Is this enough - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Is this enough
Discuss Is this enough in the Home Theater | Audio and Video forum; Is this enough I have a Yamaha RV-X1700 receiver which is 130watts/ch. My speakers setup is Rocket 850's for the fronts, Rocket RSC200 ...
Old 12-02-07, 05:51 PM   #1 (Link)
Alias: Blitz
Loc: Connecticut
User: #13896
Since: Nov 2007
fernalfers is offline
Is this enough
I have a Yamaha RV-X1700 receiver which is 130watts/ch. My speakers setup is Rocket 850's for the fronts, Rocket RSC200 center, and Rocket RS250 MKII for surrounds.
Now is this receivers output enough to get out of these speakers what they are intended to do? Or should i be buying a dedicated 2-channel amp for the fronts to do so. And if so any suggestions?
Old 12-02-07, 08:10 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Is this enough
Hard to say. They have a pretty decent efficiency rating (which is more-or-less an indicator of how much power it takes to drive them), which is a plus. On the other hand, even though they’re rated as a nominal 8-ohm, much of their frequency range is down to 4-ohms or so.
If you are able to drive them to acceptable levels with your volume control no more than about 1/2 way up, you should be fine. If not, then an amp might be a good thing.
Old 12-02-07, 09:13 PM   #3 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
Re: Is this enough
Of course, going to 230W is still only going to give you +3dB on your mains, which isn't a whole lot, although that's better than clipping. Do an SPL calculation and use an SPL meter to figure out what you're driving them at now, and where the peaks are going to be in music or movies. Also, lost of mainstream music doesn't have a lot of dynamic range anyway.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
