different reciever's overall sound quality - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Discuss different reciever's overall sound quality in the Home Theater | Audio and Video forum; different reciever's overall sound quality Well i have been using an HK avr35 for watching movies in the theatre room until i can upgrade to ...
Old 05-09-08, 10:35 PM   #1 (Link)
Alias: Jodean
Loc: Tea SD
User: #15615
Since: Jan 2008
Jodean is offline
Well i have been using an HK avr35 for watching movies in the theatre room until i can upgrade to something else. Its measly 30w just barely cut it and i always seem to turn it up just a notch or two and then i start getting distorion. I need just a little more it seems.
Im using 2 jbl hrs 620 mains and a northride center and two small jbl surrounds. Each at 175w recommended power. I believe they are 200w or 250w max.
The other night i thought i would try my elcheapo jvc reciever from upstairs that boasts 100w per channel and had dts and all the goodies. I hooked it all up and it was definetly louder than the HK but man it was some crappy sound. Glass breaking was 4x louder than it should have been and voices could only be heard if it was cranked way up. I could only take about 10 minutes of this and had to switch back to the HK.
Now being that i currently cant upgrade($$$$).....i was just wondering where it goes from here.....
Whats the next step beyond the HK? How far does it go like this? I consider the two differences huge in quality. How many steps can i go till im happy? Are there 10 more steps above where I am now?
What would be the next step up over the old HK? Do i need to go with a preamp and several different amps?
Old 05-10-08, 05:06 AM   #2 (Link)
Alias: George
Loc: Nova Scotia
User: #15981
Since: Jan 2008
Rambo4 is offline
Re: different reciever's overall sound quality
If you like the sound of the HK, put aside a little money every month, until you can find a decent HK 635 on clearance or used. Its rated 80 watts/channel. Much better than what you have now for starving speakers. That's what I am using and I am quite happy. No distortion for as loud as I can stand it. Two years ago I picked up a new 635 for $550 off ebay. It can only go down from there. If you need HDMI switching, you'll have to buy the next generation though. 645..etc.
I would even venture a look at even a HK 345, will likely fit your needs if money is an issue.
Old 05-10-08, 07:46 AM   #3 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
What about buying a second hand receiver? If you don't need HD sound and HDMI switching/upscaling then you should be able to find a 1/2 year old unit that's relatively cheap.
When it comes to the receivers' overall sound quality, my favourites are the new Yamaha, Pioneer, Onkyo and Sony. I have to admit that I have never heard the new receivers from Sony but the other brands are very good. But other people will disagree because it's a matter of taste and matching with the rest of your system.
30W is really low in my opinion. As George pointed out, save some money every month and look for good bargains (new of used). You won't regret upgrading to a better receiver. Your neighbours might
Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100"
Old 05-10-08, 09:24 AM   #4 (Link)
Alias: Jodean
Loc: Tea SD
User: #15615
Since: Jan 2008
Jodean is offline
all right ive found an onkyo 801....hows that for a reciever?
also looking at the hk 645 cant find any 635 but i think i can get the onkyo cheaper and just use a hdmi switch, i dont really think it pays to buy a hdmi reciever if its limited to 1080i at the reciever
Old 05-10-08, 09:42 AM   #5 (Link)
Alias: Jodean
Loc: Tea SD
User: #15615
Since: Jan 2008
Jodean is offline
id be blowing my budget by double but what do you think about
Onkyo TX DS989
Old 05-10-08, 10:53 AM   #6 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Onkyo makes great receivers but stay with the newer line as getting older versions you loose all the newest must have features like HDMI 1.3, 1080p pass through and of course TruHD and DTS master audio.
Denon and Yamaha are also good but the Onkyo line is the one to beat particularly if you are looking for a receiver with all the best internal parts like top of the line BurrBrown DACs and a supper large power supply. The 805, 875 and 900 are hard to beat for the price and the sound quality is just fantastic.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears,
SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's
Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's, & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 05-10-08, 11:50 AM   #7 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
mdrake is offline
If you watch for online and in-stores sales you can get a GOOD deal on an Onkyo. I got an 805 from Fry's for 700.00 on sale.
Matt
Old 05-13-08, 08:44 AM   #8 (Link)
Alias: Jay
Loc: Western Wisconsin
jackfish's Avatar
User: #5100
Since: Dec 2006
jackfish is offline
I would look at a remanufactured Harman Kardon AVR 335-Z from HarmanAudio.com. Then over time you could add power amps for more power.
Old 05-13-08, 09:10 AM   #9 (Link)
Alias: Matt
User: #16260
Since: Jan 2008
mdrake is offline
The Absolute Sound magazine just gave a Golden Ear Award to the Onkyo 875 and 905. That should give you and idea of just how good the new Onkyo receivers are.
Old 05-13-08, 03:16 PM   #10 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Look for open box deals at the stores ... I was lucky to got a Yamaha RX-V2700 for $399.99 at Best Buy
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Similar Threads
Quest to improve sound quality... DVDIT Home Audio Speakers 8 02-09-08 11:18 AM
Picture Quality a1161979 Video Displays and Processors 0 11-24-07 02:06 AM
NEED HELP ...what i should buy for Best sound quality??? psvic Home Theater Components 4 10-09-07 06:12 PM
Reference Quality nova Movies | TV Shows | Hollywood 12 05-15-07 04:27 PM
DVD recorders quality / DivX playback quality, any experience on that??? Blaser General Discussion 3 11-07-06 11:44 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
