What HD Reciever to buy - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Discuss What HD Reciever to buy in the Home Theater | Audio and Video forum; What HD Reciever to buy I am looking for an HD receiver to buy that has many HDMI inputs and Component inputs and Svideo as ...
Old 12-15-07, 09:36 AM   #1 (Link)
Alias: Reanimator
Loc: Coconut Creek, FL
User: #14378
Since: Dec 2007
Reanimator is offline
I am looking for an HD receiver to buy that has many HDMI inputs and Component inputs and Svideo as well and opticle.
I have many components to hook up to it with the variations listed above.
Thanks
Old 12-15-07, 09:55 AM   #2 (Link)
Alias: Worm
Loc: Colorado
User: #7339
Since: Mar 2007
Big Worm is offline
Re: What HD Reciever to buy
What is your budget? And how many inputs? Most common is 2-4 range on HDMI. Is that going to be enough?
Old 12-15-07, 10:05 AM   #3 (Link)
Alias: James
Loc: somers, ny
User: #13842
Since: Nov 2007
jr1414 is offline
Depending on your needs and budget, there are many options. I would start by listing out your components and preferred connection methods. Then identify your main viewing and listening material to determine what kind of decoders you will require in the Receiver. I would recommend finding an HDMI 1.3 receiver as that will provide the bandwith for higher resolutions and future audio codecs. If you don't have an upconverting player, you might consider a receiver that does upconversion also.
There are several options, and you really can't go wrong with any of these companies:
Pioneer Elite
Denon
Onkyo
Yamaha
There are lots more to choose from. There are some very, very good deals floating around on HDMI 1.2 receivers, would be worth looking into if your budget is a primary concern. Research and see which features you might appreciate more.
Good luck!
Old 12-15-07, 10:19 AM   #4 (Link)
Alias: Reanimator
User: #14378
Since: Dec 2007
Well lets start off by listing the components I have now.
XBOX 360 with HDVD player with component output
Regular XBOX with component output
DVD player with component out and optical out
Comcast HD box currently component and optical out
So in a sense I will need many component inputs but I will want at least three HDMI inputs as well for future changes
Budget under 800
Old 12-15-07, 11:12 AM   #5 (Link)
Loc: Lower Alabama
Hmmm... I'm not sure there is a receiver with 4 component inputs. Of course you could use this 4 port component switcher.
Old 12-15-07, 12:10 PM   #6 (Link)
Alias: Reanimator
User: #14378
Since: Dec 2007
I may splurge and go for the Onkyo TX-SR875, I know it only has 3 component inputs but it does well with HDMI inputs and I guess I can change one of the others to HDMI.
What do you think of that model?
Thanks
Old 12-15-07, 01:04 PM   #7 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
The Onkyo TX SR875 is in a class of its own, You cant go wrong.
To get anything even close to the quality of the 875 you have to spend well over $2000. If you have the cash to get one don't wait get it now. The HQV Raon processor alone makes it worth it. I highly recommend the Onkyo line I have the model just below it and have no regrets at all.
Home theater:
Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD XA2, Samsung BDP1400 BluRay, Pioneer LD, Sanyo Z2 projector
Two Channel system:
Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20, Nintendo Wii
My Webpage
Old 12-15-07, 04:18 PM   #8 (Link)
jvc
Exterminated!
Alias: jvc
Loc: NC
User: #10201
Since: Jul 2007
jvc is offline
There is also the ES Series Home Theater A/V Receiver (7.1 channel) by Sony. The ES series receivers, are said to be very good. The STR-DA5300ES has 6 (count'em) HDMI inputs!
From their site:
Bring your high-definition sources to life. With Dolby® TrueHD and DTS® HD Master Audio support, plus 1080p upscaling of any source, the STR-DA5300ES is optimized for Blu-ray Disc™ and other high-definition formats. See it here: http://www.sonystyle.com/webapp/wcs/...52921665186458
Good luck with whatever you get.
Old 12-16-07, 09:05 AM   #9 (Link)
Alias: Reanimator
User: #14378
Since: Dec 2007
WOW that is one sweet machine. Lots of inputs. Still only 3 component but the rest are amazing. About 3 to 4 hundred more in cash so is it worth the extra cash? Have to toss it around. Opinions are welcome.
Thanks so far guys
Old 12-16-07, 11:21 AM   #10 (Link)
jvc
Exterminated!
Alias: jvc
Loc: NC
User: #10201
Since: Jul 2007
jvc is offline
Only you can answer if it's worth the extra money.
Having plenty of inputs, and easy switching between sources, means more to some people than others. If you use a remote that does the switching for you (such as a Harmony), the only consideration is having more HDMI inputs. This doesn't seem important, until you need one HDMI input more than you have........
Old 12-16-07, 11:43 AM   #11 (Link)
Alias: Worm
Loc: Colorado
User: #7339
Since: Mar 2007
Big Worm is offline
That sony on paper looks good, but I will say that Sony is not very well regarded for good audio on their receivers. I would stick with the Onkyo.
Old 12-16-07, 03:38 PM   #12 (Link)
jvc
Exterminated!
Alias: jvc
Loc: NC
User: #10201
Since: Jul 2007
jvc is offline
Big Worm wrote: View Post
That is true about most of their other receivers, but the ES series is regarded pretty highly. Everything I've read about them has been positive.
Old 12-17-07, 09:15 AM   #13 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
The one thing that is missing on the Sony is the HQV Raon chip for upscaling video The Onkyo 875 has it and is far superior to the upscaling that the Sony has. The Onkyo 875 also has the best BurrBrown DAs available and 140watts per ch. using a push-pull amplification section (very good design) where The Sony only uses the standard Burr brown DAs and only 120watts, all things to keep in mind.
Home theater:
Two Channel system:
My Webpage
Old 12-17-07, 10:05 AM   #14 (Link)
Alias: Reanimator
User: #14378
Since: Dec 2007
I am indeed keeping this all in mind. I appreciate the info from both sides. It helps me and confuses me on what is more important to me. Keep the info coming.
Thanks
Old 12-17-07, 01:09 PM   #15 (Link)
New Member
Alias: Tim
Loc: Lovell, Maine
User: #12032
Since: Oct 2007
odonata is offline
Another receiver to consider in that same price range might be the Denon AVR-3808ci. With 4 HDMI inputs and ethernet connectivity, if that interests you, the feature set is quite impressive. While it does not have the HQV Reon-VX video chip as the Onkyo, it does have the very respectable Faroudja DCDi precessor and a host of other video/audio/multimedia features.
I have compared the sound of the 3808ci with the Sony STR-DA5300EX and, at least for my ears, found the Sony's sound to be much harsher. There also seem to be some HDMI audio issues with the Sony from what I have read. On the positive side, the Sony's GUI in wonderful and the six HDMI inputs would be handy if needed.
There again the Onkyo may be a good choice with its video chip set and a good array of features. Plus, it has THX certification, if that is important to you.
For a comparison of features/specs of the Onkyo 875 and Denon 3808ci, see http://www.theosfiles.com/zzz/receiv...vs_3808CI.html.
It's, of course, up to you to decide what features are right for you and how much you are willing to spend to the get them. Unfortunately, there is no perfect A/V receiver for everyone; you just have to find the one that best fits your needs/desires/budget.
Some legitimate questions to ask yourself might be:
How important is video upconversion/upscaling, or is onboard video processing important to me at all?
Are ethernet/USB connections important to me for access to my multimedia files on computers and other devices?
How many HDMI inputs (and outputs) will I need, not just now but in the near future?
Will I use this receiver to send audio/video to multiple zones in my home?
Is autocalibration, such as the Audyssey system, important?
Will I be listening to a lot of Dolby/DTS digital content?
How much should I be willing to put toward a new receiver as opposed to upgrading the rest of my system (speakers, components, monitor, etc.?)
Have fun!
Old 12-17-07, 01:34 PM   #16 (Link)
Alias: Reanimator
User: #14378
Since: Dec 2007
Yes lots of ?'s to be answered. Currently I have THX certified Boston Acoustics. I have always been happy with them. I was using a kenwood THX system but lately it has been a 5 year old Denon. My main priority for the moment is a lot of inputs and the most features for the buck. I like the internet feature or lan streaming but really I can do that with my xbox 360 and of course that passes through the HT unit. Upscaling seems to be an interesting feature if I find a need to use it. As far as sound quality, I think for movies it might not matter as much as it would for some classical music. Once the bass kicks in all things in my house will rattle anyway. So I feel out of the three listed the Sony ES is what I am leaning towards for the moment. I think some of that reasoning is the additional optical and other inputs. But after reading the comparison specs I see the Denon does look good.
Old 12-17-07, 01:53 PM   #17 (Link)
Alias: James
Loc: somers, ny
User: #13842
Since: Nov 2007
jr1414 is offline
How serious was that under $800 budget. It seems like the choices offered have been substantially above that figure. For under $800, you won't find many receivers with a large amount of HDMI inputs. The Onkyo SR705 is available under that budget and is hard to beat for the price. But, as mentioned, weigh all of your needs and decide how you are really going to utilize the available features of each receiver. Then make the best decision for you.
Old 12-17-07, 04:17 PM   #18 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
seeing as your budget is fairly large You could also just get this one from Sunfire It will do the job better than most anything else out there.
Strangely though it only has two HDMI inputs
Home theater:
Two Channel system:
My Webpage
Old 12-17-07, 05:17 PM   #19 (Link)
Loc: Lower Alabama
Go separates... the Anthem AVM-50 has 4 component inputs and 4 HDMI inputs.
Old 12-17-07, 06:45 PM   #20 (Link)
Alias: Reanimator
User: #14378
Since: Dec 2007
well since I am under the impression that I won't really get what I want under 800 I guess It will be more like 1200 now
Old 12-17-07, 06:48 PM   #21 (Link)
Alias: Reanimator
User: #14378
Since: Dec 2007
I just looked at that AVM-50. No way I am spending that much money.
Old 12-17-07, 08:14 PM   #22 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Reanimator wrote: View Post
I am looking for an HD receiver to buy that has many HDMI inputs and Component inputs and Svideo as well and opticle. I have many components to hook up to it with the variations listed above. Thanks
Do you use your receiver to feed video to your TV??? ... I remember I read that is better to connect the video signal to your TV directly and the audio to your receiver ... most like to do it thru the receiver because is more convenient, but I prefer to avoid the conversion of signals .
If you need a lot of HDMI and component inputs ... you can combine the use of the inputs on the TV and receiver (correct me if I'm wrong), you can use the HDMI's and components on the TV (depending on your model you have at least 1 HDMI and a couple of components) and if you add the inputs on the receiver ... you will have more than enough to connect your components
The only incovenience is switching inputs ... by the way, I read good things about the Yamaha RX-V1800
but it cost almost $900
If you're not in a hurry to get a receiver, you can do the same I do ... walk around the electronics store, look for open box deals (I'm sure there will be some after Christmas) and when you find one get it ... I just got a Yamaha RX-V2700 for $399.99 but didn't have the remote, manual and YPAO microphone to calibrate ... I was lucky and they found the remote later that week, I downloaded the manual online and I will order the YPAO ... lucky me
Old 12-17-07, 10:06 PM   #23 (Link)
Loc: Lower Alabama
Yeah... with an initial budget of $800... the Anthem suggestion was meant to be sarcastic. But it does have your required inputs and is the only piece I've seen that does.
Since you are increasing your budget to $1200... that will at least allow you a nicer receiver.
I would heavily consider the Onkyo TX-SR875 which has 3 component inputs and 4 HDMI inputs. Very nice receiver for $1269 shipped. You may find it for less.
Another one that would be really nice is the Denon AVR3808CI with the same component and HDMI inputs as the Onkyo.
And yet another very nice one is the Yamaha RX-V1800 with the same inputs as above.
As someone else mentioned the Sony STR-DA5300ES is another with even more HDMI inputs.
EDIT: Adding the Pioneer VSX-94TXH Elite to the list.
There are plenty of good choices in your price range. I suspect they will all s
