| Home Theater Components Onkyo 605 or 705?Discuss Onkyo 605 or 705? in the Home Theater | Audio and Video forum; Onkyo 605 or 705? I am looking for a budget receiver that has 1.3 HDMI and obvisouly trueHD and DTS HD. I was looking ... |
| | #1 (Link) | |||
| Onkyo 605 or 705? I am looking for a budget receiver that has 1.3 HDMI and obvisouly trueHD and DTS HD. I was looking at the Onkyo 605 or 705...is there a big difference between the two? Also, is there any other receiver in there price category that might be a better choice? | |||
| | #3 (Link) | |||
| Re: Onkyo 605 or 705? Thanks for the input, I will probably never need to add an amp and if I do I will just buy seperate components. I am more concerned with the quality of the sound, so the Audyssey does come into play | |||
| | #4 (Link) | |||
| Re: Onkyo 605 or 705? Is there a better receiver than the 605 or 705 that I can find for under $500? Which models to take a look at? My biggest concern is the HDMI inputs that send video and audio | |||
| | #5 (Link) | |||
| | Re: Onkyo 605 or 705? Did you check out the 6th Avenue deals on the two Marantz receivers? The Pioneer VSX-1017TXV-K may be another to consider... good reviews. | |||
| | #6 (Link) | |||
| Re: Onkyo 605 or 705? Given the deal on the Marantz that Sonnie links you to that is a very good option. Personally I like Onkyo but for that price the Marantz SR5002 may be the way to go if you can squeeze just a little bit more out of your budget. EDIT: I just read a review of the Marantz and it doesn't pass through HDMI 1.3 only 1.1 so if that matters to you then the Onkyo 705 would still be the best choice. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i towers, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 | |||
| | #7 (Link) | ||||
| Re: Onkyo 605 or 705? Have a look here.... http://www.avsforum.com/avs-vb/showthread.php?t=935808 Scroll down to #7 on "Why should I get a 705 over the 605?" Quote:
| Thread Tools | |
Similar Threads | ||||
| Onkyo TX-SR 605 Owners? | jmy2469 | Home Theater Components | 28 | 04-01-08 07:02 PM |
| no picture through HDMI connection? onkyo 605 | jimbronie | Home Theater Components | 1 | 12-31-07 01:18 PM |
| Got A New Toy Today! Onkyo 705 | Jerm357 | Home Theater Components | 10 | 11-22-07 08:52 PM |
| Need some help setting up Onkyo 605 | jmy2469 | Home Theater Components | 4 | 06-08-07 09:00 PM |
| Onkyo | lcaillo | Manufacturer and Vendor Reference Information | 0 | 05-12-07 10:17 PM |
