7.1 ?'s - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
7.1 ?'s
Discuss 7.1 ?'s in the Home Theater | Audio and Video forum; 7.1 ?'s Am I nuts for putting in a 7.1 system? I have never had one before. Will it take a 5.1 ...
Old 03-06-07, 01:11 PM   #1 (Link)
Alias: jeb
Loc: Iowa
User: #6247
tango is offline
7.1 ?'s
Am I nuts for putting in a 7.1 system? I have never had one before. Will it take a 5.1 DD soundtrack and put sound through the sides and rears? Or is it only used for 7.1 soundtrack and DTS_ES etc.? Excuse my ignorance on the subject.
Old 03-06-07, 02:31 PM   #2 (Link)
Moderator Emeritus
Alias: Naut
Loc: Richmond, VA
Ayreonaut's Avatar
User: #203
Ayreonaut is offline
Re: 7.1 ?'s
No, you are not nuts. Yes, with Pro-Logic IIx the receiver can remix everything between 2.0 and 6.1 into 7.1. I love having four surrounds, I find it much more enveloping than two.
We are the Shack. Existence as you know it is over.
We will add your biological and technological distinctiveness to our own.
You will be mapped. Resistance is futile.
Old 03-06-07, 05:54 PM   #3 (Link)
Alias: edd
User: #2120
Since: Aug 2006
eddthompson is offline
Re: 7.1 ?'s
Ive not found it added anything, so i went back to 5.1, but this was in a small room, in a larger room, or a dedicated room, id run 7.1.
edd
Old 03-28-07, 09:27 PM   #4 (Link)
Alias: chad
User: #7756
Since: Mar 2007
cburbs is offline
Re: 7.1 ?'s
From my experience if you have the right layout 7.1 is nice. Like mentioned you can take most signals and apply PLIIx for a nice 7.1 setup. I also really enjoyed using 7 channel stereo for sporting events.
Take a look here and look at some of the layouts.
http://www.dolby.com/consumer/home_e...oomlayout.html
Also if you have any sketches of your room or pics we might be able to make some suggestions.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
