Hornsub firing through wall? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss Hornsub firing through wall? in the Home Theater Installation and Systems forum; Hornsub firing through wall? Setting up my theater, and was thinking about cutting a hole in the wall to an adjacent unfinished laundry room ...
Old 04-17-08, 01:55 PM   #1 (Link)
Alias: Dave
Loc: Bloomington, Illinois
User: #9307
Since: Jun 2007
chopperguy99 is offline
Setting up my theater, and was thinking about cutting a hole in the wall to an adjacent unfinished laundry room to allow my horn subs mouths to exit into the room. Then fabbing up a nice matching grill. It would be the right side wall, a little less than a foot from the corner. It is actually 2 mirrored stacked horns with the mouths coupled in the middle. The opening would be about 16" wide, and around 30" tall, and starting about 16" off the floor. This would save valueable floor space. My room is 12w, 16l and 7h. Need to know if anyone sees anything wrong with this setup. I am worried about the wall these will be firing through rattling like crazy. The wall is drywall on one side, and just the studs on the other. Any cheap tips for minimizing the vibration? I really want to try this, cause it would be a very clean setup. Thanks!
Old 04-17-08, 01:58 PM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is online now
Re: Hornsub firing through wall?
It could work if you can seal the horn to the wall. Otherwise, it's going to have additional resonances from the other space. Also, I'd want to do a lot of experimentation IN the room to finalize the best position for it before cutting holes in my walls only to find out that the sub would yield better and smoother response another foot over for instance. Once you cut a hole, you're kinda limited in fixing bass anomolies via sub movement.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 04-17-08, 02:03 PM   #3 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is offline
You could add horizontal bracing between the studs to stiffen the wall and then run a bead of liquid nails where the studs and bracing meet the drywall. What are you using for horns?
We're all in this together!
Old 04-17-08, 02:32 PM   #4 (Link)
Alias: Dave
User: #9307
Since: Jun 2007
That sounds easy and cheap! Worth a try.
I am using 2 Fitzmaurice Table Tubas.
Old 04-17-08, 02:42 PM   #5 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is offline
I've heard of them. What sub did you use?
Old 04-17-08, 03:03 PM   #6 (Link)
Alias: Dave
User: #9307
Since: Jun 2007
I used 1 MCM 8" sub in each. They are pricey at 35 bucks each.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
New guy question on down firing woofer arrangement martyh DIY Subwoofers 4 04-04-08 06:37 PM
Side Firing in Sonotube? bnw DIY Subwoofers - Sealed and Ported 42 11-25-07 11:21 AM
Forward firing, downfiring or sideways? Chrisbee Home Audio Subwoofers 7 02-08-07 01:32 AM
down firing speakers...know of any? scott DIY Subwoofers 3 01-24-07 02:19 PM
Forward vs downward firing subs... Deeje Home Audio Subwoofers 2 10-22-06 11:34 AM
Mach 5 Audio
