Need a Non-Macroblocking Upscaling DVD Player - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Discuss Need a Non-Macroblocking Upscaling DVD Player in the Home Theater | Audio and Video forum; Need a Non-Macroblocking Upscaling DVD Player I'm having a tough time trying to find a good budget non-MB player. I was almost ready to buy one ...
Old 06-22-06, 01:57 PM   #1 (Link)
Alias: Quant
User: #123
Quant is offline
I was almost ready to buy one from the Samsung series (Zoran chip), but Michael TLV recently wrote on AVSforum "Severe white crush on the unit. Horrible lack of detail on bright objects."
http://www.avsforum.com/avs-vb/show...817#post7843817
The Sony 75 will not resize or vertically zoom 2.35:1 movies to fit the 16:9 screen. Sometimes I like to use this option.
The Momitsu 880 has build-quality issues.
Any other options for me? I'd like to keep it under ~$300.
Old 06-22-06, 03:07 PM   #2 (Link)
Alias: Phil
Phil M's Avatar
User: #20
Phil M is offline
Re: Need a Non-Macroblocking Upscaling DVD Player
Have you looked at the OppoDigital players:
http://www.oppodigital.com/
http://www.hometheaterhifi.com/cgi-b...h&articles=all
You can buy a few pizzas with the change.
Old 06-22-06, 04:23 PM   #3 (Link)
Alias: Quant
User: #123
Quant is offline
Just recently found out about the Oppo 970 - Mediatek chip with no macroblocking. Considering the picture quality of their last player, this might be a winner. I might give up my "vertical zoom requirement" for the oppo picture quality - the Oppo will not fit a 2.35:1 aspect movie on wide-screen tv's without black bars, unless you zoom the whole picture, but then you lose part of the picture on the sides.
Old 06-22-06, 08:17 PM   #4 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is offline
Quant wrote:
Jthe Oppo will not fit a 2.35:1 aspect movie on wide-screen tv's without black bars, unless you zoom the whole picture, but then you lose part of the picture on the sides.
Thats a good thing,.. no??? You see the film as it was intended to be seen.
Mark
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
