| Home Theater Components Will upgrading to a 7.1 surround system be worth the install?Discuss Will upgrading to a 7.1 surround system be worth the install? in the Home Theater | Audio and Video forum; Will upgrading to a 7.1 surround system be worth the install? Hi, I am pondering upgrading my current 5.1 surround system to a 7.1 system. I will be using the same ... |
| | #1 (Link) | |||
| Will upgrading to a 7.1 surround system be worth the install? Hi, I am pondering upgrading my current 5.1 surround system to a 7.1 system. I will be using the same HK635 receiver, so my question is: Will the addition of two speakers make a noticeable difference in my dedicated home theater room? The speakers will be from the same brand and family as the others installed, so matching timbre shouldn't be a problem. I will be removing the rear bipole speakers from the back wall and replacing them with bookshelf speakers; then installing the bipoles on either wall, just to the side and rear of the seating. I enjoy the sound now, but since my receiver is capable of Dolby 7.1, so I could possibly enjoy my room even more. What say you? | |||
| | #2 (Link) | |||
| Re: Will upgrading to a 7.1 surround system be worth the install? Their will be a difference but it fully depends on the movie. If it has 7.1 audio like DTS EX for example you will then have the "full" experience otherwise it will just matrix the rear channels. If your room is larger this will be a more noticeable difference. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #3 (Link) | ||||
| Re: Will upgrading to a 7.1 surround system be worth the install? Quote:
![]() Most movies are 5.1 and few 6.1 ... so the sound for the back surrounds will come from the surround speakers (receiver will do this mix); I read somwhere that a 7.1 is better used when you have more than one row of seats or when you have a large room (I don't know what is your situation) ![]() I'll suggest you to try it first and see if you like the results ... my room is 9' x 18' x 8' and I have two rows of seats ... currently I'm using 7.1 and I like it ![]() | ||||
| | #4 (Link) | |||
| Re: Will upgrading to a 7.1 surround system be worth the install? Thanks for the responses, guys. I do have two rows of seating, so it may make it worthwhile. I'll give it a bit of a dry run with wires outside the wall before I start drilling to make sure I will like the difference. My wife turns a ghostly white when she sees me running with a drill and electronics. ![]() | |||
| | #5 (Link) | |||||
![]() Quote:
| | #7 (Link) | |||
| Re: Will upgrading to a 7.1 surround system be worth the install? If you have the ability to be fully compliant with the rest of your gear in terms of Blu-Ray/HDMI Etc... Go for it... I've had 7.1 for 3 years and I love the versatility... Go Go Go ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() TG | |||
| | #8 (Link) | |||
| Re: Will upgrading to a 7.1 surround system be worth the install? Good question. I have wondered this same question. There are not many movies that are 7.1 yet are there? But, I have read that more should start turning up this year. I hope so. What are some thoughts on using dipoles for the rears? | |||
| | #9 (Link) | |||
| Re: Will upgrading to a 7.1 surround system be worth the install? I have read that dipoles lessen the sense of localization, than say bipoles, which is great for movies but they are not recommended if your listening is geared more toward music. This is only what I have read, not from first hand experience. | |||
| | #10 (Link) | |||
| Re: Will upgrading to a 7.1 surround system be worth the install? I have the AVR-645 and it is setup for 7.1 (minus the .1, but that's another story) I do not have matched speakers, but when I switched from 5.1 to 7.1 on Finding Nemo, there was a noticeable difference. The scene where the submarine slides and strikes the cliff is where I first noticed the 7.1. The rubble falling moves from rear to middle to front. Pretty cool! | |||
| | #11 (Link) | ||||
I am envious of your HK 645 HDMI inputs though... | ||||
| | #12 (Link) | |||
| Re: Will upgrading to a 7.1 surround system be worth the install? I purchased for the HDMI, but don't have any thing that requires them. I do beleive that they are HDMI 1.1 so not sure how useful they will be???? | |||
| | #13 (Link) | ||||
| | #14 (Link) | ||||
![]() ![]() I suggest you to open a new thread with your ideas and what you're looking for and you'll get a lot of s uggestions from members ![]() ![]() | ||||
| | #15 (Link) | |||
| Re: Will upgrading to a 7.1 surround system be worth the install? I am not sure that 7 channels wil sound better than 5 well positionned speakers if you have enough space in the back. I think that it depends on your room and your listening position. JP | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| FS: SMART DEVICES Center-Surround 3X, Jr. Digital Surround Decoder | intelonetwo | Classifieds - Audio Equipment | 3 | 06-05-08 10:03 AM |
| FS: 50" Samsung 1080P DLP & DVD upconvert/receiver with 5.1 surround system LG-HTI | E-A-G-L-E-S | Classifieds - Video Displays and Projectors | 2 | 09-18-07 06:32 PM |
| Powering a Surround Sound System | Bob_99 | Home Theater Components | 7 | 09-07-07 08:59 AM |
| Polk SurroundBar One Box Surround Sound Speaker System | Chris Boylan | Home Theater, Audio and Video News | 0 | 10-02-06 07:02 PM |
| Yamaha Bows New One-Box Surround System (YSP-1100) and Home Theater Receiver (RX-V2700) | Chris Boylan | Home Theater, Audio and Video News | 0 | 10-01-06 12:25 AM |
