| System Setup and Connection HDMI and Audio IssueDiscuss HDMI and Audio Issue in the Home Theater | Audio and Video forum; HDMI and Audio Issue I think I know the answer but I will ask anyway.
I have my HD-DVD players connected to my AVR ... |
| | #1 (Link) | |||
| HDMI and Audio Issue I think I know the answer but I will ask anyway. I have my HD-DVD players connected to my AVR connected to my TV. Player to AVR is HDMI AVR to TV is HDMI to DVI-D (tv does not have HDMI and only DVI-D) If I play a movie and leave the tv off - I get audio via HDMI If I turn the tv on then I loose audio I finally gave up and am using a optical cable for audio. My guess is the DVI-D does not have audio so I loose the HDCP handshake for audio when the tv is on? I could come up with no other explanation. Any other ideas? Equipment : Toshiba XA1 HD-DVD AVR: Sony 5200ES TV: Mitsubishi 48" RPTV HDTV 1080i | |||
| | #2 (Link) | |||
| Re: HDMI and Audio Issue I think it is the other way around. With the TV off, the AVR is using the audio. With the TV on, it is sending it out the HDMI but, of course, it has no where to go. | |||
| | #3 (Link) | |||
| Re: HDMI and Audio Issue Thx for the reply but I do not understand ... If I did have HDMI from AVR to TV - then it would seem I could play audio via TV speakers and not the AVR? But hey, maybe? dunno?? I just discovered that this happens after getting a second HDMI cable and results were the same, TV Off, Audio works, TV On, Audio does not work. I want a new TV! LOL | |||
| | #6 (Link) | |||
| Re: HDMI and Audio Issue Does your Sony AVR have a setup setting to tell it to always use the HDMI audio and never send it on to the TV? Seem to recall that other AVRs have such a setting. If you are using an AVR, it is normally undesirable to have the TV's speakers used at all. | |||
| | #7 (Link) | |||
| Re: HDMI and Audio Issue I bet it probably is the HDMI handshake that's messing things up. You could ditch the HDMI-DVI cable and use component instead. The other option would be to get a more sophisticated HDMI to DVI changer that guarantees that it is HDCP compliant. A powered converter box might sandwich in the middle and be compatible with your receiver. Maybe a firmware update is available for your receiver that solves this problem. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| hd-a30- HDMI (video) and Optical (audio) = 1/2 volume issue | jkicak | Home Theater Components | 4 | 01-26-08 12:49 PM |
| Is 1.3 hdmi necessary for Dolby TrueHD and DTS-HD Master Audio? | jmy2469 | Home Theater Components | 7 | 06-03-07 08:32 AM |
| Benefits of HDMI audio? | Sonnie | General Discussion | 8 | 02-22-07 10:39 PM |
| Viewsonic LCD(HDMI to DVI issue) | zetabass | Video Displays and Processors | 3 | 01-05-07 09:15 PM |
| HDMI audio support in receivers | John S | Home Theater Components | 5 | 12-09-06 05:00 AM |
