| Home Theater Components Blue volume ring on Harmon Kardon is dead.Discuss Blue volume ring on Harmon Kardon is dead. in the Home Theater | Audio and Video forum; Blue volume ring on Harmon Kardon is dead. Hi, has anyone had any experience with replacing the bulb, or whatever is inside the volume ring, on a Harmon ... |
| | #1 (Link) | |||
| Blue volume ring on Harmon Kardon is dead. Hi, has anyone had any experience with replacing the bulb, or whatever is inside the volume ring, on a Harmon Kardon receiver? Just noticed tonight that the little glowing blue light around the volume is gone. I can live without it, but I prefer my gear to be in 100% working order. Thanks in advance. | |||
| | #2 (Link) | |||
| | Re: Blue volume ring on Harmon Kardon is dead. I'd frankly be glad it's off. I'm one of those anal retentive types that blacks out all the indicator lights and most of the displays on my gear with a 2 layer combo of black duct tape on top of blue painter's tape (for removability) so that it doesn't visually distract. Just trim to fit with an Exacto blade and you're all set. Tim ![]() He drove a black and white pirate ship at 190 mph. - Dale in the #3 will never be forgotten. Thanks for the memories. | |||
| | #3 (Link) | |||||
| | Re: Blue volume ring on Harmon Kardon is dead. Quote:
Your thing is lights; mine is “billboards” - all those stupid emblems noting this or that feature plastered all over the faceplate (THX! AL24 Processing! Cinema DSP!). VCRs were the absolute worse! (TimeScan! VCR Plus! 70μ Heads!) And I have always hated that DVD emblem they plaster on the drawer of DVD players. What, we can’t read where it says, “Yamaha Natural Sound DVD Player DVD-S700??” Anyway, I precisely cut a piece of black 3M electrical tape to size and cover the billboards. Even in broad daylight it’s practically invisible, and under regular viewing lighting, it is! Regards, Wayne | |||||
| | #4 (Link) | ||||
Tim ![]() He drove a black and white pirate ship at 190 mph. - Dale in the #3 will never be forgotten. Thanks for the memories. Last edited by OvalNut; 02-07-08 at 01:01 AM. | ||||
| | #5 (Link) | ||||
C'mon Wayne, what's wrong with advertising for Tom Holman, et al in your HT? They paid you for that right, didn't they? "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | ||||
| | #6 (Link) | ||||
I just peeled off a piece from an old VCR I’m not using anymore, that’s probably been on nearly 10 years, and it left just a smidge of residue at rubbed right off. I expect most people won’t keep a component that long, so they won’t even get the “smidge.” ![]() Regards, Wayne | ||||
| | #8 (Link) | |||
| Re: Blue volume ring on Harmon Kardon is dead. Getting back on topic...George, what model is this? I'll see if I can dig up some info on the part. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| | #9 (Link) | |||
| Re: Blue volume ring on Harmon Kardon is dead. Hi, thanks Leonard, the model number is AVR 635. I happened to be looking at it tonight while waiting for a DVD to boot up and noticed it flicker, but further watching and tapping, I didn't see it repeat. But please let me know if you find out anything! As for the other advice on the black tape, I used mine up sticking IR reapers to my equipment. ![]() | |||
| | #10 (Link) | |||
| Re: Blue volume ring on Harmon Kardon is dead. Just to update the Harman blue ring issue from my first post... you were right Wayne, it is impossible to get at that knob to change the bulb without causing worse problems than I started with. I may take it in to a shop to get a static annoyance taken care of in my right surround channel, and get them to look for that bulb wayyy in there. It's not two years old yet, but the warranty isn't valid in Canada because I purchased it in the good old U.S. of A. I don't see the big difference with the same machine, but companies are funny like that. So I will pay out of pocket for the fix. ![]() | |||
| | #13 (Link) | |||
| Re: Blue volume ring on Harmon Kardon is dead. Not that I am aware of. I have reset the receiver several times since then, and still no light. I will give it another shot for what it's worth. I think it may have just loosened up due to shipping or install. Thanks though, I have been wrong before when it came to this receiver. | |||
| | #14 (Link) | |||
| Re: Blue volume ring on Harmon Kardon is dead. These bulbs are usually LED surface mount and are not user replaceable. LEDs last almost forever and vibration dose not affect them. I wonder if you used the dimmer function on the receiver and turned it off accidentally as it is usually only on on the brightest setting.. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Tinnitus (ears ring) subwoofers and electronics | bbphd | General Discussion | 9 | 10-24-07 12:39 PM |
| Sony rp lcd " blue blob or blue haze" | Joey Skinner | Video Displays and Processors | 6 | 09-25-07 08:01 AM |
| Harman Kardon AVR 240 deal | SteveB | Home Theater Components | 1 | 09-13-07 12:24 PM |
| Volume versus effective volume? | ramchip007 | DIY Subwoofers | 4 | 08-29-07 01:57 PM |
| Keiko Matsui The Ring: CDs no hi-fi fan should be without | jackfish | Music and DVD Concerts | 2 | 03-18-07 02:03 PM |
