Behringer CX2310 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Behringer CX2310
Discuss Behringer CX2310 in the Home Theater | Audio and Video forum; Behringer CX2310 I am interested in using this crossover from Behringer ... can someone help me understand how it works ... I've ...
Old 03-02-07, 08:31 PM   #1 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
Behringer CX2310
I am interested in using this crossover from Behringer ... can someone help me understand how it works ... I've read the online manual and ...
http://www.behringerdownload.de/CX23..._ENG_Rev_A.pdf
here's what I want it to do ...
feed it a fullrange signal, set crossover to somewhere in between 50-60
output to left and right speakers >crossover
output to left and right subwoofers <crossover
my question is: since this unit has a separate MONO subwoofer output ... will it cut out the low freqs. that I want going to my left and right subwoofers? can I disable it or simply not use it?
Old 03-03-07, 10:31 AM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Behringer CX2310
From Page 8 of the manual, referring to item 14, which is the subwoofer crossover frequency knob: “This control governs the crossover frequency between the low signal and the subwoofer signal.
So the answer is no, this crossover won’t do what you want. The subwoofer “Mute” switch will only mute the sub output – it won’t disable its function.
Probably just as well - I'm really leary of cheap pro gear in the main signal chain, and this thing doesn't even cost a hundred dollars. I briefly used a Carvin crossover in my system a number of years ago, which cost about $300, and it audibly colored the sound. If you really want a pro electronic crossover in your signal chain on the cheap, try a used Rane or Ashly. Better yet, an AudioControl PCA III, which is what I ultimately ended up with and have been using the past 10 years.
Old 03-03-07, 06:12 PM   #3 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
thanks Wayne. maybe I'll skip adding something to the signal chain.
Old 03-03-07, 06:54 PM   #4 (Link)
Loc: Lower Alabama
I think the CX2310 actually specs out pretty good. I'm going to me using it on my behemoth dual RL-p15 sub, if I end up needing to cross it over below 80Hz. I think if you use it for the low end, you'd be okay... otherwise, I might look at something else.
Old 03-03-07, 09:47 PM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Yup – I wouldn’t have a problem using it for the sub only. In fact, I recommended it to some else on this Forum right after I made my previous post.
Old 03-04-07, 08:38 AM   #6 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
are you guys familiar with the Hsu MBM12?
can I use the 2310 as a low filter for an extra subwoofer to act as an MBM?
Old 03-04-07, 06:02 PM   #7 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
As I understand it, the MBM is a “woofer” that operates between 50 and 150 Hz. If you’re asking if the 2310 will let you crossover between two subs, letting one operate the low bass and one the high bass, the answer is yes.
Old 03-04-07, 06:08 PM   #8 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
cool, might try this one out.
Old 03-06-07, 06:52 PM   #9 (Link)
Alias: norpus
Loc: Melbourne
norpus's Avatar
User: #3037
Since: Oct 2006
norpus is offline
Sonnie wrote: View Post
I agree in practise it is clean too.
A number of us are using it in our 2ch systems here and no one has complained of dirtying up/reducing dynamics on our systems - otherwise it wouldn't survive a day.
We recently had a bookshelf gtg at my place melding a number of bookshelf speakers to my dual18" IB via the 2310.
There were no complaints of sound colouration despite initial concerns by some (of having something foreign in the chain) prior to the event. There were 17 participants in this get together and the CX2310 blended the IB in absolutely seamlessly - even the tiny Rogers LS3/5a (which has about 1/5th the cabinet volume of the IB Vd ) which sounded good for such a tiny thing
Cheers
Norpus
Old 03-06-07, 07:28 PM   #10 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
norpus wrote: View Post
Are any of you using it full-range? Can’t tell for sure from your post.
Old 03-06-07, 07:59 PM   #11 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
A while ago on another forum I mentioned my doubts to someone about the audible results one could expect with the CX2310 and was surprised at their response.Something this cheap certainly had to have high noise levels and would obscure fine musical details.But they were using it in a very hi end system and it aquitted itself very well.They claimed it was the sonic equal of a much more expensive unit that used higher quality parts.So it may be worth a try.
Old 03-08-07, 05:35 PM   #12 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
wow, thanks for the additional inputs guys. makes me want to try anyway.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Similar Threads
Which Behringer unit? Peter De Smidt BFD Forum 7 12-26-06 09:29 AM
Behringer virtualiser pro drf General Discussion 11 11-21-06 05:27 AM
Behringer UB802 response brucek SPL Meters | Mic's | Calibration | Sound Cards 6 11-20-06 07:02 AM
FS: Behringer FBQ2496 Josuah Classifieds - Equalization and Calibration Equipment 1 11-13-06 03:35 PM
Help w/ Behringer EP2500 -- DOA??? Otto Home Theater Components 34 08-20-06 09:28 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190
