I will start this thread with the latest pics. First, all the construction is DIY and the equipment list is below.
Receiver: Onkyo TX -SR605
SD DVD player: Sony 5 Disc (need to check model #)
Game System: XBOX 360 and Modified XBOX 1 and PS2
Blue Ray DVD: Soon to be Sony PS3
Speakers : All JBL Venue series
2 X Stadium 3-WAY 8" Dual Speaker
1 X Voice 2-WAY 5" Dual CC Speaker
2 X Balcony 2-WAY 4" on wall speaker
1 X SUB 12 12" 500w Powered Subwoofer
Projector: Mitsubishi HC 4900 1080P
Screen: DIY Blackout Cloth 86" wide
Not 100% complete, but close. Thought I would put these in the beginning. Some panorama shots.
I will post progress pics in subsequent posts. Enjoy
The build, so far, has taken a little over 6 months of time. Each month I gave myself a goal and budget not to go over. I was working with a room already finished, but I rearranged some walls, removed some carpet, and built a false screen wall. I reused everything I could from any tear down including wood studs, drywall, insulation, ceiling tiles, etc. Below is what the room looked like initially.
I also have some Stadium on my HT ... I didn't see them in the picture (I'm sure they behind the false wall, Right??? )... I do see the Balconies, you still have the silver grill on them :bigsmile:
If you want to change the color (to blend better with your room) ... I used Dye to change the color of the grill (see picture below) ... there is also a forum for just JBL owners here (http://www.avsforum.com/avs-vb/showthread.php?p=13499431)
You are correct - LCR and Sub behind the false wall. I debated the silver grills and I may dye them eventually. I absolutely love my JBL's - they may not be audiophile grade but to me they sound fantastic! Thanks for the link.:T
The next steps were painting the walls, removing all the ceiling tiles, running new electrical, installing new outlets, sconces, and recessed lights above the screen.
Wall color paint is a deep plum.
Ceiling tiles out - to run electrical and to paint them
Riser construction consisted of 2X10 outer frame and 2X6 interior joists - 16" on center.
The riser was wired with 4 outlets: 2 on the side, one above the step, and one in the front. Insulation was placed under and in between the joists.
3/4" plywood was screwed down on top. Carpet tacks were installed on the edges of the top an the bottom of the sides. Carpet padding was stapled to the top and the sides.
Berber carpet remnant was purchased from Lowes, carpet stretcher rented from a local hardware store, and the carpet was installed - using crown staples under the lip.
Next up is the ceiling tiles and acoustical treatment of the walls ....
The next set of photos are the ceiling tiles, acoustical treatment/fabric on the walls, and projector column.
Painted ceiling tiles black - I eventually painted the metal suspension frames black also.
Fabric is a black faux suede with a bit of design in it. I got this from a local fabric warehouse.
I placed rigid fibergalss on the wall, the used furring stripps above and below the fiberglass to stretch the fabric around. I went up ~ 36 inches on all walls.
The column for the projector in the back
Another small column on the side wall.
Next set of photos is the pergo flooring from the entry ...
There really is no problem with the reflections. Behind that wall is a bathroom, and there was a water line and waste line the were unused, so I added the sink. The pictures do not show it well, but your not that close to it when sitting.
Thanks for the support and positive feedback everyone.
I have completed my concession stand build. I built this from scratch using plywood and particle board. The colors used are to match the decor of the room (Black and gold). All I need is the popcorn Machine, Fridge, and Candy. The popcorn machine is on its way! Here are pics below.
Photos of the final product of the concession stand below - complete with popcorn machine, candy, and fridge. We love it.
Related Threads
742.3K posts
170.9K members
Since 2006
