Question about multiple speaker setup - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss Question about multiple speaker setup in the Home Theater | Audio and Video forum; Question about multiple speaker setup Hi, Sorry if this isn't the right forum, it kind of fits into several categories. I'm looking for a good ...
Old 03-09-08, 06:42 PM   #1 (Link)
New Member
Alias: John
User: #17881
Since: Mar 2008
beanless is offline
Hi,
I'm looking for a good starting point for a home sound system, spending pretty much the minimal amount necessary. I recently bought an Insignia 200w 2.0 stereo reciever from BestBuy, but have a question.
On the back of the reciever, it says for A or B, speakers have to be 8ohms. For A+B, speakers have to be 16ohm. My problem is this- I want to hook up multiple speakers if possible, but most floor standing speakers are only 8ohms. I want floor standing speakers over 5.1 based solely on volume. Listening to movies would be secondary to blowing my ears out with metal.
I still can take the reciever back, and BB has a 500w 5.1 A/V home theatre reciever, would this work for me? I have two 2.1 satellite speakers that are 16ohm(not to use per se, just as a reference), so I'm guessing that the 5.1 system will require 16ohm speakers as well. I've seen posts on forums where people said they bought two recievers to hook up multiple speakers, is this my only option? Are there recievers that will power multiple(4) speakers?
Thanks for any help.
Old 03-09-08, 06:47 PM   #2 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
yourgrandma is offline
Re: Question about multiple speaker setup
Go for the surround receiver if you want to use multiple speakers. For what it's worth, though, I wouldn't worry a whole lot about blowing the amp running 2 pait of 8 ohm speakers unless you're really cranking on it.
Still, you'd be getting a lot more fun out of surround, rather than stereo, assuming of course you're into movies rather than music.
Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3
Old 03-09-08, 06:51 PM   #3 (Link)
New Member
Alias: John
User: #17881
Since: Mar 2008
beanless is offline
That was another question. I've heard people talking about 5.1 music, which is something I'm really not interested in. Would the 5.1 reciever distort the sound any? Front LR + Rear LR? It wouldn't make normal stereo music sound any different would it?
Thanks for the help, I tried calling BB today to ask some of these questions, and the guy was pretty much as clueless as me.
Old 03-09-08, 07:19 PM   #4 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
beanless wrote: View Post
Welcome to the forum
My question is: How much do you want to spend??? ... there is a lot of receivers that you can get, but it will depend if you want to use for movies and music or just music
If you decide to return the receiver (I suggest you do) ... you can get a better receiver at BB (Pioneer VSX517 or Sony DG510 for $206, or Yamaha RVX461 $300); they will perform better than the Insignia (specially Yamaha) ... all receiver can be used as 5.1 set up for movies, and if you want to hear music you can use it as 2.1
Good luck
I dont recommend Insignia 5.1 because it doesn't have the DTS decoder; there are some movies with DTS audio ... and believe me; you'll hear the difference between DTS and Dolby Digital
If you can wait for your receiver ... I suggest you to look online, you'll find better deals
You can start here at the forum ... http://www.hometheatershack.com/electronics-retailer/
Old 03-09-08, 07:28 PM   #5 (Link)
Alias: Randy
Loc: Minnesota, USA
User: #12896
Since: Oct 2007
Wow. There are actually receivers without a DTS decoder? I had no idea.
As for multichannel music, I enjoy it personally, but many do not. The most accurate way to listen to music is still a well thought out stereo setup. Although, as David said, a 5.1 receiver will do stereo as well. A dual purpose system can present certain challenges, but if you can only have one setup, what other choice do you have? I'd say return your receiver and do some serious shopping. Try to sort out exactly what you think you'll want from your system and use that goal to help choos the receiver that will best suit your needs.
Old 03-10-08, 02:13 PM   #6 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
There are some multi channel listening modes that now actually sound good. My Onkyo has some nice ones. Go with the 5.1 system for sure you wont look back.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears,
SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's
Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's, & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 03-10-08, 03:48 PM   #7 (Link)
New Member
Alias: John
User: #17881
Since: Mar 2008
beanless is offline
Old 03-10-08, 04:19 PM   #8 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
if you hook 8ohm speakers up in parallel you will get 4ohms but if you hook the same speakers up in series you will have 16ohms. Rarely will you find 16ohm speakers.
At low power levels (below 70db), many amplifiers will not be too fussy about the resistance they see. At high power levels (above 80db) like you would use listening to a movie, a mismatch will drastically reduce the capacity to produce audio power to the speakers and will cause damage to the amp due to heat caused by this. You generally can't hook up more than one speaker to each channel without problems.
Nintendo Wii
Old 03-15-08, 08:12 AM   #9 (Link)
New Member
Alias: Ron
Loc: Ontario
User: #17274
Since: Feb 2008
85FMGT is offline
[quote=beanless;86051]Hi,
/[quote]
A + B puts the 2 speakers in parallel that’s why they say to use 16 ohms speakers. The 2 16 ohm speakers will make 8 ohms which is what the amp wants to see. With a 5 channel receiver each amp is separate so 8 ohm speakers are fine. It’s like having 2 ½ stereo receivers. Floor standing speakers have nothing to do receivers with 2 or 5 amps. A lot of us have floor standing speakers for their full range capability. It’s what I prefer for two main channels. If you want them all around go for it. I think some one has confused you with Dolby Digital having something to do with a five channel receiver other than DD needs 5 channels.
I have a denon that has 5 channel stereo mode and it is better then using a/b since you can adjust the rear speaker levels, something you can't do with a/b. It’s very annoying if you can hear 1 speaker over the others. I would also suggest that you buy the same brand of speakers all around so the sensitivity matches. Having matching speakers makes balancing the four easier. If your in the mood for 2 channel stereo just hit the button on the remote.
I hate Dolby pro logic for music but love true 5.1 channel music, like from SACD’s or DVD-audio, 2 dead formats. I am hoping music will start using the high bit rate lossless compression on the Blue Ray disk.
Return it for one of the others mentioned and you can still use the a/b if you prefer 2 channels over 4 channels for stereo. Your best bet is to return the receiver and go to dedicated stereo store and speak to someone knowledgeable. The people at BB and stores alike know nothing about what their selling.
Ron
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
Looking for a 5-speaker setup for about $1500... jaball77 Home Audio Speakers 27 03-05-08 09:00 PM
Another multiple sub question Bob_99 Home Audio Subwoofers 8 12-21-07 07:48 AM
Question about multiple subs in REW pmandt REW Forum 6 08-11-07 04:12 PM
PB-2+ Setup Question jamesm42 SVSound 4 07-31-07 05:30 AM
question about setup Cheecho Home Audio Speakers 76 06-02-07 10:35 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
