| Home Theater Design and Construction Goon's new theater roomDiscuss Goon's new theater room in the Home Theater Installation and Systems forum; Goon's new theater room I'll be moving into a new house in a few weeks so while bored at work today I modeled the ... |
| | #1 (Link) | |||
| Goon's new theater room I'll be moving into a new house in a few weeks so while bored at work today I modeled the basement in Sketchup and couldn't resist posting it! I will definitely be doing some acoustic treatment in the room so I'll be back with measurements once we are all moved in. Also not shown are my sonosubs as I'm not sure where they will be. I'd like to get even bass coverage in the ping pong area as well if I can. Behind the screen is another window and down the hall to the right are 2 bedrooms and a bathroom. ![]() | |||
| | #3 (Link) | ||||
| Re: Goon's new theater room Quote:
![]() ![]() I'm not sure if I'd be able to walk between them and the couch but that would be interesting. Thanks for the idea! | ||||
| | #5 (Link) | |||
| Re: Goon's new theater room Are you talking about the tiny tubes on the L + R of your scrren???? ![]() THXGoon.jpg Will you test to find the the place with the best response on your room or just a placement for aesthetic reasons??? ... What about one placed horizontally behind the couch??? ... and the other ![]() | |||
| | #6 (Link) | |||
| Re: Goon's new theater room Those are the ones! Lol! I'll definitely be putting performance ahead of asthetics and my roommates already know this ![]() Bryan that's an interesting idea. I guess I'll have to get in there and do some listening. How do you think having the subs so far apart would affect their sound? | |||
| | #7 (Link) | |||
| Re: Goon's new theater room I think it would give you a ton of options to play with tuning for best response and give you an immersive bass field in the theater area as well as getting good fill in the other areas. Bryan | |||
| | #10 (Link) | ||||
... I have a small 10" inside my riser and I can feel the shake, I can imagine how you fell with those 15" and 18" around you ![]() | ||||
| | #11 (Link) | ||||
![]() We're all in this together! | ||||
| | #12 (Link) | |||
| Re: Goon's new theater room Well, I got everything in and set up as in Mike's suggestion and it sounds pretty good. The acoustics are light years ahead of my old room. I'm thinking of reverting back to my old S-150 speakers as the S-5000's are a bit bright in this room. Here's some REW's of the subs on the side of the couch. Uncorrected ![]() With 4 EQ filters ![]() Waterfall of new room (frequency to 200... oops) ![]() Just to give an idea for how much better the acoustics are, here's a waterfall from my old room. Note that the time scale on the old room is 933ms vs 300 on the new room. ![]() The bass is definitely less immersive and requires about 7db extra gain to keep up but they sure sound good. They literally dissapear into the front soundstage as they should I still intend to try Brian's idea and move things around a bit but there are still boxes everywhere.... | |||
| Tags |
| goon's, room, theater |
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Theater Room Layout Question | TCinGA | Home Theater Design and Construction | 21 | 05-02-08 03:19 PM |
| Theater room overhaul | Rambo4 | Home Theater Design and Construction | 9 | 03-12-08 10:32 PM |
| Goon's theater | thxgoon | Home Theater Equipment | 9 | 10-31-07 08:25 AM |
| Our First Dedicated Theater Room | Jeff Aguilar | Home Theater Design and Construction | 1 | 10-28-07 12:32 AM |
| my idea theater\game room | scott | Home Theater Design and Construction | 8 | 01-24-07 07:24 AM |
