Onkyo TX SR805 HDMI-Component out - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Discuss Onkyo TX SR805 HDMI-Component out in the Home Theater | Audio and Video forum; Onkyo TX SR805 HDMI-Component out Hi everyone, I will be getting my brand new Onkyo 805 on Monday and I have a question. I will ...
Old 11-22-07, 03:25 PM   #1 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
Hi everyone,
I will be getting my brand new Onkyo 805 on Monday and I have a question. I will be hooking up my Toshiba A2 HD DVD player to the Onkyo via HDMI if I must go to my Sanyo Z2 projector with Component will the 805 keep the signal in HD via component?
I tried a HDMI to DVI cable but for some reason I do not get video displayed on the projector going that route when I go directly from the A2's HDMI out.
Home theater:
Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD XA2, Samsung BDP1400 BluRay, Pioneer LD, Sanyo Z2 projector
Two Channel system:
Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20, Nintendo Wii
My Webpage
Old 11-22-07, 04:12 PM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: Onkyo TX SR805 HDMI-Component out
The DVI connection on the Sanyo Z2 is HDCP enabled so it should be working with the Toshiba A2 HD. By saying "not getting video displayed" do you mean a blank screen or video noise? What resolution were you sending the Z2, 1080i or 1080p?
Old 11-22-07, 04:22 PM   #3 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Mike P. wrote: View Post
I get only a blank screen. The A2 only outputs 1080i not 1080p and thats the setting I'm using.
Home theater:
Two Channel system:
My Webpage
Old 11-22-07, 04:26 PM   #4 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Then it's either a setting in the Z2 menus or a bad cable. It should be working with 1080i.
Old 11-22-07, 04:30 PM   #5 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
When I go into the Sanyo's menu it says its getting a 1080i signal and its the only option in the DVI HDCP category when selected. I will play with it some more tonight.
Home theater:
Two Channel system:
My Webpage
Old 11-24-07, 05:55 PM   #6 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Well I tried playing with the settings in both the Z2 and A2 menus and simply can not get it to play video through the HDMI to DVI cable I have. The projector says D-1080i in the Video 2 inputs display so it seems to know that what I am sending it but all I get is a blank screen.
Home theater:
Two Channel system:
My Webpage
Old 12-03-07, 04:29 PM   #7 (Link)
Alias: Zip
Loc: Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
Up conversion won't work over component becuase of HDCP, although I do get a message telling me it won't on my A2.
I have had problems in the past with the HDMI handshake and not being able to see anything on my projector or TV. Usually if I power everything off then power up the HD-A2 then the display it comes on. You could try powering up in difference sequences to see if it fixes the problem.
Also update your firmware to most recent version. There are usually known HDMI connectivity issues that get fixed in the firmware updates.
Old 12-04-07, 09:29 AM   #8 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Thanks Zip, I have recently bought an Onkyo TX SR805 so I now have it working through HDMI.
Home theater:
Two Channel system:
My Webpage
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Similar Threads
Onkyo TX-SR674 and HDMI MrPorterhouse Home Theater Components 7 12-30-07 04:15 PM
PS3: Component vs HDMI Motegi High Definition | HD DVD | Blu-ray 4 10-21-07 05:26 PM
HDMI vs. Component Sonnie Remotes | Cables | Accessories 9 03-17-07 12:39 AM
Component, DVI and HDMI over CAT-5 Roger Home Theater, Audio and Video News 0 05-24-06 01:33 AM
Component, DVI and HDMI connections Roger Home Theater, Audio and Video News 0 05-09-06 06:32 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
