Pioneer 74TXVi: MCACC is ignoring 63hz - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Discuss Pioneer 74TXVi: MCACC is ignoring 63hz in the Home Theater | Audio and Video forum; Pioneer 74TXVi: MCACC is ignoring 63hz I just got my new Pioneer Elite 74txvi 2 days ago, and set it up as 5.1 system. Despite setting ...
Old 05-10-06, 01:32 PM   #1 (Link)
Alias: Quant
User: #123
Quant is offline
I just got my new Pioneer Elite 74txvi 2 days ago, and set it up as 5.1 system. Despite setting a crossover at 50 hz, the Advanced MCACC is ignoring the 63 hz setting.
Here is what I did. I did a full Auto MCACC setup. As expected, all my speakers were set to Large. I went to Manual SP Setup (option 5, I believe), changed all the speakers to small, set the X.Over to 50 hz, went back to Auto MCACC, chose the option to "All (keep SPsetting)" and re-ran everthying. At the end of MCACC, when I check the final settings, the speakers are small, the Xover is 50 hz, and in the Acoustic Cal EQ, the 63 hz setting is blank!
What am I doing wrong?
Old 05-10-06, 01:36 PM   #2 (Link)
Alias: Jeff
Loc: Puyallup, WA
Jeff Aguilar's Avatar
User: #5
Jeff Aguilar is offline
Re: Pioneer 74TXVi: MCACC is ignoring 63hz
Quant,
What speakers are you using that your crossover is set at 50 Hertz? If your speakers are set to small, I would think that your crossover should be at 100 hz. I would use 80 hertz if I had larger speakers.
Try that in your setup and see if it works.
Jeff Aguilar
I'm just an old thug huggin redneck realtor ready to sell you a shack!
Old 05-11-06, 10:43 AM   #3 (Link)
Alias: Quant
User: #123
Quant is offline
Hi Jeff,
I think you might be mistaken regarding the crossover setting. There is no requirement that small speakers should have a crossover at 100. In fact, THX recommends 80 hz, but I think thx tries to use a one-size-fits-all approach. The xover setting should be whatever you feel your front speakers go down to in your room. At low frequencies, the in-room speaker frequency response is many decibals higher than the printed anechoic lab response, because of room acoustics and wall reinforcements.
My Totem bookshelfs go down to 50, and I want to try different settings to see if xover at 50 hz gives me better sound versus 80 hz or 100 hz.
Specific to Pioneer 74, I have a feeling that maybe the 63hz equalization is only used if the speakers are large and go down substantially below 50. I'm going to try setting my speakers to large, setting the xover to 50, and then re-run MCACC, keeping the speaker (and xover) setting. I'll report back tomorrow.
Old 05-11-06, 02:01 PM   #4 (Link)
Alias: Jeff
Loc: Puyallup, WA
User: #5
Quant,
I think you and I agree as to what may be going on with your pioneer. I know you can set your crossover to whatever you think sounds best. That is why I asked you what kind of speakers you were running. I guess it all depends on the system, sub, and speakers you are running. Even when I was running my Martin Logan speakers, I crossed over my fronts at 100hz and let my dual svs subs handle everything below that. It worked well for me.
Let us know what you find out when you play with more settings.
Jeff
Old 05-12-06, 01:39 PM   #5 (Link)
Alias: Royce
Loc: Victorville, CA
User: #49
RollsRoyce is offline
Nothing. This simply means that MCACC made no adjustments at 63 Hz. IIRC, MCACC uses response at 1 KHz as its reference and adjusts all the other frequencies to match. If your speakers are producing the same level at 63 Hz as at 1 KHz within MCACC's sampling time window, it won't make any changes. Your receiver's basic Auto MCACC setup uses a different time window than the Auto Pro setup, and if your receiver has Professional Advanced, you can manually specify the time window.
BTW, one oft-quoted recommendation for sub crossover setting is to set it at one octave above the -3 dB point of your speakers' low end response. This would be 100 Hz in your case. Jeff was giving you some good advice!
---Royce---
"I never drink...wine..." Bela Lugosi, DRACULA, 1931
Old 05-12-06, 03:31 PM   #6 (Link)
Alias: Quant
User: #123
Quant is offline
RollsRoyce wrote:
Nothing. This simply means that MCACC made no adjustments at 63 Hz. !IIRC, MCACC uses response at 1 KHz as its reference and adjusts all the other frequencies to match. If your speakers are producing the same level at 63 Hz as at 1 KHz within MCACC's sampling time window, it won't make any changes.
The receiver displays 0 for those bands that it does not make any adjustment for. For 63 hz, it is displaying a " " or a blank, which makes me think it is omitting that band completely. I am getting a blank for all the five channels, which again makes me think its omitting - what are the chances I have perfect response at 63 hz for all the five speakers in my room!
I didn't think Jeff wasn't giving good advice, I only disagreed with his explaination, which might have been a mis-communication.
Your point of setting it a full octave higher seems interesting - I would normally put a crossover at the point where I just begin to see the rolloff.
Old 05-12-06, 04:15 PM   #7 (Link)
Alias: Royce
User: #49
Smile Re: Pioneer 74TXVi: MCACC is ignoring 63hz
Mine shows dashes for no adjustment--and 63 Hz is not being adjusted for any of my speakers with my current settings, which is all speakers SMALL, 100 Hz crossover, and MCACC at Auto Pro. In the past, I've manually changed the MCACC Pro time measurement window up and down, but like the sound and the REW/ETF frequency response plots from the Auto Pro setup better. If you can futz around with the time window on your 74txi, you'll eventually see the 63 Hz band being adjusted.
Remember that MCACC only samples the system's frequency response at a very specific time before bass response really starts to build due to room gain. In reviewing the room reverb charts that MCACC stores for my system, it appears to be capturing the data when the 1 KHz and 63 Hz amplitudes are the same, for all 6 of my speakers!
---Royce---
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195
