| Home Theater Components "Crank it up" - Cheap AVR's vs HeadroomDiscuss "Crank it up" - Cheap AVR's vs Headroom in the Home Theater | Audio and Video forum; "Crank it up" - Cheap AVR's vs Headroom Help me out here guys or did I whimp out? I'm extremely pleased with the clean sound of a ... |
| | #1 (Link) | |||
| Help me out here guys or did I whimp out? I'm extremely pleased with the clean sound of a recently purchased SVS 5.1 system (SBS-01/SCS-01/20-39 PCi) and so are my friends. I was asked to crank it up over my preferred listening SPL (80dB avg. - 90dB peak) and received boo's for declining. Hey, my low $ AVR is working for me until more money and HT savvy come along. Being an old stereo buff I tried to explain that lower cost amps don't have the headroom to push the envelope for a number of reasons. Jerry | |||
| | #2 (Link) | |||
| Re: "Crank it up" - Cheap AVR's vs Headroom Well, you certainly don't want to distort your amp and damage your speakers. Next time, just juice up your sub a little. That SVS has plenty of power and a little exaggerated bass is usually a crowd pleaser (if the crowd doesn't know better). Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #3 (Link) | |||
| Re: "Crank it up" - Cheap AVR's vs Headroom My experience is that if you turn it up until it sounds bad and back it off a bit you are likely fine. You won't likely damage good quality speakers nor amps with short periods of clipping. It is the folks that constantly push the limits that damage things. Just be aware of temperature on the amp and quality of sound from the speakers and you will be fine. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #4 (Link) | |||
| Thanks for your sound check advice. The peak SPL reading stated was for CD's. Request to turn up the volume pertained to CD playback. Did a follow up SPL sound check on DVD demo used for friends - chapter 3 of: Superman Returns - crystal ship crash landing - measured 105dB peak (volume on AVR set at 50, same setting as used for listening to CD's). DVD passage shakes everything in the house except your teeth. Replayed the same DVD passage using your sound check advice and started to hear sound break up at 110dB (AVR set at 60). So, do I have more headroom for CD playback? How much more? Jerry | |||
| | #5 (Link) | |||
| Re: "Crank it up" - Cheap AVR's vs Headroom The big bottleneck on lower end receivers is always the power supply if it is not big enough the amp simply wont be able to hit the dynamics at high db's causing distortion. There are several things to keep in mind: One the efficiency of the speakers, Two the Ohms that the speakers run at, And three the amps actual power rating is rarely what it says on the spec's. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 4 ch amp, 2-Mission 765 Mains, 4-762's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i towers, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Thanks to my wife who tolerates this ![]() | |||
| | #6 (Link) | |||
| Re: "Crank it up" - Cheap AVR's vs Headroom There is no easy formula. There are too many variables and program material varies too much. The bottom line is, if you hear distortion turn it down. It is rare that you will do damage on a few transients. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| Thread Tools | |
Similar Threads | ||||
| RHTI 31: AudioEngine AW1 Wireless Audio Adapter, Bad DRM, Nine Inch Nails "Ghosts", Elizabeth "The V | eugovector | Real HT Info Podcast | 1 | 04-15-08 04:03 PM |
| RHTI 30: Surround Sound: A Historical Perspective, "Enchanted", Gnarls Barkley "St. Elsewhere" | eugovector | Real HT Info Podcast | 2 | 04-11-08 10:34 PM |
| Episode 21 - $99 the end of the War?, "The Contract", They Might Be Giants "Factory" | eugovector | Real HT Info Podcast | 10 | 11-13-07 06:07 PM |
| My sub goes "tock" when it should go "thud" | BoomieMCT | DIY Subwoofers | 11 | 04-18-07 05:07 PM |
| Getting pro audio from "cheap" devices | quintosardo | General Discussion | 10 | 01-20-07 05:30 AM |
