| Home Theater Components audyssey worth it?Discuss audyssey worth it? in the Home Theater | Audio and Video forum; audyssey worth it? I am completing my DIY surround system, and will be getting a new receiver soon. I have digital cable, and ... |
| | #1 (Link) | |||
| audyssey worth it? I am completing my DIY surround system, and will be getting a new receiver soon. I have digital cable, and an upconverting dvd (no blu-ray yet) that both use hdmi cables. My tv only has one hdmi input, so switching is a must. Running seperate opticals is no big deal if the receiver is only pass thru. I need to know if audyssey should be on my feature list. And which version. EQ2 or Multi EQ. I have no test equipment at all right now. I will be buying refurb, and only have about 300 or so to spend. Thanks for any advice. | |||
| | #6 (Link) | |||
| Re: audyssey worth it? $300 is not enough to get even a good used receiver IMO. If your budget can't go up above $500-600 then Audyssey shouldn't be on your list of must haves. If you were looking at the Onkyo 605, that's not a bad receiver, but the 705 will also give you THX Select2 and an extra HDMI input which could come in handy. I'd wait and save an extra $200, you'll probably end up regretting it if you don't. That's part of the A/V addiction. I think www.accessories4less.com has the 705 refurbished for a good price. | |||
| | #8 (Link) | |||
| | Re: audyssey worth it? Audiogon could be your friend... keep a check on it. At the moment an Onkyo 805 is there for $570. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Audyssey MultEQ? | Alec.su | General Discussion | 3 | 03-13-08 01:40 PM |
| Thinking about Audyssey -- experiences? | Anthony | Home Theater Components | 1 | 03-13-08 01:37 PM |
| SVS PB12-Plus/2 with Audyssey | drdoan | SVSound | 1 | 03-11-08 09:50 AM |
| Filtering, Audyssey and what have you | Sniderhouse | REW Forum | 2 | 03-04-08 02:28 PM |
| Audyssey | Donald | Home Theater Components | 12 | 01-26-08 09:14 PM |
