Pioneer Elite VSX-82TXS automatic MCACC calibration issues - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Discuss Pioneer Elite VSX-82TXS automatic MCACC calibration issues in the Home Theater | Audio and Video forum; Pioneer Elite VSX-82TXS automatic MCACC calibration issues After repeated automatic calibrations of the MCACC system so ensure the process was done right, the playback volume of a ...
Old 08-18-07, 10:03 PM   #1 (Link)
Alias: The sound guy
User: #10826
Since: Aug 2007
The sound guy is offline
After repeated automatic calibrations of the MCACC system so ensure the process was done right, the playback volume of a DVD is SIGNIFICANTLY LOWER than the playback volume with the MCACC turned off. In addition, the tonal quality with the system isn't as crisp and brillant as without MCACC.
Has anyone experienced the same results (repeated)? If that isn't the case, can anyone suggest what I might be doing wrong and not realizng it? Yes, I even set the microphone on a tripod exactly where I would be sitting with the mic at ear height.
Thanks
Old 08-19-07, 09:05 PM   #2 (Link)
Alias: gs
User: #159
gsmollin is offline
Re: Pioneer Elite VSX-82TXS automatic MCACC calibration issues
It is probably normal to lose some volume, because the filters are set to cut. Loss of brilliance is usually a result of the room curve being used. It is common to cut high frequencies 6 dB/octave with a cinema curve above midrange frequencies. This is done to match the expected response of the commercial theater speakers, which roll off significantly at high frequencies.
One important thing to remember is that you must have a quiet room. Do the equalization at ~2 AM to keep traffic noise minimized. Turn off projector, computer, HVAC, refrigerators, freezers, fluorescent lamp ballasts, aquarium pumps, everything! Finally, just before you run the equaliztion, shut off any CRT monitor you may be using for the OSD. The horizontal sweep will trash the high frequency response!
Afterwards, I think you can examine the filter settings. Is it reasonable? I'm not sure if you can adjust them manually. That feature may vary by model number of the receiver. If you don't like the automatic setup, and you can manually change it, then you may be able to do a manual equalization.
Lastly, equalization does not make poor equipment sound better. It generally makes it sound worse, since you are adding the stress of the equaliztion. This is why the conservative approach only uses cut filters to lower room peaks. Boosting dips will quickly overload most home systems.
Old 08-19-07, 09:18 PM   #3 (Link)
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
tcarcio is online now
I have the 81TXV and I believe that is correct as mine were also low after doing the MCACC. I don't know if it is the right thing to do but after runiing that I went into the menu of the Pioneer and with an SPL meter I turned up the level of each channel so they were more to my likeing. It sounds excellent and I had each level set to 80db.
Old 08-19-07, 09:50 PM   #4 (Link)
User: #10826
Since: Aug 2007
gsmollin : Thanks for the help. Although my room was very quiet, I'll make certain nothing else is on like the A/C, ****, etc. as you suggested.
My display system is the Pioneer Elite PRO-1130HD. Once I get to the part of the automatic calibration where it performs something like 8 tests or so, I'll need to turn off the media receiver since it turns off the plasma display.
Old 08-19-07, 10:01 PM   #5 (Link)
User: #10826
Since: Aug 2007
tcarcio : Thank you also for your help. In addition to redoing the automatic calibration as I just described above and saving it as MCACC -1, I'll do a manual calibration too. I've got a Radio Shack digital sound level meter which I'll use to try to manually set each channel at 80db, then save it as MCACC-2.
I'm anxious to see how the two different calibration techniques compare to each other and then to MCACC 'off'.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Similar Threads
Pioneer VSX-515 and WMA DrPainMD Home Theater Components 4 03-28-07 06:38 PM
Pioneer VSX-84TXSi sur5er Home Theater Components 13 02-07-07 10:52 AM
Pioneer Elite VSX-74TXVi THX Select2 7.1 A/V Receiver Sonnie Home Theater, Audio and Video News 0 06-16-06 01:36 AM
Pimp my Pad 4 $1K : Pioneer Elite VSX-52TX Roger Home Theater, Audio and Video News 0 05-20-06 09:51 AM
Pioneer 74TXVi: MCACC is ignoring 63hz Quant Home Theater Components 6 05-12-06 04:15 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
