| Home Theater Design and Construction Newbie - looking for some HT room adviceDiscuss Newbie - looking for some HT room advice in the Home Theater Installation and Systems forum; Newbie - looking for some HT room advice scyce wrote:
You were wondering how low I was talking...
Well without a riser it will be 87" or 7'3''. ... |
Views: 1144 - Replies: 37
| | #26 | |||||
| Re: Newbie - looking for some HT room advice Quote:
| | #27 | ||||
| Re: Newbie - looking for some HT room advice Hey Scott, what part of PA you from? Im also in PA, if your close enough your welcome to come view my HT room to get some ideas. As I mentioned in a previous post we have a very very similar layout for the room including that dang duct on the same side. | ||||
| | #28 | ||||
| Re: Newbie - looking for some HT room advice Yes thank you. Or install blocking in between the joists and attach the clips to that. THis will cause the drywall attachment point to be on;y perhaps 1/2" below the current joists. Almost no ceiling height loss. | ||||
| | #29 | ||||
| Re: Newbie - looking for some HT room advice I was looking at the Owens Corning site regarding sound insulation. They have a 'QuietZone Acoustic Sealant' that they recommend using around you stud base plates, top plates, outlets, etc... Couldn't I get the same effect using a standard non-hardening caulk for a lot less money... I'm sure Owens brand has some additional properties in it, but is it worth the extra cash? I like the idea of sealing these areas... Thanks... | ||||
| | #30 | |||||
| | #31 | ||||
| Re: Newbie - looking for some HT room advice A good 50 year Latex should work just fine. Bryan | ||||
| | #32 | ||||
| Re: Newbie - looking for some HT room advice True. However, if you look around you can find specialized sealant for the same price as the quality 50 year. | ||||
| | #33 | ||||
| Re: Newbie - looking for some HT room advice Absolutely Ted. If it can be found at a reasonable price, that's great. I have it for sale at reasonable prices but then shipping costs tend to get in the way. Bryan | ||||
| | #34 | |||||
| | #35 | ||||
| Re: Newbie - looking for some HT room advice I bought a bunch of the "silenseal" acoustical caulk when I bought my green glue. Thankfully Charlotte has a distributor so I was able to pick it up and save shipping (adds up quick when you are buying cases of the stuff ) | ||||
| | #36 | ||||
| Re: Newbie - looking for some HT room advice You either have shipping or local sales tax. Tough to avoid both | ||||
| | #38 | ||||
| Re: Newbie - looking for some HT room advice Slow and steady... Here is an update on my project... I am finishing the rest of the basement at the same time so this is going pretty slow.. I put up the final wall tonight.. Now it's time to get the Electrician... Here is some pics.... Last edited by scyce; 07-08-09 at 10:57 PM.. | ||||
