In the beginning
Project "C8" has started!
I may be Norways slowest home theater builder, at least when you include the fact that I have been planning this particular room since 2003. I'll not dwell on the reasons for this taking me so long. But you may say I have had enough time to make plans.
I have named the project "C8". This may mean a lot of things, but for me it stands for "Cinema 8". The number 8 has many meanings, it is a chinese symbol for happiness, the floor area of the room is between 8 and 9 square meters, there are 8 channels in a 7.1 system...
There may be other reasons, but by now you may be saying: "8 square meters!???". And, yes, it will be about that size when finished.
This is the reason I think it will be Norways smallest home cinema. There may be some smaller, but i doubt they are dedicated HT rooms, and I doubt they can seat a whole family.
Here are some early planning sketches:
The first sketch shows something about how I imagine the front speaker setup. It is rather old, andsome changes may be made.
Here is another sketch. The speakers will not be like this, but the seating arrangements are close to what I'll be making:
I am not going to spoil the excitement by telling every detail, but here are some points to keep the expectations to a realistic level:
- There is no room-in-room solution. That would steal too much floor space.
- The bass acoustics will not be perfect. This must be solved using electronic room correction.
- It will not be the most beautiful home theater in the world. The finish will be limited of my limited carpentry skills and the fact that the room will be mostly dark.
- It will not be an all black bat cave.
- There will be compromises.
- There will be DIY-solutions
- A lot of stuff will be done to save and utilise space.
The project has started with cleaning up the room. Here is the unpromising start:
After cleaning and some deconstruction:
I guess a lot of my spare time will be spent on this project. I don't know when I'll finish, that's part of the excitement.
