Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Slaughter House Cinemas (Project Thread)
Discuss Slaughter House Cinemas (Project Thread) in the Home Theater Installation and Systems forum; Slaughter House Cinemas (Project Thread) That is looking good....
Views: 10189 - Replies: 329
Old 08-15-08, 06:21 PM   #176
Alias: Steven
thewire's Avatar
Loc: Midwest
User: #9828
Since: Jun 2007
  thewire is offline
Re: Slaughter House Cinemas (Project Thread)
Old 08-17-08, 10:58 AM   #177
Alias: Carl Slaughter
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
thewire wrote: View Post
Thank you!
Work progressed Friday and part on Saturday for the riser. I have photos of the progress posted:
http://www.itsallbutstraw.com/galler...g2_itemId=7239
I made a small mistake but I caught it before I closed up the top! I originally placed the insulation paper/lip over the top of the boards where I was going to secure the plywood. BAD idea I wanted to glue everything and the glue would have just stuck the paper to the bottom of the plywood
That was fun pulling out about 100 staples out , it was even worse up by the front seats as I had already anchored the riser down the the floor!
I have the second layer down I had to have Home Depot cut my plywood down into 2x8 sheets to get it home, so I have a few more seams than I wanted, but they are all glued and screwed so they should be ok. Two layers one going horizontal the other going vertical, all glues down with liquid nails and screed every 6 " or so. This will make the surface a good point to mount the chairs.
I am going to use the router to round the corners off the edges and then try to get the carper down on it and then I can mount the seats. More photos later tonight!
Old 08-18-08, 09:00 AM   #178
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
The riser is done and I have the standards and backs installed for the back row (3). I should recieve the other 2 seats today so I can complete them. I wrapped the riser in a piece of carpet I had left over from the floor. I just stapled it to the bottom edge and used carpet tape on the top.
Riser Photos
I will eventually put some sort of molding or maybe even use my left over baseboard to cover that and it will look a little better.
I have already tripped over it, so something will have to be done to make it more visible
Also I fount a nice looking reprint of the original Star Wars movie, that was framed for $40 at Block Buster. They had a nice selection of posters just not all the ones I wanted These are painted or somehow covered with something that is no reflective and textured I think the look really nice for the price that is.
Next is the baseboards and then I will be done for a while. Watches "The Bank Job" last night, almost fell asleep through the first half of it thought, It got a little better twords the end.
Old 08-18-08, 04:02 PM   #179
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Nice!!!
After looking at the pictures, I think you have a couple of options for some lights
1. Use raceways and an extension to the riser ...that way you can install a rope light
2. Same as 1, but you can connect the extension from the AV rack (through the wall) and cover the cable with a cable organizer.
3. Is that a night lamp on the outlet??? ... you can use a couple to light the path to the riser and seats (I have a couple of those in my HT, and is enough to see the way)
Old 08-18-08, 04:50 PM   #180
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
salvasol wrote: View Post
Why yes, yes they are I have two of these night lights.
(Just realized they say, Theater lighting!)
Thinking of buying two more for the other side and I am done ;-)
I may paint them the same color as the wall and you would never know they were "plugged-in"
Old 08-18-08, 05:26 PM   #181
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
carls64 wrote: View Post
Maybe just some reflective tape on the edge of the riser to be safe ... and watch your step
Old 08-21-08, 01:17 PM   #182
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Just an update, I think I am pretty much done for now, more picture to follow once I have the room all cleaned up. I have the base boards installed and the seats all installed. So now I need to do some cleanup and touch up work on the paint. With the lights down low (Wall sconces) and watching a movie, you can't see the speakers up front so at this time I am going to hold off on the enclosure around the screen for now. I am all but tapped out now, and starting to feel a bit under the weather. Now I can start tweaking my sound and enjoying the new theater! So thanks again to everyone for your help and support. I will be here off and on, but probably not the frequency I had during the construction. If anyone wants to contact me feel free to do so, I will monitor my emails and my IM programs. I will upload pictures soon of the finished project.
Old 08-21-08, 01:23 PM   #183
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Just one more thing!
If anyone knows a way to make or resurce to put together a "Intro" for your HT let me know, I have Apple equipment and use Final Cut Express, Aperture and iPhoto, iMovie and iDVD.
Probably something stat has sights and sounds and allows me to "brag" on my Theater when company comes to watch movies.
I plan on putting it on my PS3 and depending on the movie, I will "rip" the movie to the PS3 or my Apple Mac Pro's Raid disk and I use MediaLink to stream media from my Mac to the PS3, I can place it there or combine media for a seamless experience ;-)
Old 08-22-08, 09:32 PM   #184
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Here are the ending photos of the project. I have a number more things I "want" to do, like the shadow box around the screen to conceal the speakers. Now its time to do some sound tweaking. I am going to download REQ and get out my RS Sound meter and give it a go ;-)
Boy a photo flash sure points out the imperfections in the finish work don't it :-(
Current ending project photos
Old 09-22-08, 06:09 PM   #185
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Well it has been a while since I reported in. I am still around. I have recently ordered a pair of eD A2-300 subs, and contemplating a complete speaker replacement as well. Been watching a number of movies, and also purchased a BFD 1124, I have it hooked up and from what I can tell by my REW measurements I have it tweaked pretty good, the while system sound great, but it laks the base I think I should have, hence the purchased of the A2-300's I will have further posts and photos when they arrive in 4-5 weeks :-(
Old 09-22-08, 07:29 PM   #186
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
... I have recently ordered a pair of eD A2-300 subs, and contemplating a complete speaker replacement as well. ...
Upgrading so soon??? ...
I'm glad you're happy with your project ... like some say: "This is a non-stop hobby"
Do you have any speakers on mind??? ... remember that you can also get nice used speakers; I've been checking on ebay, Audiogon (high end speakers that sells cheap), craigtlist, etc. if you want to go that route
Do you want another suggestion (to spend more money)??? ... get an external amp for your front speakers; I got one that I already installed but I need to do the final calibration of the system ... and as far I can tell right now; is making a big difference
Old 09-22-08, 07:50 PM   #187
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Yes as a matter of fact, I am considering a complete set of eD speakers, using a pair of towers for the mains. But I may still wait until the subs get here, that will be another $1000 that of course I don't have LOL
I have been watching Craigslist and eBay but so far found nothing I am sure about.
Old 09-22-08, 07:54 PM   #188
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Oh I forgot I did take some more pictures of my mounted movie posters, that I forgot to post here:
http://www.itsallbutstraw.com/galler...g2_itemId=8216
Someone was asking about the movie posters that Blockbuster sells, so I took some closeups of those, as well as of the rest of the mounted ones. I didn't get one of the Dark Knight poster I have on the door leading into the room.
Old 09-22-08, 08:01 PM   #189
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
... I am considering a complete set of eD speakers, using a pair of towers for the mains. But I may still wait until the subs get here, that will be another $1000 that of course I don't have LOL
Besides eD ... Do you have anyting on mind???
You can start will a really nice towers, and upgrade the rest later ... here is just an example
Old 09-22-08, 08:12 PM   #190
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Found a pair of Infinity RS5's for around $100-150 so far ;-) But the eD seem pretty good for the price, plus they are shipped to my door for free ;-)
Old 09-23-08, 04:39 PM   #191
Alias: dradius
dradius's Avatar
Loc: Louisville
User: #25570
Since: Sep 2008
  dradius is offline
Great thread. Enjoyed reading through it. I've considered the eD towers myself. If you go that route be sure to let us know what you think about them.
Old 09-25-08, 06:48 PM   #192
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
I received a note from eD that my Subs are under construction ;-)
09/22/2008 Box Under Construction
Old 10-01-08, 04:17 PM   #193
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Talking Re: Slaughter House Cinemas (Project Thread)
09/30/2008 Awaiting Paint
Old 10-02-08, 06:16 PM   #194
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
10/02/2008 In Paintroom
Old 10-02-08, 06:36 PM   #195
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
What are you doing there??? ... .
(P.S.: Just joking, I know you're talking about your new eD toy building process )
Old 10-02-08, 06:40 PM   #196
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Come on in the air is f....iiiiinnee
Suffering right now from a broken clavicle. waiting till tomorrow to see what the doctor has in mind for the repair ;-) based on the x-ray looks like surgery to me ;-) It hurts so bad!
Old 10-02-08, 07:01 PM   #197
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Sorry to hear that ... believe me I feel your pain
When I was young (many moons ago 1980-1981) same thing happenned to me playing soccer
I'm form El Salvador (Central America), our hospitals used rudimentary tools to do some repair; what they used was some pantyhose (tights) that they filled with toilet paper ... then they used that under my arms and around the neck (forming an eight, that's how they called); after a couple of months I went to the hospital again so they can tight the knott again until my bones fused
Nowadays, if somebody pass a finger where the clavicle broke ... they can feel that bump, because one piece is on top of the other
I'm sure that they will use some kind of nail to level the bones if they're broken ... which is a good thing.
Good luck and relax.
Be prepared to sleep uncorfortable for a couple of months, I remember that I can only sleep face up, not on my sides of face down
I didn't mean to scare you ... okay
Old 10-02-08, 07:09 PM   #198
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Oh believe me you aint telling me anything I don't already know LOL. I am in a similar figure 8 brace, but hope the orthopedic Doctor will give me a better answer, the bone is defiantly broken in two and over lapped, looking at the x-ray. I can sleep on my side believe it or not its a tad bit more comfortable than on my back. 4-6 weeks of this is going to have me crazy!
Old 10-02-08, 07:20 PM   #199
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
you'll be fine in no time
By the way ... How this happenned??? ... working, playing, accident, ... just a little curious
Old 10-02-08, 08:26 PM   #200
Loc: Bethalto, IL
User: #22904
Since: Jul 2008
  carls64 is offline
Ready for this, fell out of a golf cart doing 25 mph, landed right shoulder first on the ground.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
cable, equipment, finish, home theater, wire
