denon reciever with pro amp - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Components
Discuss denon reciever with pro amp in the Home Theater | Audio and Video forum; denon reciever with pro amp hi everyone Ihave a denon 3803 and a behringer ep 2500.I want to run my klipsch klf 30s the denon ...
Old 02-13-08, 10:37 PM   #1 (Link)
New Member
Alias: randy
Loc: chicago IL
User: #4768
Since: Dec 2006
randyman is offline
hi everyone
Ihave a denon 3803 and a behringer ep 2500.I want to run my klipsch klf 30s the denon will be the pre amp ep 2500 running the .klf 30s My question is how should i set the volume or test tones on the denon reciever ? any advice would be great I plan on putting the 2500 back on subwoofer duty once I get a new xti 2000 crown will the run the Klipsch .
thanks for your help guys
P.S dose anybody else use the behringer 2500 to run the home audio speakers? I think it is a good amp for 300 ipaid for it i know thers better amps out there but you cant beat this amp for the money
thanks again
Randy
Old 02-14-08, 05:17 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: denon reciever with pro amp
Same as without the amp. The only difference is that the amp has gain controls that you can adjust for volume for those channels, rather than from the Denon itself.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Components »
Similar Threads
Which reciever Onkyo TX-SR875 or Denon 3808ci MatrixDweller Home Theater Components 34 06-03-08 11:08 PM
Denon 4308: can't decide if it plays Dolby Digital or Pro Logic II John Simpson Home Theater Components 5 03-21-08 02:54 PM
Samsung Bd-up5000 And Older Denon Reciever ewarren High Definition | HD-DVD | Blu-ray 1 12-28-07 05:30 PM
Adding a Power Amp to bi-amp from a Denon 3805 Malice Home Theater Components 18 08-07-07 05:26 PM
Denon AVR-3806: Audessey & other confusion... russ.will Home Theater Components 9 05-27-06 01:49 AM
Mach 5 Audio
