Distribution device? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss Distribution device? in the Home Theater | Audio and Video forum; Distribution device? Hello all, I've been lurking here for some time and this would be my first post. I'm really not knowledgable ...
Old 10-26-07, 03:46 PM   #1 (Link)
New Member
Alias: punkin
Loc: Colorado
User: #8287
Since: Apr 2007
punkin is offline
Hello all,
I've been lurking here for some time and this would be my first post. I'm really not knowledgable in the area of home theater. If it's alright, I'd like to ask what is probably a very simplistic question.
My home stereo serves me quite well in the living room. The amplifier has a center, front, rear and a sub outputs. My home also is wired for sound in several rooms. They call it "Hi-Tek" wiring. Bottom line, there are 2 coaxial cables, 4 audio (2 pair) speaker wires, and 2 CAT-5 cables into virtually every room all converging upon a single distribution center in the basement (patch panels, punchblocks etc..). There are also speakers mounted in the ceilings/walls in most of the rooms as well so, it would seem that I'm pretty set with the exception of the delivery hardware.
I understand that it's unwise to "double up" or connect parallel speakers as it reduces over-all load resistance and stands to cause wear and possibly damage to the amplifier. So, I'm guessing someone will suggest a pre-amp and amplifier array type of device(s). While I'm not an expert in sound amplification and distribution and the products available on the market, I do have a very strong background in electronics. So, I'm here seeking advice of those who have a pulse on the consumer audio market.
My interest would be for a simple, clean and cost effective way of distributing audio to each of the rooms preferably switchable room by room. To be honest, most of the rooms don't need it, I'd be quite happy if I could do say, two or three rooms. It would also be good to be able to control the volume from those rooms without having to go all the way into the living room to make a simple volume adjustment. Things like channel/mode select not important to me at all.
Again, nothing real fancy. Thank you. I look forward to the comments and suggestions.
Steve
Old 10-26-07, 04:26 PM   #2 (Link)
Medialand Manager
Alias: Matt
Loc: Concord NH
tweeksound's Avatar
User: #10576
Since: Jul 2007
tweeksound is offline
Re: Distribution device?
1st, welcome to the shack!
2nd, your home sound system sound awesome!
As far as impedance from system to system, you can get the impedance you want by being creative with wiring.
I'm assuming you know this with your background in electronics.
If you have 8 - 8 ohm speakers and you wish them to equal 8 ohms you can wire 4 groups of 2 in parallel, then wire 2 groups of those in series and end up with 2 - 8 ohm systems or 1 - 8 ohm system.
I may have the description wrong but either way, it can be done with as many speakers as you want.
I'm not big in audio systems so I may be way off base here adn in that case someone will offer useful info soon.
Old 10-26-07, 04:47 PM   #3 (Link)
Loc: Lower Alabama
Sonnie is offline
Whole house distribution systems / multi-room systems... do get somewhat complicated when you wish to control them from within each room. There are several companies and tons and tons of configurations depending on what features you want.
Russound has several varieties.
SmartHomeUSA carries a selection from a couple of different companies.
Niles offers some solutions.
One of the most comprehensive is Nuvo.
Sonnie
Old 10-26-07, 05:33 PM   #4 (Link)
New Member
Alias: punkin
Loc: Colorado
User: #8287
Since: Apr 2007
punkin is offline
tweeksound wrote: View Post
Thanks Tweeksound,
I have played with the series parallel idea but it too has it's limitations. Worst of which is the lack of the clean independant controls. But good thoughts. Thank you.
Old 10-26-07, 05:34 PM   #5 (Link)
New Member
Alias: punkin
Loc: Colorado
User: #8287
Since: Apr 2007
punkin is offline
Sonnie wrote: View Post
Thank you Sonnie,
I'll surf these sites and see what floats to the top. Appreciate it!
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
Wireless A/V distribution and HD Antenna's JCD Remotes | Cables | Accessories 3 09-13-07 04:47 AM
BFD-like device for mains and surrounds? lovingdvd BFD Forum 13 01-31-07 04:50 PM
Anyone ever used a USB expansion device Wayne A. Pflughaupt Computers | Games | HTPC | Digital Devices 4 09-05-06 06:39 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
