Electrical Help with new Denon AV-787 AV Receiver needed - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Discuss Electrical Help with new Denon AV-787 AV Receiver needed in the Home Theater | Audio and Video forum; Electrical Help with new Denon AV-787 AV Receiver needed I have a Denon AV-787 AV receiver that I bought from CC a few weeks ago and I have noticed ...
Old 09-27-07, 01:15 PM   #1 (Link)
New Member
Alias: Nate
Loc: Colorado Springs, CO
User: #11519
Since: Sep 2007
Fustern is offline
Question Electrical Help with new Denon AV-787 AV Receiver needed
I have a Denon AV-787 AV receiver that I bought from CC a few weeks ago and I have noticed that if using it in any mode I get several slight pauses of the sound. This occurs whether I am listening to DVD/CD, Satellite TV, or tuner. By "slight pause of sound" I would say it is maybe 1/4 second long. I do not see any flickering of lights/LED's/etc on any of the components when this happens. The audio seems to be the only thing affected.
At first I was thinking maybe my setup (see below) was pulling too much current but I would expect some dimming of things or protection circuitry kicking in with my components.
Is this a bad receiver?
My system is:
VIZIO 42" LCD
Toshiba upconverting DVD (HDMI to TV HDMI connection)
Direct TV satellite box (RCA patch cords for audio to AV receiver and S-Video to TV for video)
Denon AVR-787 AV receiver 85 watts x 7 channels
Velodyne VRP-1200 12" 125watt powered sub wired to the RCA sub out on receiver
SVS 12NSD 12" powered sub 325watts also wire to RCA sub out on receiver
All of this is connected in my unfinished basement via a power strip and a VERY heavy gauge extention cord to the only outlet in my basement. I don't listen to things at totally ridiculous power levels either.
Thanks for any advice. If its bad I will just return it for an exchange.
Old 09-27-07, 02:06 PM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: Electrical Help with new Denon AV-787 AV Receiver needed
Do you mean all the time in any mode or just at the beginning when you switch modes?
Old 09-27-07, 02:16 PM   #3 (Link)
Alias: brucek
User: #6
brucek is online now
If you're using digital connections, this would be what occurs when the source momentarily drops the digital signal. This is fairly common. When the digital signal is dropped (as opposed to simply continuing to send digital zero's), the DAC in the receiver has to reaquire digital lock by sampling and ensuring the type of signal that is being sent (i.e. PCM, DD, DTS, etc). The volume contollers are muted during this transition. It all takes less than a second. Most satellite STB's drop the signal during channel change for example.
Old 09-27-07, 02:24 PM   #4 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
My suggestion is to take it to CC if is possible and let them take a look ... if is bad I'm sure they will exchange it there ...
If you're lucky, maybe they will just exchange it without inspecting what is wrong ... usually they sell it as an "open box" ...
Did you purchased new or open box???? ....
Old 09-27-07, 02:44 PM   #5 (Link)
New Member
Alias: Nate
User: #11519
Since: Sep 2007
Fustern is offline
brucek wrote: View Post
Well I only have digital connections (HDMI) from the TV to the DVD and then I have an optical digital audio connection between the DVD/CD out and the receiver.
As for the satellite box it is NOT a digital connection but the RCA patch cords for audio to the receiver and S-video to the tv.
The problem is occuring with digital input and RCA input and even if the channel, song, station, etc has been going for a while. (i.e. not unique to changing sources).
Typically this momentary pausing of sound occurs once every 4-5 minutes of use and lasts for probably 1/4 to 1/3 of a second I would guess. It is somewhat annoying when you are really into a song or a movie and it happens.
Think I have a problem that I should return it?
Old 09-27-07, 03:31 PM   #6 (Link)
Alias: brucek
User: #6
Yep, given the info you just supplied in your last post....
Old 09-27-07, 05:46 PM   #7 (Link)
New Member
Alias: Nate
User: #11519
Since: Sep 2007
Fustern is offline
Thanks for the help...I checked my receipt and I was on the very last day to return for an exchange so I just went ahead and exchanged. Crossing fingers that the new one is good to go sans audio pausing.
Circuit City took it back without any trouble luckily.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Similar Threads
Futuristic Denon Blu-ray player / receiver concept HDBeat Home Theater, Audio and Video News 9 04-08-08 07:52 AM
Yamaha RX-V1700 Receiver / RX-V2700 Receiver - Official Owners Thread Sonnie Home Theater Components 88 09-18-07 10:41 AM
Help needed to adjust Receiver speaker levels alan monro Home Theater Components 3 06-21-07 01:33 PM
Denon AVR-2807 Receiver Sonnie Home Theater Components 19 04-19-07 11:38 AM
FS: Denon AVR-3806 Receiver Sonnie Classifieds - Audio Equipment 1 09-15-06 07:17 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
