Parasound Halo C1 or C2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Discuss Parasound Halo C1 or C2 in the Home Theater | Audio and Video forum; Parasound Halo C1 or C2 Does anyone have any experience with these pre/pro's. I like the idea of being able to add additional channels to ...
Old 03-28-07, 01:24 PM   #1 (Link)
Alias: AC
Loc: WICHITA, KS
ACGREEN's Avatar
User: #6917
ACGREEN is offline
Does anyone have any experience with these pre/pro's. I like the idea of being able to add additional channels to help fill your room and mix them based on user settings.
Old 03-29-07, 11:42 PM   #2 (Link)
Alias: Steve
Loc: Shoreview Minnesota
User: #5693
Since: Jan 2007
ccdoggy is offline
Re: Parasound Halo C1 or C2
well my boss has and uses the Halo C2 connected to the Halo A51. pretty amazing setup for movies especially. not to say that its not amazing for audio, its just that his Halcro seperates are a bit better.
Personally i havent gotten much chance to mess with it as he usually only has the halcro stuff hooked up. but its a pretty nice preamp to play with and can output some awesome sound.
Old 04-02-07, 08:21 AM   #3 (Link)
Alias: Joe
Loc: CT
User: #6402
blownrx7 is offline
I have the Parasound C1. The only differences between the C1 and the C2 is the nice to look at but not really needed display and one additional component video input.
I got the C1 as a package deal with an A51 amp at a "could not refuse" price
The C1/C2 has excellent sound and versatility. I only use the additional channels to drive some bass shakers (after spending thousands for equipment - this $100 item gets the most kudos...go figure) but I do have a 7.2 system (two subs).
Until someone builds in video processing (like the Anthem AVM-50 or Statement D2) at a REASONABLE price , this is a keeper!
fyi, I had a Proceed PAV and an Anthem AVM-20 prior to getting the C1.
Old 04-04-07, 12:41 PM   #4 (Link)
Alias: Bob
Loc: Pittsburgh, PA
khellandros66's Avatar
User: #962
Since: Jun 2006
khellandros66 is offline
Save up them bones for the Anthem Statement D2, its amazing i saw one locally and the VPX video is incredible, even SD-DVD was nothing short of fantastic. The lack of HDMI on the Halo's is quite a pickle for todays new gear... even DVI seems folly.
If you are ready to drop the coin grab the most you can.
~Bobby
Old 04-04-07, 05:35 PM   #5 (Link)
New Member
Alias: tlqualman
Loc: oklahoma
User: #7976
Since: Apr 2007
tlqualman is offline
I have the C1 and love the sound quality, my unit is dead quiet. I would have saved up for the Anthem D2 Statment but found a steal on a demo C1 at half the Anthem's price and decided I could live without the video processing. I also have the Halo amps and they kick ****. Also someone mentioned that the only difference in the C1 and C2 was the display screen on the C1 and an extra component input, thats true. But the power supplies are also different between the C1 and C2 with the C1 having the larger, I don't know how much of the extra supply goes for the video display. If you can do without the video processing the C1/2 are great processors.
Old 04-05-07, 05:59 PM   #6 (Link)
Alias: Bob
Loc: Pittsburgh, PA
User: #962
Since: Jun 2006
TBH A C1 + DVDO VP50 would be sweet but with HD-DVd/Blu-Ray in order to do the 7.5 (if you setup the L/R Axis) you have to optical unless I am mistaken and its allowed on the 5.1in.
~Bobby
Old 09-04-07, 06:05 PM   #7 (Link)
Alias: Konky
Loc: Canton, GA USA
conchyjoe7's Avatar
User: #11137
Since: Aug 2007
conchyjoe7 is offline
Hi guys...I'm the low rung on the ladder here, but I love my Parasound New Classic 7100. I have it set up (see my profile) as a 2.0, 2.2 or 7.2 channel setup, and while I'm sure something could make me happier (I'm sure the Anthem Statement would); overall I'm just smiling away! Of course it helps to have decent ancilliary equipment as well.
Cheers...
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Similar Threads
xBox Halo? xBox networking? Sonnie Computers | Games | HTPC | Digital Devices 6 12-12-06 11:10 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
