Ahaa!!..now I've got ya..good old velcro!! :T
That's what I used to fix my acoustic panels in place..
When you said "hung" I presumed that you were fitting them on to some sort of bracket system..:R
Here are som pictures of the later part of the building of am acoustic frame. Not inkluded in the pictures are initial measurements, kutting wood, drilling of holes, screwing the frame together, routing of edges and cutting of the acoustic panels.
Here is a frame with the Rockwool Acoustic panels.
A closer look on the corner.
Then it is time to cut the fabric into the right size. You need to have enough fabic to fold up and around the outer eges of the frame.
The cloth is fastened by starting the stretching on the middle of each side, and then gradually working from the middle, along the edge towards the corners
The corners are folded as neatly as possible. This is my method of choice.
Excess fabric is cut from the corners.
Then I use velcro tape to fasten the frame to the wall. The glue on the tape is not fastening properly, so I have to use staples.
Using velcro on the wall too, makes hangig the frames easy.
Yes..that's exactly how I made my panels and fitted them to the walls...right down to the stapling on of the velcro..
That's going to be a lot of work!!..I know how long it took me to make up just 4 panels..:whew:
I just wanted to say that the room is looking fantastic, I've enjoyed watching your build! And thank you - thank you very much - for the idea of using velcro to hold the acoustic screens up. My room has angled walls and I had been racking my brain trying to come up with a method to install the screens up evenly. Velcro - awesome!
More panels are done here. Still working along two walls in parallell, but can't conclude that it is more efficient. Anyway, almost half of the walls done. :bigsmile:
When I am not needed for the kids or have other plans for the evening, I usually put in some hours between 18:00 and 23:00 (Norwegian time). I then update the web if there is something to report, and get to bed around 01:00. :coocoo:
More of the same (acoustic boards).
This wall now has 5 boards, one more to go:
Not much has happened on this side of the room since the last post:
I may not have mentioned it before, but frames for the in-wall surround speakers are mounted. It can be seen on this and the previous picture.
And here is a view of what remains. I have to do something in the corners of the front wall before I get correct measurements to make the two last boards on the side walls.
The observant may notice that the old CD player is gone. The display that can be seen below this work table is a Squeezebox Classic. The old player is once more hidden away in another storage room.
Something else than acoustic boards for a change. :T
I have now placed cables in the cable channels and made holes for the cables several places. In the front corners are wooden boards put in diagonally, making them cable channels from ceiling to floor.
Here are the cables for the left surround speakers and HDMI for the projector, too:
And the same way for the speakers on the right side:
Here are the front corner cable channels pretty obvious.
A closer look on one of the speaker cables in the front of the room.
Hole for the audio and video cables behind the front rack:
A lot of cables through one hole, but still room for a bit more:
A closer look on the hole for the projector HDMI cable.
And some more wood is still to come. Here a quick shot of some, painted before it is mounted:
Do you see what's new compared to the previous picture post? The solution is below the pictures.
You probably saw that I have put in a carpet. The reason is partly acoustics, but also because the room gets a "warmer" feel to it. The carpet is only 3mm thick and the floor heating is coming through nicely to the rest of the room.
Not as much as I hoped, actually, but it is nicer to walk on, so I think the carpet is a keeper. The floor boards look good, but they were not expensive, so I have no regrets about choosing carpet instead.
Related Threads
742.3K posts
170.9K members
Since 2006
