| Home Theater Components Denon AVR-2807 ReceiverDiscuss Denon AVR-2807 Receiver in the Home Theater | Audio and Video forum; Denon AVR-2807 Receiver As some of you are aware, I sold my Yamaha V1700 and picked up this Denon 2807.
You can see ... |
| | #1 (Link) | |||
| | Denon AVR-2807 Receiver As some of you are aware, I sold my Yamaha V1700 and picked up this Denon 2807. ![]() You can see features and specs at the Denon website... AVR-2807 I'll be posting my experiences with it over the next few days/weeks. Initially, for the first time ever... Auto Setup got my speaker sizes right (all set to Small), the distances were on the money as well, but it failed on the crossover for the surrounds trying to set them at 40Hz. It also didn't set my sub level quite high enough for my liking... actually is was way too low. I ran Audyssey and it does sound different switching between No EQ and Audyssey. I suppose it is better with it engaged, but it's hard for me to tell for sure. I'm thinking it probably sounds more like it's supposed to, but my hearing is not the greatest for critical listening. I could not tell that Audyssey effected the bass region... it did not appear to, but I want to do some REW measurements to see exactly what it does to the entire frequency range. I'll post some graphs later. I posted in another thread (along with graphs) that my 3806 did in fact cut my bass response, which I was not fond of... therefore I previously did not use it. I listened to nearly all of the Eagles HD DVD and I was satisfied with the initial sound of this unit. I used both the 3805 and 3806 as pre-pros with a separate amp, so I never really heard the amp section on those. The 2807 is more neutral than the Yamaha V1700. I actually prefer the 1700's laid back sound over the 2807, but it's not drastic and again I believe I can be satisfied, especially with movies, which is what I watch most. It's just much easier for me to compare the sound of the units using music... taking into considering once again my very poor critical hearing abilities. | |||
| | #3 (Link) | |||
| | Re: Denon AVR-2807 Receiver Trust me... it's quite a difference... Notice that I copied the Denon volume over next to the Yamaha's volume. That is pretty significant IMO! I can hardly read the "-40" on the Yammie... while the Denny is very readable. Agree? ![]() The Denon numbers also show up in the display area highlighted when changing volume... ![]() I like the Yamaha sound best of all the setups. The Denon and the AudioControl/Cinenova setup both sound pretty neutral to me. Of course if you got some critical listeners in here to compare them all, they'd probably select the AudioControl/Cinenova setup. ![]() I have to admit too... the Yammie is a better cosmetically looking receiver than the Denny... but.... I won't be watching the receivers, I'll be watching the screen. | |||
| | #4 (Link) | |||
| Re: Denon AVR-2807 Receiver Sonny, congrats on your new receiver (same as mine). I should have said before that even tho I am using the Audessey MultiEQ only (no BFD this time) I did increase the volume on my sub to about 3db higher than reference, but, left all else the same. Have fun. So far, I really like the sound over my previous Yammie HTR-5990. Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) Denon AVR-2807 Receiver w/AudysseyXT LG DVD Recorder w/HDMI Direct TV DVR HD Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | |||
| | #10 (Link) | |||
| | Re: Denon AVR-2807 Receiver They both look pretty sharp to me, although I think I would give Yamaha the nod there. I’ve become rather fond of the orange display. The Denon has too many exposed buttons. These days with everything remote-controlled, there’s really no reason not to put everything behind a flip-down panel. Plus Denon really overdoes it with the billboards across the front of the display (DTS, HDMI, etc.). I hate that! Why can’t they just put that stuff somewhere on the back? Who needs it staring you in the face every time you look at it? What, are you going to forget that it has XM radio or a multi-zone function?? I typically cover the billboards over with carefully cut and strategically placed pieces of black electrical tape. Practically invisible in lower lighting. Regards, Wayne | |||
| | #11 (Link) | |||
| | Re: Denon AVR-2807 Receiver I can't see any of that stuff anyway in my HT room.... the only thing I see is what's lit up and that's only if I happen to look at it. And no, the bar graph seemed silly to me since it had no numbers and you could press volume up or down for 3-4 seconds before it moved the bar. I'm not even sure what the function of the bar served. ![]() | |||
| | #12 (Link) | |||||
| Re: Denon AVR-2807 Receiver Quote:
This appears to be a common theme with these post EQ programs. They figure everybody has a ****** 8-12" sub and start rolling off the lows too early. If someone really needs to apply post EQ, they are better off using RoomEQ to take a snapshot of their system's reproduction from 20hz-20khz and then manually going in and making some discrete adjustments. | |||||
| | #13 (Link) | |||
| | Re: Denon AVR-2807 Receiver Yeah... I've never used Audyssey myself because of what it does to the bass. I did try cutting off my behemoth and turning the Plus/2 subs volume down real low, but it still did a really funky number on the low end response. I never could figure out what it was trying to do up top, but I'll wait until I get the Boston's and my ECM8000 back before I make a final judgment on it. If there is no work around to keep it from adjusting the bass, then I definitely ain't gonna be using it. As far as the manual EQ... those don't do nothing like what they are supposed to do. I was getting some weird readings on those as well. Again, I'll wait on my ECM for final judgment of the upper range. | |||
| | #14 (Link) | |||
| Re: Denon AVR-2807 Receiver Congrats Sonnie. I have the same amp. I do use Audyssey and find it's worth the effort setting it up properly. Way better imaging and more cohesive sound from the surrounds and fronts. As far the bass, it does seem to cut 40hz and below considerably. I found the best way is to let Audyssey do it's thing first and then measure the bass with REQ and going in and pump up those frequencies again with a BFD. This gives you the advantage of the Audssey especially in the mid/high frequencies where it seems to clean up the sound quite abit and still allows you to get the bass sounding right. | |||
| | #16 (Link) | ||||
Would you mind showing the LF Waterfall plots before and after Audyssey? Thanks. Nick | ||||
| | #17 (Link) | |||
| | Re: Denon AVR-2807 Receiver I don't think I saved the .mdat file on this, so I'll probably have to try it again, which I want to do anyway since I've got the Boston Acoustics installed. However, it may be a while before I can get to it. I'm loaded down for the next couple of nights before we go on a trip. | |||
