Onkyo 905 Review - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Onkyo 905 Review
Discuss Onkyo 905 Review in the Home Theater | Audio and Video forum; Onkyo 905 Review I have had my 905 for about 1 month now and wanted to post a review. This is one heavy ...
Old 09-06-07, 01:13 PM   #1 (Link)
Alias: Tommy
User: #1972
Since: Aug 2006
Th8ter Nut is offline
Onkyo 905 Review
I have had my 905 for about 1 month now and wanted to post a review. This is one heavy unit at a little over 50 lbs. I replaced a Denon 3803 with the 905. The sound on the 905 is definitly in a different league than the Denon. The Onkyo reproduces much cleaner defined sound in both 2 channel and surround sound. I have a 7.1 system consisting of B&W 7 series speakers and a SVS sub. I hooked my Dish VIP622 via HDMI and without any problems. I tried connecting my Denon 2910 upconverting DVD player via HDMI but got no sound or picture. I have since connected it via HDMI converter to the DVI out on the Denon to HDMI on the receiver and optical for sound.
Pros: 1) As stated above the sound from the Onkyo is fantastic, much cleaner natural sounding. 2) the HDMI upconverstion to my Pany projector is great, it takes some tweaking on the Reon menus, as it tends to be on the soft side right out of the box. I also backed down about 3 notches on the brightness control on the projector. 3) I have enjoyed using the networking ability to play music from my PC to whole house system through the 905. 4) another great feature is you can transfer music to a USB drive and plug it into the front of the 905. 5) One connection to your source via HDMI and all switching is done through the 905. This makes it very simple for those in your household that might not be quite as tech savy to change between sources. 6) THX certification - I have never thought that I would say this in the past I have thought of this as just being something that mfg could boast about but the THX modes on this recevier are wonderful. I have experimented with several surround settings and must say the THX Ultra2 setting has made me a believer. This really brings out the best sound from surround encoded material whether it is from DVD or Sat. 7) Audyssey EQ system - very easy to use I ran the set up in 3 locations in my theater did a few tweeks on the levels with sound meter and was up and running very quickly.
Cons: 1) Only 2 optical inputs (although there are 3 coax) 2) Requires a separate adapter for iPod connection, it would have been great if a built in connection would have been provided. 3) Remote - for a receiver in this price range a better remote should be provided. 4) Internet radio feature is very difficult to set up, I still can't get this to work correctly. 5) Some have complained about how hot the unit gets but it does not seem to be any hotter than my previous Denon.
Aside from the hiccup with the HDMI connection to my 2910 DVD player the set up on this unit was very easy. The GUI is not as sexy as some of the new receivers but it works just fine. If anyone has any questions please let me know.
Old 09-07-07, 05:28 AM   #2 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Re: Onkyo 905 Review
I have a 3803 and B&W setup and am currently looking at Denon, Onkyo and Yamaha receivers. Can you elaborate on the differences in sound quality between the 905 and 3803, does one have a different sound (brighter or warmer) or are you just taking better sound quality overall from the 905?
Hakka.
Old 09-07-07, 07:32 AM   #3 (Link)
Alias: Tommy
User: #1972
Since: Aug 2006
Hakka wrote: View Post
Hakka.
I would say with the B&W the sound is much brighter with more detail in it. On music instruments like guitar strings and symbols come through with more detail. My 3803 seemed to maybe hold back some of this detail with the B&W's after comparing the 2 the Denon seemed a little muddy, not so that you cuold tell it although unless you A/B the 2 back to back. Also the sounds in the surround speakers really come alive with the 905. I am not sure if this is inherent to the 905 or it comes via the Audyssey set up. I don't think you will be disappointed with the 905 at all. Hope this helps.
Old 09-08-07, 09:57 PM   #4 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Thanks for the feedback mate.
Hakka.
Old 04-01-08, 02:57 AM   #5 (Link)
Alias: louis
Loc: Taipei, Taiwan
User: #2397
Since: Sep 2006
lienly is offline
took me months to add more net stations, used to be only built in e-onkyo ottava station. http://www.shoutcast.com tip, you can only connect from 1 AP directly. I try 2 APs, NG.
how hot is Denon? my 905 run 53C! after added fan, much cooler now.
http://photo.pchome.com.tw/lienly/047*30
BTW, have you suffered by HDCP handshake? I still need to use HDCP remover even upgraded to newest v1.08.
Th8ter Nut wrote: View Post
Old 04-01-08, 07:53 AM   #6 (Link)
Alias: Tommy
User: #1972
Since: Aug 2006
I can't really tell you how hot the Denon is I sold it several months ago. On the handshake issue I have the occasional lag but nothing I can't live with. Much of what I hear on the handshake is how, the order, in which you power up your equipment.
Old 04-01-08, 05:09 PM   #7 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
Hi Tommy, Nice review.
Its good to get another solid review on an higher end Onkyo receiver. Like the 805 that I have the 905 sounds like one that will satisfy you for many years to come.
Enjoy.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 04-01-08, 05:40 PM   #8 (Link)
Alias: Tommy
User: #1972
Since: Aug 2006
Thanks Tony. You have some very nice equipment listed in your profile. I notice you also have a Sammy BDP1400 are you experiencing any problems with yours? I have had to send in two units for repairs. I am not having very good luck with the 1400's. One quit playing BD but would play SD the other just would not power on at all.
Old 04-01-08, 09:14 PM   #9 (Link)
Alias: louis
Loc: Taipei, Taiwan
User: #2397
Since: Sep 2006
lienly is offline
Thumbs down Re: Onkyo 905 Review
no matter which device power on first, Onkyo/Tosh just won't handshake!
On the handshake issue I have the occassional lag but nothing I can live with. Much of what I hear on the handshake is how, the order, in which you power up your equipment.
Old 04-02-08, 09:35 AM   #10 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Thanks
So far so good, I've had mine for about 3 months and its been working fine.
Nintendo Wii
Old 04-02-08, 05:45 PM   #11 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Good review !
What is wrong with the picture through HDMI? Is it something specific or generalised?
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 04-15-08, 02:07 PM   #12 (Link)
New Member
Alias: steve
Loc: England
User: #19647
Since: Apr 2008
steve2529 is offline
HI Tommy,
We bought the 905 amp a few months ago and we are trying to connect to pc to play mp3 and musics files but having great dificulty and as you say that the playback from your pc is good through this I was wondering if you could point me in the right direction? I.E what connections/programs do we need etc....
We have also plugged up an mp3 storage device and a external usb hardrive both with music on and cannot get it to play.
Also we have seen TVertsity recomended on the net and we have downloaded but cannot get it to interface with it!
Any guidance would be appreciated
Steve
Old 04-21-08, 09:59 AM   #13 (Link)
New Member
Alias: nate
Loc: Weatherford, TX
User: #19878
Since: Apr 2008
nathan2174 is offline
I hear people who own the 905 or 875 that they had it spark all over the place and then didn't work after that. Is the Heat that much of a problem? I'm a little scared to buy it now. Also does any know if I can hook up my media computer to it with HDMI cables and will I get picture to the monitor? I want to use HDMI to get the digital sound. IT would be better sound then using coax.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Similar Threads
TW first Onkyo 905 owner! lienly Home Theater Components 12 04-27-08 11:40 PM
Onkyo Receivers Exocer Home Theater Components 7 12-31-07 12:17 AM
Need some help setting up Onkyo 605 jmy2469 System Setup and Connection 4 06-08-07 09:00 PM
HK or Onkyo brandonnash Home Theater Components 14 06-03-07 12:02 AM
Onkyo lcaillo Manufacturer and Vendor Reference Information 0 05-12-07 10:17 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141
