Equalizer & Accurian 5.1 Home Theater Receiver - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss Equalizer & Accurian 5.1 Home Theater Receiver in the Home Theater | Audio and Video forum; Equalizer & Accurian 5.1 Home Theater Receiver I've got an Accurian 5.1 channel surround Stereo Receiver and a Kenwood 1070KE Stereo Graphic Equalizer. The whole problem is, ...
Old 06-15-07, 08:06 PM   #1 (Link)
New Member
Alias: James L. Parmenter
Loc: Alamogordo, NM 88310
User: #8891
Since: May 2007
jimlp1 is offline
I've got an Accurian 5.1 channel surround Stereo Receiver and a Kenwood 1070KE Stereo Graphic Equalizer. The whole problem is, the Accurian 5.1 receiver does not have a "Tape Monitor" button/switch so any effects the Equalizer creates for room acoustics, it never reaches the loudspeakers. Is there any way known to man, around this, other than getting a two channel Stereo receiver. Also I just got a vintage pair of JBL L56 speaker/montiors at the pawn shop. They wanted $80.00, and I was willing to pay it, but I noticed a couple problems. One of the pair didnt work and there was a rattle inside when we brought it up to the counter. The same one, part of the Woofer Surround (Butyle Rubber) had a slit in it. I got a discount for the slit surround and then got the pair for $37.00 when he noticed one of the pair didnt work, at all. I got home, cleaned themm up, removed the 10" Woofer and found a .068uf =/-20% capacitor blown apart. The rattle was one of the coils broke away from the Cross-over PC board. Anyway, they're all fixed and sound great!
Old 06-15-07, 10:35 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Equalizer & Accurian 5.1 Home Theater Receiver
James,
Even if there was a tape monitor loop to connect the equalizer, it wouldn’t do you much good. With the tape monitor engaged, you only get Dolby Pro-Logic, not Dolby Digital, since the tape loop is an analog signal path. So, you’d be missing out on the discrete 5.1 audio for DVD and HD broadcasts.
The only “work-around” is if your receiver has both pre-out and main-in jacks. If not, you have to use an outboard amp and connect the EQ between it and the receiver’s pre-out jacks.
Congrats on the JBL fix. You can do a “band aid” on the woofer with the split surround, too. Just spread a thin layer of silicone across it, but on the back side. Once it sets up, it should hold everything together and be practically invisible from the front.
Old 06-15-07, 11:11 PM   #3 (Link)
New Member
User: #8891
Since: May 2007
jimlp1 is offline
Thanks for the reply Wayne, yeah I've already put the band-aid on the woofer, and they sound great. As for the Receiver, I'll give it once over tomorrow and see what its got for pre-outs, etc. Thanks again man, appreciate it!
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
My little Home Theater JRace Home Theater Equipment 2 06-06-07 04:42 PM
Yamaha Bows New One-Box Surround System (YSP-1100) and Home Theater Receiver (RX-V2700) Chris Boylan Home Theater, Audio and Video News 0 10-01-06 12:25 AM
Secrets of Home Theater Onix Rocket R-DES Equalizer review geekwithfamily BFD Forum 1 09-14-06 02:57 PM
Pre/pro + Amp or all-in-on receiver? haver Home Theater Components 21 07-17-06 11:30 AM
Home Theater vs Movie Theater Roger Home Theater, Audio and Video News 0 05-09-06 07:45 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
