| Home Theater Components onkyo vs. marantzDiscuss onkyo vs. marantz in the Home Theater | Audio and Video forum; onkyo vs. marantz simply put the onkyo tx-nr905 or the marantz sr8002?
i can get them both for about the same price, any ... |
| | #2 (Link) | |||
| Re: onkyo vs. marantz Thats a tough choice, The one big thing is the Onkyo has more power per channel and has a Toroidal Power Supply. The Marantz also doesn't mention if it uses the HQV Raon chip for upscaling video where the 905 does. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25, Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, My Webpage | |||
| | #5 (Link) | |||
| Re: onkyo vs. marantz I looked at the Marantz SR8002 because it was heavily pushed by a dealer who higly recomended it. It is rated at 125 watts x 7 channels. It only weighs 33.1 pounds. Maximum power consumption is 780 watts. It does 480i to 480p upconversion. And its dimensions (whd) are 17 5/16" x 7 1/4" x 15 5/8". The dealer said it would sound really good with the Paradigm Studio speakers he was also selling. The Onkyo TX-NR905 is rated at 140 watts x 7 channels. It weighs 54 pounds. Maximum power consumption is 9.8 amps (1176 watts). Its dimensions (whd) are 17 1/8" x 7 5/8" x 18 1/16". It is thus 21 pounds heavier, 2 11/16" deeper, and can use about 400 watts more AC power than the Marantz. My understanding is that amplifiers are rated as stereo amplifiers only. So in most of the ratings for 7 channel amplifiers or receivers they are testing the amplifier with only 2 channels at a time. Thus an underpowered powersupply would not be noticed by any measurement in the ratings. I suspect that a big heavy transformer will output more power than a smaller lighter transformer. And big larger conventional aluminum heatsinks will dissipate heat better than small light copper plated ones will. I don't know the exact improvements that a toroidal transformer has over a more conventional cheaper transformer except that they are probably a little more power efficient and dissipate less heat. They are also much more expensive to manufacture. A necessary improvement for marketing with no real improvement for the customer. I also believe that much of the maximum power that a unit will consume will be an indication of how much power could go to the speakers. Of course a class D switching amplifier will be more efficient than a non switching amplifier. However, at higher frequencies the class D will have more distortion. Subwoofers commonly have class D switching amplifiers but they only amplify low frequencies. The dealer told me that the Integra DTR-7.8 receiver ($1200) that I was thinking of buying had a harsh and bright high end. This would make the Paradigm speakers sound harsh and bad. He said that the Marantz would make the speakers sound smooth and clear. I ended up buying the Integra receiver and the Paradigm speakers from another dealer whose advice I trusted more. The sound is clear, flat, accurate, detailed, and there is plenty of power. Integra is a division of Onkyo. So I am sure that the sound from Onkyo TX-NR905 will also be excellent. And it has the HQV reon-VX which upscales to 1080p. The reon is worth $700 alone. | |||
| | #6 (Link) | |||||||
| Re: onkyo vs. marantz Quote:
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25, Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, My Webpage | |||||||
| | #7 (Link) | ||||
The primary advantage in a torroidal transformer is the efficiency. You can build a smaller, lighter device to get the same current. They are quieter as well, but the difference in how "clean" the power might be is marginal. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | ||||
| | #8 (Link) | |||
| Re: onkyo vs. marantz Torroidal transformers are self-shielding (they contain their magnetic fields better). This can reduce the amount of 60 Hz hum (when using a linear design power supply) induced in other circuits. For higher frequency switching power supplies, a torroidal transformer does a better job of containing EMI. Harder to wind though. | |||
| | #9 (Link) | |||
| Re: onkyo vs. marantz Plitron is a company which makes toroidal transformers. This information is from their web page: http://www.plitron.com/advantages.asp High efficiency of around 95% at load versus 80% for a standard transformer. Size can be 50% smaller and lighter than conventional transformers. Toroidal transformers are acoustically silent with very low mechanicl hum compared to conventional transformers. The windings of the toroidal transformer act as magnetic shielding and they radiate 1/10 the magnetic field of conventional transformers. The toroidal transformer uses 1/16 the power when no load is being driven. All of these factors should be of greater importance when larger loads such as 1000 watts or more are required to drive the speaker output amplifiers. | |||
| | #10 (Link) | |||
| Re: onkyo vs. marantz I'm pretty sure that both of these amps have toroidal transformers. Copper is a better conductor of heat than aluminum so a smaller copper heatsink would be more efficient than a larger aluminum one. Excess weight can also mean poor design or heavy use of older (heavier) components or materials. I think it would boil down to features, which the Onkyo has more. You get network capabilities (streaming, internet radio), THX Ultra certification as opposed to THX Select, a little more wattage and much better video upconversion. The 905 has the upper hand in pretty much every category, looking at the specs. You might want to audition them though to see which one sounds better in you opinion. On paper the 905 is a clear winner. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Marantz 7002 and 8002 | Wayde | Home Theater Components | 7 | 08-07-08 06:33 PM |
| Yamaha RSXV1700 vs Onkyo 805 vs Onkyo 705 | Buckster | Home Theater Components | 2 | 03-03-08 09:22 AM |
| marantz vc6001 vs denon dv2200 and marantz cc4300? | enrique | Home Theater Components | 3 | 06-06-07 01:07 PM |
| Marantz | lcaillo | Manufacturer and Vendor Reference Information | 0 | 05-13-07 08:26 AM |
| Marantz SR5200 | Phil M | Home Theater Components | 4 | 05-14-06 10:36 AM |
