Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Noise traveling between two rooms connected by glass exterior wall...help?
Discuss Noise traveling between two rooms connected by glass exterior wall...help? in the Home Theater Installation and Systems forum; Noise traveling between two rooms connected by glass exterior wall...help? I need advice on how to keep noise from traveling between two rooms that are seperated by a drywall parrtition ...
Views: 351 - Replies: 2
Old 05-28-08, 04:18 AM   #1
New Member
Alias: bledsjo
Loc: fl
User: #21236
Since: May 2008
  bledsjo is offline
I need advice on how to keep noise from traveling between two rooms that are seperated by a drywall parrtition but connected by the same glass exterior wall (the previous owner built out a room doing the work himself). These are the family room and our master bedroom. My wife complains that she can hear casual conversations like they're in the same room and I'm not sure where to begin. If it is the glass, should I add a sealant to the joint where the drywall meets the glass? Would curtains help...?
Old 05-28-08, 01:10 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Noise traveling between two rooms connected by glass exterior wall...help?
I suspect that it is several problems.
1) no insulation inside the wall that was built.
2) glass is a great transmitter of sound so some sort of chalking or insulation should be placed where the wall meets the glass.
Heavy Curtains may help a little but its best to address the problem directly.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 05-29-08, 11:24 AM   #3
Alias: Zip
MatrixDweller's Avatar
Loc: Canada
User: #10408
Since: Jul 2007
  MatrixDweller is offline
Tony is right, the glass is probably conducting the vibrations along it's entire width from one room to the next. You would almost have to short circuit that and cut the glass where the partition is and seal it with caulking/silicone. You would also want to seal the partition wall where it meets the glass.
You might want to check out how the top of the wall joins to the ceiling as well. Insulation inside the wall will help soundproof it further. It's possible the previous owner used 1/4" drywall (paper thin wall). You could add a layer of 1/2 or 5/8" drywall if that's the case, but that would be a lot of work.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
