Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
A/V Closet ideas??
Discuss A/V Closet ideas?? in the Home Theater Installation and Systems forum; A/V Closet ideas?? I'm working on building my media room in my basement. We've almost finished getting the walls put up in place ...
Views: 1349 - Replies: 12
Old 12-03-08, 04:37 PM   #1
Alias: Mark
Loc: Chilliwack
User: #27135
Since: Oct 2008
  markopolo is offline
A/V Closet ideas??
I'm working on building my media room in my basement. We've almost finished getting the walls put up in place so I'm starting to think about my wiring etc. for the media room. my dimensions are roughly 12'6"x21' for the room. At the back left of the room is where I'm situating my A/V components in a 4'x4' closet. In the closet will go the following:
HDPVR Cable Box
Receiver
DVD Player
Future piece (or 2)
I'd like as nice and clean of an installation as possible, yet still functional. My thoughts were to use wire shelving as it would allow good air circulation around all the components. What I was thinking of, was to use wire shelving and mount it to a sliding rack system, so the components could be slid out and the backs accessed easily.
I'd appreciate any advice from those with A/V closets out there. Thanks!
Old 12-03-08, 04:41 PM   #2
Alias: ludwignew
ludwignew's Avatar
Loc: México
User: #28696
Since: Nov 2008
  ludwignew is offline
Re: A/V Closet ideas??
What kind of speakers do you want? Maybe liket towers or something like that?
When the game ends, the king and the pawn return to the same box.
Old 12-03-08, 05:12 PM   #3
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
markopolo wrote: View Post
That's a good idea ...Are you planning to have it closed or open??? ...Any plans to install a fan to keep the hot air out???
Old 12-03-08, 06:33 PM   #4
Alias: Mark
Loc: Chilliwack
User: #27135
Since: Oct 2008
I'm planning on it being a closed closet. It is on an outside corner, so I may end up cutting a vent to the outside and put a passive vent in. That way the hot air can escape easily to the outdoors. Don't think a fan would be needed in that case.
Old 12-03-08, 06:40 PM   #5
Alias: Mark
Loc: Chilliwack
User: #27135
Since: Oct 2008
ludwignew wrote: View Post
I have some old Sony towers that I will likely use for my fronts and a corresponding set of surrounds for all the other spots. Why do you ask?
Old 12-03-08, 08:58 PM   #6
Alias: Kyle
Loc: Orlando, FL
User: #29770
Since: Dec 2008
  Quartermaster is offline
I suggest Definitive technology BP7002 for fronts, I have a pair of these and they are remarkable.
Old 12-03-08, 10:26 PM   #7
Alias: Mark
Loc: Chilliwack
User: #27135
Since: Oct 2008
Quartermaster wrote: View Post
Thanks but I'm not looking to replace what I have at this time. Priority is getting the room built. I'm just looking for advice on how to setup the closet.
Old 12-03-08, 10:45 PM   #8
Alias: Mark
Loc: Chilliwack
User: #27135
Since: Oct 2008
Here's a pic of my layout. As you can see, the closet is on the complete opposite end of the room.
Old 12-03-08, 11:43 PM   #9
Alias: Kyle
Loc: Orlando, FL
User: #29770
Since: Dec 2008
What kind of receiver are you using, Brand, Watt, Size? From the looks of your list of components your receiver will be producing the most heat. I like the idea of separating the gaming equip from the other components which produces loads of heat. 4x4 is small but I think you would be fine with the current set up; it all kind of depends on what future piece you were thinking of purchasing. You get 1 or 2 high powered amps in there and it would turn in to an oven.
Old 12-04-08, 01:56 AM   #10
Alias: Mark
Loc: Chilliwack
User: #27135
Since: Oct 2008
It's a simple Sony... STR-K900. I definitely agree that the room would get very hot adding higher powered amps, which is why I think I'll add the "dryer vent" to the outside right away. That vents to the outside of my house and I can add a fan if needed.
Old 12-04-08, 02:03 PM   #11
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
About the pro-amps producing more heat ...it will depend on how hard you play your system; I have a Samsom Servo 600 that gets warm but not exagerated.
Are you planning to complete conceal the equipment??? ...or will they be visible (maybe a glass door)???
Something like this ...
Name:  Tanner Cinema.jpg
Old 12-04-08, 05:14 PM   #12
Alias: Mark
Loc: Chilliwack
User: #27135
Since: Oct 2008
salvasol wrote: View Post
It's actually a "walk-in closet", completely concealed with a solid door. I'm going to use an IR repeater to transmit the signal from the front of the room to the closet in the back. The room is designed "multi-purpose" for potential resale to be a 4th bedroom. Hence, the needed closet.
Old 12-04-08, 05:28 PM   #13
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
It's actually a "walk-in closet", completely concealed with a solid door. .
If that's the case ...I think you can stick with your original plan (vented duct) and if you want to add a vent to the door it will help too
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
closet, ideas??
