| Home Theater Design and Construction Slaughter House Cinemas (Project Thread)Discuss Slaughter House Cinemas (Project Thread) in the Home Theater Installation and Systems forum; Slaughter House Cinemas (Project Thread) carls64 wrote:
Ready for this, fell out of a golf cart doing 25 mph, landed right shoulder first on the ... |
Views: 10190 - Replies: 329
| | #201 | |||||
| Re: Slaughter House Cinemas (Project Thread) Quote:
![]() Were you racing in the golf course??? ![]() I landed on my left ... I was 15yrs old and just started playing semi-professional, the other guy tripped me when I was turning and preparing to run (he was a veteran) ![]() | |||||
| | #202 | ||||
| Re: Slaughter House Cinemas (Project Thread) I must say Carl... you did a very nice job on the theater. ![]() | ||||
| | #203 | ||||
| Re: Slaughter House Cinemas (Project Thread) Thanks Sonnie! It was the best job I could do with the money I had and the time I had to do it ;-) | ||||
| | #204 | |||||
| Re: Slaughter House Cinemas (Project Thread) AH I can almost taste my eD A2-300's now Quote:
![]() Now I just need to decide if I want to purchase some front mains LCR for about $590 more I can get their A6-6T6 Towers and a A6-6T6 MTM Center channel speaker ![]() | |||||
| | #205 | ||||
| Re: Slaughter House Cinemas (Project Thread) Oh boy I pulled the trigger on a complete 5.0 set of speakers, from eD they will be here Friday so this weekend I will have to start all over again calibrating my system ;-) | ||||
| | #206 | ||||
| Re: Slaughter House Cinemas (Project Thread) My two A2-300 are sitting in my garage waiting for me to get home, lets see 12:17 I have 5 more house before I get home ![]() My A3-5TC, A6-6T6-MTM, and A6-6T6-Towers should be here Friday! Nice to live only 2 days from eD ![]() | ||||
| | #207 | ||||
| Re: Slaughter House Cinemas (Project Thread) ... and is nice to have money too ![]() Congratulations ![]() | ||||
| | #208 | ||||
| Re: Slaughter House Cinemas (Project Thread) Well it is loaned money, but I suppose money nevertheless ![]() They are here, here are the pictures! I was also notified that my Full range eD speaker arrived, so I hope to get those in and hooked up tonight! | ||||
| | #209 | ||||
| Re: Slaughter House Cinemas (Project Thread) The new eD Full Range 5.0 system in in, had a friend help me get them down there and set up. I briefly calibrated the LCR set along with the subs, and I have to say I can't believe what I was missing in regard to the fidelity. I watched a couple Demo DVD I have been collecting and I could not believe my ears! The dynamic range of sound I have now is simply superb! It was like going from internal speakers on your TV to a live performance. Now I need to do some calibration with REW and the BFD and see where I am at. Here are the un-boxing photos and setup. eD does a great job of packaging their speakers, although all the boxes and the speakers say "Made in the Philippians" ;-) The workmanship of the speakers is great! I have to figure out how to mount the rear/side speakers as they are MUCH bigger than the Polk's that I have up there now, and I doubt that the plastic mounts will hold them at over 7 lbs each ;-) Not sure what happend to the pictures but the are out of order they are last is first and first is last order ;-) http://www.itsallbutstraw.com/galler...g2_itemId=8376 | ||||
| | #210 | ||||
| Re: Slaughter House Cinemas (Project Thread) Congratulations ... they look nice ![]() To place the surrounds maybe you can use just screws and plastic anchors (my JBL weights 11lbs, and that's what I'm using); or you can use a small shelf too ![]() EDIT: I forgot ... Why did you place the sub with port facing to the room??? ... Try it facing to the walls and see how they sound... Last edited by salvasol; 10-18-08 at 01:44 PM.. Reason: Add text | ||||
| | #211 | |||||
Well that is just the way they seemed to look best ;-) plus they are a pin in the to move with spikes and the little wound spike pads LOL I will maybe try turning them to point to the walls, but I don't want to turn them completely around because the other side of the port is the amp and connections :-) Also can you show me how you mounted your surrounds? Last edited by carls64; 10-18-08 at 07:32 PM.. | |||||
| | #212 | ||||||
... maybe this subs are meant to be used the way you have them (mine have the port in the same side as the amp and connections )Leave it the way you have them now ... please ignore my suggestion ![]() Quote:
![]() they have the mounting holes in the back ... so I just used plastic anchors like this drywall anchors or plastic anchor to hang them on the wall (for drywall ... the first one is better) | ||||||
| | #213 | ||||
| Re: Slaughter House Cinemas (Project Thread) These are considered bookshelf speakers so they have no mounting hols on the back :-( | ||||
| | #214 | |||||
) just get a pair of small shelf at Lowes or Home Depot (like this so they don't show the brackets)Also, What receiver are you using??? ...I just noticed that the speakers are rated 6 ohms, I'm sure you'll be okay but take a look at the manual to see if there's any caution note when using speakers rated below 8 ohms ... better safe than sorry ![]() | |||||
| | #215 | ||||
| Re: Slaughter House Cinemas (Project Thread) It's a Yamaha RX-V663 Good thing you said that as it needed to be changed over to 6 ohm Min! Hope the I didn't hurt anything we watched a 2 hr movie like that ![]() I switched it now to 6 ohm so we shall see, the unit did not seem to be hot or anything so we shall see. ![]() | ||||
| | #216 | |||||
![]() I have the RXV 2700, and in a review I found online they suggested to keep the AVR at 8 ohms even if the speakers used were 4-6 ohms (specifically 4 ohms) ... the wattage the AVR outputs was higher (4 ohms speakers; AVR set at 4/6 ohms wattage was 144WPC but when they used the same speakers and set the AVR to 8 ohms the wattage was 272WPC )Try it and see if there's any difference ... just be sure the AVR is not overheating ![]() | |||||
| | #217 | |||||
If you use one set (A or B), the impedance of each speaker must be 8Ω or higher. If you use two sets (A and B), the impedance of each speaker must be 16Ω or higher.* Center The impedance of each speaker must be 8Ω or higher. Surround Surround back 6ΩMIN Front If you use one set (A or B), the impedance of each speaker must be 4Ω or higher. If you use two sets (A and B), the impedance of each speaker must be 8Ω or higher. Center The impedance of each speaker must be 6Ω or higher. Surround Surround back | |||||
| | #218 | ||||||
| Re: Slaughter House Cinemas (Project Thread) I found this Quote:
| | #220 | ||||
| Re: Slaughter House Cinemas (Project Thread) Why yes, yes I did Ok so how much is that going to cost me ![]() | ||||
| | #221 | |||||
| | #222 | ||||
| Re: Slaughter House Cinemas (Project Thread) I like this two (BTW, I got the Servo 600 refurbished ... so I paid less than what they show on the link) ![]() | ||||
| | #223 | |||||
| | #224 | |||||
![]() The sound changed a lot, and got some load out of the Yamaha (just removing the fronts) ... as far as bridging the amp to power the center I can't tell you ... I remember reading that you can assign the internal amps to bi-amp speakers but I'm not sure about bridging ![]() | |||||
| | #225 | ||||
| Re: Slaughter House Cinemas (Project Thread) Ok have some pictures of the surrounds shelves, thanks salvasol! ![]() ![]() ![]() ![]() ![]() | ||||
