Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
New HT Project: Construction questions
Discuss New HT Project: Construction questions in the Home Theater Installation and Systems forum; New HT Project: Construction questions It is shaping up quite nicely!!!...
Views: 3317 - Replies: 83
Old 07-07-09, 06:04 AM   #76
Alias: Matt
hddummy's Avatar
Loc: ATL
User: #7380
Since: Mar 2007
  hddummy is offline
Re: New HT Project: Construction questions
Old 07-07-09, 07:00 AM   #77
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Very nice. Congrats on getting that portion done. Excellent set of pics showing the progress. That's going to look really sweet when the screen wall/screen are done.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 07-07-09, 09:25 AM   #78
Alias: Zip
MatrixDweller's Avatar
Loc: Canada
User: #10408
Since: Jul 2007
  MatrixDweller is offline
Looks awesome. How does it sound with all of those treatments up?
Old 07-07-09, 07:59 PM   #79
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is offline
It's looking good Duc..and the equipment rack looks to have turned out fine..
What did you put on or over the front wall insulation to make it black?
Prof..
Home Theatre...the never ending story!
Old 07-13-09, 10:20 AM   #80
Silver Supporter
Alias: Duc
DucatiR's Avatar
Loc: Idaho
User: #27147
Since: Oct 2008
  DucatiR is offline
MatrixDweller wrote: View Post
MatrixDweller, the sound improvement is remarkable. In Dark Knight Batman shoots his goo-bombs onto a building in Hong Kong. I found myself startled and looking to the left as he fired his gun and then the sound of bomb sticking to the glass in the front center. That same scene did not sound nearly so clear pre-treatment.
Prof. wrote: View Post
Prof., at a local fabric store I picked up 'speaker grille cloth' for $9.99/yd minus my 40% off coupon. I probably didn't need to do the whole wall since not all of it would be visible behind the screen.
I now have the screen frame up and ready and also installed my behind screen lighting effect.
Here is the skeleton screen frame before painting. Estimated screen weight is 30lb so I didn't think I needed a rock solid frame attached to all surfaces. The beam is made of 2-1x4 oak pieces laminated together to minimize vertical sag. It is attached to the vertical struts with a plate made for fence/deck construction.
Name:  frame plate.JPG.jpg
And a picture after painting the frame elements I thought might be exposed to the projector image behind the screen. The unpainted wood pieces will be used to staple speaker cloth across the openings.
Name:  screen frame painted.JPG.jpg
I have seen several pictures of lighting behind acoustically transparent screens and have attempted to set up that effect. I used led puck lights that can be plugged into an outlet.
Name:  led puck original.JPG.jpg
The cover of the puck light removes easily enough. But why?
Name:  puck cap removed.JPG.jpg
I wanted a blue light effect to match the blue rope light around the riser. This shot shows a comparison of the puck light with blue glass over the top. One with the white cover in place beneath, the other with the cover removed. Considerably more light come through without the diffuser cover as one might imagine.
Name:  blue glass compare.JPG.jpg
I found the glass at a local stained glass business. Since the pucks are out of view I just went with square cut pieces which were considerably cheaper than having them cutting circles or me fruitlessly trying. I attached the glass to the led puck with a few beads of clear silicone.
Name:  slicone application.JPG.jpg
The pucks were mounted behind the oak beam on a piece of scrap wood screwed into the frame.
Name:  puck mounted.JPG.jpg
Name:  mount side view.JPG.jpg
Here is the screen wall with light accents and the screen frame painted.
Name:  screenwall lighted2.jpg
My anamormphic lens is sitting at the post office waiting to be picked up. Projector is on a truck somewhere. And the screen is supposed to ship on Tuesday.
Old 07-13-09, 11:50 AM   #81
Shack Moderator
Alias: Ted White
Loc: Michigan
User: #37110
Since: May 2009
  Ted White is offline
Wow. Love the blue a lot!
Old 07-13-09, 07:30 PM   #82
Silver Supporter
Alias: Bruce
Loc: Charlotte, NC
User: #13727
Since: Nov 2007
  Bruce Fisher is offline
Nice - that looks great! I like the Blue... I saw those pucks at Lowes (or HD, can't remember) and was thinking about using them. Hadn't thought about the blue though! I like it!
Old 07-13-09, 08:36 PM   #83
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
DucatiR wrote: View Post
A lot of people do cover the whole front wall insulation with the black cloth..even though you won't see it it..
I'm a bit of a cheapskate, so I just covered the bits you might see!.
Attachment 14925
Attachment 14922
Attachment 14919
Attachment 14927
The blue lights look cool!..
With the screen in front, it should look quite spectacular..
Prof..
Old 07-14-09, 09:27 AM   #84
Alias: patchesj
User: #38686
Since: Jun 2009
  patchesj is offline
Looking good! Love the blue pucks, please take a few pictures of them once you get the screen in place. Have you had any issues with sound traveling in the duct work?
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
construction, floor, questions
