking about a single (centre) speaker, it should be fine. Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #13 (Link) | |||
| Re: Yamaha RX-V361 Question You may actually get more power by leaving it on 8 ohms. IIRC, they just switch to a lower voltage tap on the transformer to limit the voltage swing on the outputs to keep the unit from driving too much current into the load and stressing the output stage or the transformer. You are more likely to have overheating and do damage if you don't switch it, but if you never push it and keep it cool you will likely have better dynamics. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| FS: Yamaha RX-V661 | E-A-G-L-E-S | Classifieds - Audio Equipment | 3 | 06-28-08 02:59 PM |
| Yamaha RX-V795a Question | 2akitas | Home Theater Components | 10 | 01-12-08 09:32 PM |
| question regarding yamaha recievers | wiles | Home Theater Components | 5 | 12-06-07 03:30 PM |
| Yamaha | lcaillo | Manufacturer and Vendor Reference Information | 0 | 04-30-07 07:57 AM |
| Oppo dv-970HD, Yamaha DVD-S-657, or Yamaha DVD-S1500 | nm2285 | Home Theater Components | 6 | 10-31-06 12:02 PM |
