Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Just starting it
Discuss Just starting it in the Home Theater Installation and Systems forum; Just starting it Ok , here goes ... fairly small room , 11 x 18 , but will be dedicated for htr .. ...
Views: 351 - Replies: 2
Old 06-20-08, 09:19 AM   #1
Alias: points
Loc: Fort McMurray
User: #22163
Since: Jun 2008
  Pointswest is offline
Just starting it
Ok , here goes ... fairly small room , 11 x 18 , but will be dedicated for htr .. from what I've been reading in the posts so far , I will be painting the front wall and ceiling low lustre black. The walls, one is already a dark cherrywood ,so thinking dark burgandy or other paint close to the wood color for the other side and back wall.There are three windows , so far my plan is to build 2 x 2 frames larger than the windows , cover the frames with a Dark Grey fabric and then put a layer of ceiling tile inside the frame to cut out the light and provide a little more sound barrier. I want to have two rows of recliner seating
first row 11 1/2 to 12 feet from screen second row will be 8 inches higher and 15 to 16 feet from front.
Screen size .... I was thinking around 110 to 116 diag.
Old 06-20-08, 09:45 AM   #2
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Just starting it
Sounds pretty good to me. The only thing I'd question is a screen that big in a room that narrow. That's going to push your speakers way too close to the side walls.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 06-21-08, 02:59 PM   #3
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Pointswest wrote: View Post
Well ... bigger than mine 9'x18'x8'
...There are three windows , so far my plan is to build 2 x 2 frames larger than the windows , cover the frames with a Dark Grey fabric and then put a layer of ceiling tile inside the frame to cut out the light and provide a little more sound barrier...
Will they be permanently attached to windows or will be possible to remove them when not in use??? ... if it were me, I prefer to be able to remove them
... i want to have two rows of recliner seating first row 11 1/2 to 12 feet from screen second row will be 8 inches higher and 15 to 16 feet from front. Screen size .... I was thinking around 110 to 116 diag.
You have to consider the distance between back wall and second row ... mine is just 1' from the wall, and that doesn't help with the acoustics because is not the ideal distance
Have fun with your project
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
