| Home Theater Components True HD receiver needed?Discuss True HD receiver needed? in the Home Theater | Audio and Video forum; True HD receiver needed? I am using a PS3 which has True Dolby HD and is soon to have DTS HD capabilities. DO I ... |
| | #1 (Link) | |||
| True HD receiver needed? I am using a PS3 which has True Dolby HD and is soon to have DTS HD capabilities. DO I need a receiver that has those same decoding codecs? If a receiver has a direct mode and HDMI inputs, will it transmit the True HD signal? I am really confused.... | |||
| | #2 (Link) | |||
| | Re: True HD receiver needed? If the PS3 is decoding it, then the receiver does not have to decode it. You simply need a receiver with HDMI inputs, which I think pretty much all of the latest models have HDMI now. Depending on your budget, you may get the decoding anyway. How much are you looking to spend? | |||
| | #4 (Link) | |||
| Re: True HD receiver needed? I dont know what quality the DA's are in the PS3 but its usually better to have the receiver do the decoding. The Onkyo 705 is defiantly a good choice. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i towers, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 | |||
| | #6 (Link) | ||||
| Re: True HD receiver needed? Quote:
The player's audio D/A convertors come into the playback process when you use the player's audio analog outputs (stereo, 5.1 or 7.1) to the stereo or multichannel analog inputs of the receiver (AVR/Pre-Pro) being used. | ||||
| | #7 (Link) | |||
| Re: True HD receiver needed? I have a PS3 and BTW it does not pass lossless audio as of yet. It's not a true HDMI 1.3 device. A HDMI 1.3 receiver right now would just be future proofing. A future firmware release or new hardware model might enable raw lossless audio however. Currently the PS3 decodes the codecs and passes them as LPCM. Any receiver that can accept LPCM over HDMI will do the trick. | |||
| Thread Tools | |
Similar Threads | ||||
| Greetings from WildBill...a true HT and home audio fanatic! | Twinbugles | Welcome | Member Introduction | 4 | 11-22-07 02:45 PM |
| Electrical Help with new Denon AV-787 AV Receiver needed | Fustern | Home Theater Components | 6 | 09-27-07 05:46 PM |
| Yamaha RX-V1700 Receiver / RX-V2700 Receiver - Official Owners Thread | Sonnie | Home Theater Components | 88 | 09-18-07 10:41 AM |
| Help needed to adjust Receiver speaker levels | alan monro | Home Theater Components | 3 | 06-21-07 01:33 PM |
| Room EQ Wizard, true RTA, ETF - any need for all? | basementjack | REW Forum | 12 | 11-07-06 06:31 PM |
