7.1 in a 14'X18' Room? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss 7.1 in a 14'X18' Room? in the Home Theater Installation and Systems forum; 7.1 in a 14'X18' Room? Hello, I an designing my home theater room and would like to use Dolby TrueHD 7.1 Suround Sound for BluRay ...
Old 04-13-08, 11:14 PM   #1 (Link)
New Member
Alias: Matt
User: #19592
Since: Apr 2008
mlacek is offline
Hello, I an designing my home theater room and would like to use Dolby TrueHD 7.1 Suround Sound for BluRay Movies. The dimensions of the room are 14' W X 18' L. I would like to go with a 123" projector screen. My main concern is the 7.1 speaker placement, specifically the two rear speakers having enough room behind the seats. How far back do they need to be? Thanks for any help you can provide...
Old 04-14-08, 03:46 AM   #2 (Link)
Alias: alan monro
Loc: Melbourne Australia
alan monro's Avatar
User: #465
alan monro is offline
Re: 7.1 in a 14'X18' Room?
mlacek , gooday , I have a 7.1 in an 18x14 room . no problem. your seats need to be 4ft from the rear wall . My screen is 106" . 120" may be a little on the large side . A small room that size needs to have have a lot of absorption in it . like carpet , rugs , drapes over the walls etc . Let us know how you go , Kind regards , Alan Monro .
Old 04-14-08, 06:15 AM   #3 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Agreed. Place your seats properly first and then set the screen size. Setting screen size first can result in lots of problems (and I'd agree that's a bit big for that room)
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 04-14-08, 11:22 AM   #4 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Agree on the screen size issue as well.
I've seen a screen that took over the entire wall with only about 8" on each side. It looks incredible, however, the owner is stuck with using small speakers all around (which was fine at first, but now he wants to upgrade).
Get your seating right and then pick the size. There are a bunch of calculators online, or you can do the hand test. Sit in the listening/viewing position. Put your hands in front of you at full arms length, spreading your fingers. Touch your thumbs together. The pinky to pinky distance as seen on your wall is close to your ideal screen size. It gives good coverage, so the screen fills up most of your field of view, without having to turn your head to see everything.
A friend of mine from college who went to film school afterwards taught me that. It also works for computer monitors.
Old 04-14-08, 01:02 PM   #5 (Link)
Alias: George
Loc: Nova Scotia
User: #15981
Since: Jan 2008
Rambo4 is online now
I also have a 18 x 14 room, and have gone with a 92" (7.67') screen with the HD projector over my head. I sit back about 12 feet, and find it perfect for my viewing and speaker positioning.
Watch out for bass nulls in that area though... trust me.
Old 04-14-08, 03:50 PM   #6 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Placing your rear speakers about 4 ft apart and 4 ft behind the back seats is the best placement. I also echo the screen size recommendations I use a 96" screen and sit back 12 ft from it and find that size just right.
Home theater:
Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD XA2, Samsung BDP1400 BluRay, Pioneer LD, Sanyo Z2 projector
Two Channel system:
Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20, Nintendo Wii
My Webpage
Old 04-15-08, 04:01 PM   #7 (Link)
Alias: Zip
Loc: Canada
MatrixDweller's Avatar
User: #10408
Since: Jul 2007
MatrixDweller is offline
They say the prime seating position is about 1.5 screen widths back from the screen. With a 123" screen you'd be sitting about 15 feet back. Any closer and it would start feeling like sitting in the first row at the movie theater. You'd end up having to turn your head to see everything and at the end of the movie you'd wonder why your neck hurt. You also can start seeing pixelization in 1080i projectors the closer you get. Size the screen to where you'll have your seats.
Here is a link to a good online viewing distance calculator
http://myhometheater.homestead.com/v...alculator.html
Old 04-16-08, 05:54 AM   #8 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
PLEASE don't think of it that way. You don't move the seat to fit seating distance. You put the seat where it needs to be and then purchase the appropriate sized screen.
Also, the 1.5 width is a very rough rule of thumb. I prefer to use the 36 degree minimum included viewing angle. Where you go from there depends way too much on screen type and projector quality to make any other assumptions.
Bryan
Bryan Pape
GIK Acoustics
Old 04-16-08, 04:45 PM   #9 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Anyone is just posting what he likes.... Just place your seats then chose your screen size. My advice is big screens have a lot of WOW factor but PQ degrades with size as well. You should consider full definition and a good projector if you want anything bigger than 120" if you're about 13 ft-15ft.
THX recommends a max 40 degree and a minimum 36 degree. 40 degree make 150" from 15 feet....make the calculations for 36 degree.
I am having 106" from 10.8 ft and that makes about 39 degree viewing angle. Anything static and I feel the screen is too small. Transformers or Saving private Ryan make me feel I can't stand any bigger.... But sure I needed 1080p resolution ... Check my signature and decide
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
Room-in-room and acoustics atledreier Home Theater Design and Construction 5 12-09-07 03:50 PM
Calculating Room Modes - Odd Shaped Room Bob in St. Louis Home Theater Design and Construction 25 02-20-07 12:15 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
