| Home Theater Components Onkyo TX-SR 605 Owners?Discuss Onkyo TX-SR 605 Owners? in the Home Theater | Audio and Video forum; Onkyo TX-SR 605 Owners? Did anyone pick up the Onkyo TX-SR 605 yet? How do you like it? Any issues with it? I hope ... |
| | #2 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? This looks like this might be my next receiver. I hope somebody chimes in. Im going to be comming from a Onkyo TX-SR600 which is still a great receiver and going strong. Well changed my mind went with the 705 model. Last edited by Jerm357; 03-01-08 at 08:57 PM. | |||
| | #5 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? I have one that I've used lightly. So far, no issues, although I'm having a little trouble with upconversion from 480 to 720 using component and the hidden menu. I've heard other people say that it runs hot. Mine runs a little hot, but not terrible. Setup is very easy (if you're familiar with AVRs). I have a pretty simple setup, though; everything is through HDMI, with the exception of the one component cable. | |||
| | #6 (Link) | ||||
| Re: Onkyo TX-SR 605 Owners? Quote:
![]() mech Got questions? Start a thread. | ||||
| | #7 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? Picture quality? 480 to 720, no, not that I can see, but I'm not absolutely positive I have it set up right. 1080 to 1080, definitely not. The reason I say I'm not positive I have it set up right is because my setup is as follows: In to Direct TV HD-DVR, which is set at 1080i. Out to Onkyo 605 via HDMI Then out to TV (Sony KDS XBR1) via HDMI. So the HD-DVR might already be doing the upconversion. So, no improvement in picture quality, but it's not worse, either. HD is already exceptional. SD is, in all honesty, not very good. But I didn't buy the Onkyo for its upconversion capability, anyway. | |||
| | #8 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? Interesting point Davetroy. I didn't think that the HR20 upconverted anything. I figured that if it was a SD channel, it was 480i. I'll have to go look into that at dbstalk. Out of curiousity do you download the "cutting edge" software for your HR20 when they're available? mech mech Got questions? Start a thread. | |||
| | #9 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? I guess it depends upon how you have native set up. I have mine on so that my projector is doing the conversion. There's talk that native off (HR20 upconversion) is quicker now and a better picture. I'll have try it out. mech Got questions? Start a thread. | |||
| | #10 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? It is unlikely that you will find any improvement by having the receiver process your video or by doing upconversion in the STB. Think about what is happening. In order to upconvert video, the process is to resample and add digital filters to prevent aliasing and quantization artifacts. You also have to do interlace/deinterlace processing on some of the video. Your display already does this to get whatever comes in to its native resolution. So now add doing it again in the receiver and/or the STB with chipsets that are likely to be less expensive. The results are rarely an improvement. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #11 (Link) | ||||
I didn't think the HR20 upconverted anything, either. It sure doesn't look like it does. I was hoping the Onkyo would do the upconverting, but if it is, I definitely don't see a difference. As I said, I might be doing something wrong. "Cutting edge" software for the HR20? I didn't know there was such a thing. | ||||
| | #12 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? If anyone is interested, there is a site selling this receiver for $399 in black and $375 in silver, but only for the next 7 hours. They are running some 20% off promotion. I don't want to advertise for them, so PM me for a link. | |||
| | #13 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? I was able to compare the Onkyo 605 to a Panasonic XR-57. I am liking the Onkyo more and more. It's a bit warmer and quite clean as well. Although I still think the XR-57 dominates in the bang-for-buck factor. | |||
| | #14 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? I have the 605. Over at avsforum in the New 605 owners thread mrgibbles did a listing of the modes for the 605 video conversion. At this point it looks like any 480 conversion will output at 720 with a double set of black bars. If it is inputed at 720 it is processed and outputs 720, if it is inputted at 1080 it is processed and outputs at 720. If the processing on the 605 is bypassed and you use the same inputs as you do outputs (hdmi/component) you will just pass-through the signal 1080 in - 1080 out untouched. 720 in - 720 out and 480 in - 480 out. It's a disappointment since I was hoping it would be a benifit for 480. The back bars with the processing make it unusable in my opinion. I have my 605 set up in my family room at the moment. I have it planned for my bedroom but this is my first real receiver and I am curious about the freq response in my family room. My initial impression is that its pretty horrendous. No fault of the 605. I am just soaking up the knowledge of the folks here and having fun with it. | |||
| | #17 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? Gotta tell you, I've been using Onkyo equipment for the last eight years and it's always been top notch. I'd put it up there with Denon stuff at twice the price. Currently I've got the Onkyo 797 THX certified receiver which is awesome, and heavy too. Unfortunately it's seven years old and only has 2 component inputs - don't even think about hdmi connections. And it doesn't cross convert - so if you bring in S-Video, it won't go out component. All this was fine until I got my HDTV. Now it's time for a new receiver. The 605 was on the short list, but after reading the avs forums on it, I'm gonna hold out for the 805. It's a little more pricey, but it is THX certified and uses the Faroudja DCDi chipset, which the 605 does not. And the Faroudja chip is the cream of the crop for upscaling. My .02 Mark Santora | |||
| | #18 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? You might want to check out the 875 and 905 as they are using Silicon Optix Reon chip. It is considered by most videophiles to out perform Faroudja currenlty. I have the 905 and I am throughly impressed. | |||
| | #19 (Link) | |||
| Re: Onkyo TX-SR 605 Owners? On the 605, is it possible to turn off the video processing for various inputs? I'm considering it for HDMI switching and upconversion from component, but I don't want it reprocessing stuff that doesn't need it. Thanks. | |||
| | #20 (Link) | ||||
Mark Santora | ||||
