Slaughter House Cinemas (Project Thread) - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss Slaughter House Cinemas (Project Thread) in the Home Theater Installation and Systems forum; Slaughter House Cinemas (Project Thread) bpape wrote: I'd say that's a steal. Signs of the weak economy I guess. Bryan Or a good negotiator...
Old 07-18-08, 01:42 PM   #26 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Re: New basement HT Posting progress photos
bpape wrote: View Post
Bryan
Old 07-18-08, 03:23 PM   #27 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Well, that too
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 07-18-08, 04:34 PM   #28 (Link)
Alias: Carl Slaughter
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
carls64 is offline
Can someone tell me that since it does not matter how far back I place the projector, based on the projector central calculator for an 120 screen I can be as far back as 24'6" for that size screen. That places the lens just inside the back wall. Wonder if I can place it in the wall or behind it a bit and project the full length of the room? I have an 11" 1/2" soffet to go around and probably have to be careful that peoples heads do not obstruct the view. But the Panasonic 200U has a movable lense to compensate for placement. The room is at 6'7 1/2" where the duck is, that is from about 14' and extends back 5' (Finished). Problem is it says (riser calculator) that I need to be up 15" (at least) for the rear seating. Let see, that may not work unless the dispersion is minimal in the first 10 feet. Not sure if I am better with the camera in front or above the first row seat of behind or above the rear row seating. This is all making me crazy!
Old 07-18-08, 04:35 PM   #29 (Link)
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
carls64 is offline
salvasol wrote: View Post
A friend of a Nephew ;-)
Old 07-18-08, 04:45 PM   #30 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Again, don't push all the way to the edge of the zoom. The other option is to do a false wall and bring the screen forward 2'. That MIGHT let you do what you want and stay away from the edge.
Another option is to build a soffit and hide the PJ in there. That'll gain you some room and an easy way to hide wiring.
Bryan
Bryan Pape
GIK Acoustics
Old 07-18-08, 05:04 PM   #31 (Link)
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
carls64 is offline
Ok here is an updated diagram, with measurements. I am starting to get a little concerned about the projector location as if I place it all the way back to the 24' mark (23' if I move the wall back a foot) that the dispersion will intersect with peoples heads! Take a look and give me your recommendations. (North is the side with the entry door (top))
Ht Room Layout Before Construction
Click the image again to get a full size view.
Old 07-18-08, 05:15 PM   #32 (Link)
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
carls64 is offline
We may end up bringing the east wall (screen wall) in around 11-12" to enclose the drain pipe, that will shorten the room by nearly a foot.
I am working with a very limited ceiling clearance, the soffet is killing me brings down the ceiling to 6'7 1/2" then I have to worry about clearing peoples heads!
Old 07-18-08, 05:47 PM   #33 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Soffit in the back will be behind the seating area hopefully so headroom isn't an issue.
Bryan
Bryan Pape
GIK Acoustics
Old 07-18-08, 06:08 PM   #34 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Soffit in the back will be behind the seating area hopefully so headroom isn't an issue. Bryan
What about the soffit above the first row???
Old 07-18-08, 06:09 PM   #35 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Why would you want one there? Soffits generally are only around the perimeter of the room.
Bryan
Bryan Pape
GIK Acoustics
Old 07-18-08, 08:52 PM   #36 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Why would you want one there? Soffits generally are only around the perimeter of the room. Bryan
You see what happens when you don't explain things???
What I meant to say was, to build a box to install the projector or maybe just hang the projector avobe or just behind the first row, so he doesn't have to worry about people banging their heads on the projector ...
Old 07-19-08, 10:58 AM   #37 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
lol. Gotcha. I just read it wrong. That's doable I guess. I was just trying to facilitate it going back farther as was mentioned.
Bryan
Bryan Pape
GIK Acoustics
Old 07-19-08, 01:48 PM   #38 (Link)
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
carls64 is offline
:What I meant to say was, to build a box to install the projector or maybe just hang the projector above or just behind the first row, so he doesn't have to worry about people banging their heads on the projector ...
That looks like its going to be the best position as I am going to move the drain, as seen in this shot:
As far back as I can get it, that will take up with furring (2x4 on side) about 6" then I can get back 15' to clear the I-Beam and duct work HERE as there is about 15" where I can place the mount. This will put the front row right below the projector. HERE you can see the detail of the location where the projector will be mounted, a front view facing away from the projector the middle of the room is where the floor joist that is in the middle of the photo HERE. I am still debating on bringing the wall forward around the drain or just boxing it in. If I measure so my eye level (36" in my sofa, that I am using currently for the front row) and I measure 1/3 up on the screen that puts the screen about 16" off the floor! With the top of the screen at 75" That puts the top of the screen right beneath the soffet for the drain, and would I suppose make a nice top valance for the screen?
Does anyone know is the measurements on the screen take in account of the frame, or is the 120" for example not include the frame? So if the screen is 59" its actually 61" for a 2" frame, and 111" for the width, if that is what it is then I will be only 14" from the floor and not perfectly 1/3 up on the screen at eye level.
If I knew this was going to be this hard I think I would have thought twice about starting this LOL.
I received my projector Friday! along with the mount and cable si I may hook it up and see what things look like ;-)
Old 07-19-08, 02:19 PM   #39 (Link)
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
carls64 is offline
carls64 wrote: View Post
Looks like the ezFrame Screen has a 3" frame so that changes things yet again, not instead of 59" high the total screen size is 65" so, if I get the drain against the wall and up against the ceiling I have the frame against the top, I have the fur down 2" for the water pipes, that leaves me with a 7'5" ceiling but the soffet around the drain will be only 6" so I am going to just move the pipe against the wall, that will shorten the room by 6" but at the 15' mark I will be in good shape to mount the projector, and be at about 1.65 of 2.0x on my zoom keeping me back 35% away from my zoom? Does that sound right?
Old 07-19-08, 03:52 PM   #40 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
... Does anyone know is the measurements on the screen take in account of the frame, or is the 120" for example not include the frame? So if the screen is 59" its actually 61" for a 2" frame, and 111" for the width, if that is what it is then I will be only 14" from the floor and not perfectly 1/3 up on the screen at eye level....
I dont think it uses the frame around the screen ... I'm sure that you have to measure from the point where you'll get the picture ... we'll wait to see what the experts say
...If I knew this was going to be this hard I think I would have thought twice about starting this LOL.... ;-)
It'll be worth it ... when you start enjoying your new HT you'll forget all this troubles.
Just be prepared because after you finish the room ... you'll keep upgrading/changing everything again ... this is a non-stop hobby
Old 07-19-08, 08:23 PM   #41 (Link)
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
carls64 is offline
My wife is going to kill me
Old 07-19-08, 08:26 PM   #42 (Link)
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
carls64 is offline
Well the pipe is moved, but I forgot you have to have some room to get the fittings on so I was able to finagle 1/2" less than what I hoped for, the wall will now be 6 1/2" from the concrete wall, so I am only 1/2" off from what I wanted ;-)
I have to get rid of the old electrical boxes on the south wall now so the contractor can start framing on Monday.
I hope to set up the projector tonight and see where I stand in regard to a mount point. And just to see how it it works ;-)
Old 07-20-08, 01:49 PM   #43 (Link)
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
carls64 is offline
I took some more photos last night of the room and equipment, HERE (page 4) is where O moved the drain pipe, so I am bout 3/4" from the wall now so the contractor can build the wall in front of it about 6 1/2" finished out. This will allow me to be withing the sweat spot for the projector at about 15'6" and to clear the I-Beam and duct work (in between).
I also took some photos of the "gear" and the Panasonic 200U Projector. HERE Also I was able to take a few shots of the images produced by the 200U, I placed a all white Studio backdrop made of some sort of flat opaque material, not ideal for projector screen use, with that said I think the picture looked great! Then I realized I was watching 480p resolution! Then I turned it to 1080i output (From a DishTV HD Receiver) and I was blown away! I have a Samsung 1080p 50,000:1 52" TV in the living room, and I have to say Even on this imperfect screen I had made I was very impressed, no pixilation, crystal clear even at about 3 foot away! I can't wait to get the screen and see what it looks like then.
I think everything is read for the contractor to come in Monday and start framing. I will have some more photos tomorrow!
Old 07-20-08, 02:31 PM   #44 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
Congratulations ...
Those pictures look nice ... by the way: What size was the picture??? ... same size that you're planning on using??? ... I think that you can play with your equipment to find the best size
Old 07-20-08, 02:49 PM   #45 (Link)
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
carls64 is offline
Congratulations ...
140" bigger than my screen so I didn't watch it long so I didn't get spoiled
I think I am going to be alright with my projector position based on what I saw, As I have a good amount of zoom (both directions) from that position. I am somewhat Limited with my seating option using couches but it is all I have right now
I will keep the pictures coming!
Old 07-21-08, 09:45 AM   #46 (Link)
